void InitSysCtrl(void)
unsigned int i;
EALLOW;
// On TMX samples, to get the best performance of on chip RAM blocks M0/M1/L0/L1/H0 internal
// control registers bit have to be enabled. The bits are in Device emulation registers.
DevEmuRegs.M0RAMDFT = 0x0300;
DevEmuRegs.M1RAMDFT = 0x0300;
DevEmuRegs.L0RAMDFT = 0x0300;
DevEmuRegs.L1RAMDFT = 0x0300;
DevEmuRegs.H0RAMDFT = 0x0300; //初始化RAM
// Initalize PLL
SysCtrlRegs.PLLCR = 0x9; //CLKIN=(OSCCLK*10.0)/2
// Wait for PLL to lock
for(i= 0; i< 5000; i++){}
// HISPCP/LOSPCP prescale register settings, normally it will be set to default values
SysCtrlRegs.HISPCP.all = 0x0001; //高速时钟=SYSCLKOUT/2=150M/2=75M
SysCtrlRegs.LOSPCP.all = 0x0002; //低速时钟=SYSCLKOUT/4
// Peripheral clock enables set for the selected peripherals.
SysCtrlRegs.PCLKCR.bit.EVAENCLK=1;
SysCtrlRegs.PCLKCR.bit.EVBENCLK=1;
//SysCtrlRegs.PCLKCR.bit.EVBENCLK=1;
//SysCtrlRegs.PCLKCR.bit.SCIENCLKA=1;
//SysCtrlRegs.PCLKCR.bit.SCIENCLKB=1;
//SysCtrlRegs.PCLKCR.bit.ADCENCLK=1;
EDIS;
// KickDog:
// This function resets the watchdog timer.
// Enable this function for using KickDog in the application
// Non-Peripheral Interrupts
INT13_ISR, // XINT13 or CPU-Timer 1
INT14_ISR, // CPU-Timer2
DATALOG_ISR, // Datalogging interrupt
RTOSINT_ISR, // RTOS interrupt
EMUINT_ISR, // Emulation interrupt
NMI_ISR, // Non-maskable interrupt
ILLEGAL_ISR, // Illegal operation TRAP
USER0_ISR, // User Defined trap 0
USER1_ISR, // User Defined trap 1
USER2_ISR, // User Defined trap 2
USER3_ISR, // User Defined trap 3
USER4_ISR, // User Defined trap 4
USER5_ISR, // User Defined trap 5
USER6_ISR, // User Defined trap 6
USER7_ISR, // User Defined trap 7
USER8_ISR, // User Defined trap 8
USER9_ISR, // User Defined trap 9
USER10_ISR, // User Defined trap 10
USER11_ISR, // User Defined trap 11
unsigned int i;
EALLOW;
// Initalize PLL
EDIS;
// KickDog:
