4375|3
92
关于2812烧写的问题 [复制链接]
请问EEWORLD的工程师,小弟第一次烧写2812,结果程序运行到一个FOR循环时卡住出不来了(我在FOR循环后加了个亮灯的语句,结果没有亮灯,去掉FOR循环,亮灯正常,故得出程序卡在FOR循环里了)还请达人指点一下啊。我在编译时,曾报这样的警告:
>> warning: creating .stack section with default size of 400 (hex) words.
   Use
            -stack option to change the default size.
不知道跟这个有没有关系?
我的CMD配置文件如下:
MEMORY
PAGE 0:    /* Program Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
   ZONE0       : origin = 0x002000, length = 0x002000     /* XINTF zone 0 */
   ZONE1       : origin = 0x004000, length = 0x002000     /* XINTF zone 1 */
   ZONE2       : origin = 0x080000, length = 0x080000     /* XINTF zone 2 */
   ZONE6       : origin = 0x100000, length = 0x080000     /* XINTF zone 6 */
   OTP         : origin = 0x3D7800, length = 0x000800     /* on-chip OTP */
   FLASHJ      : origin = 0x3D8000, length = 0x002000     /* on-chip FLASH */
   FLASHI      : origin = 0x3DA000, length = 0x002000     /* on-chip FLASH */
   FLASHH      : origin = 0x3DC000, length = 0x004000     /* on-chip FLASH */
   FLASHG      : origin = 0x3E0000, length = 0x004000     /* on-chip FLASH */
   FLASHF      : origin = 0x3E4000, length = 0x004000     /* on-chip FLASH */
   FLASHE      : origin = 0x3E8000, length = 0x004000     /* on-chip FLASH */
   FLASHD      : origin = 0x3EC000, length = 0x004000     /* on-chip FLASH */
   FLASHC      : origin = 0x3F0000, length = 0x004000     /* on-chip FLASH */
   FLASHA      : origin = 0x3F6000, length = 0x001F00     /* on-chip FLASH */
   romfunc     : origin = 0x3f7f00, length = 0x0000f0          /* used to store ram function */
   BEGIN       : origin = 0x3F7FF6, length = 0x000002     /* Part of FLASHA.  Used for \"boot to Flash\" bootloader mode. */
   ramfunc           : origin = 0x3f8000, length = 0x0000f0     /* used for ram function */
   RAMH0              : origin = 0x3F80f0, length = 0x001f0e     /* on-chip RAM block H0 */
/*   BEGIN       : origin = 0x3F9ffe, length = 0x000002*/
/*   ZONE7       : origin = 0x3FC000, length = 0x003FC0     /* XINTF zone 7 available if MP/MCn=1 */
   ROM         : origin = 0x3FF000, length = 0x000FC0     /* Boot ROM available if MP/MCn=0 */
   RESET       : origin = 0x3FFFC0, length = 0x000002     /* part of boot ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
   VECTORS     : origin = 0x3FFFC2, length = 0x00003E     /* part of boot ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
PAGE 1 :   /* Data Memory */
           /* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE0 for program allocation */
           /* Registers remain on PAGE1                                                  */
   RAMM0       : origin = 0x000000, length = 0x000400     /* on-chip RAM block M0 */
   RAMM1       : origin = 0x000400, length = 0x000400     /* on-chip RAM block M1 */
   DEV_EMU     : origin = 0x000880, length = 0x000180     /* Device emulation registers */
   FLASH_REGS  : origin = 0x000A80, length = 0x000060     /* FLASH registers */
   CSM         : origin = 0x000AE0, length = 0x000010     /* Code security module registers */
   XINTF       : origin = 0x000B20, length = 0x000020     /* External interface registers */
   CPU_TIMER0  : origin = 0x000C00, length = 0x000008     /* CPU Timer0 registers (CPU Timer1 and Timer2 are reserved for BIOS)*/
   PIE_CTRL    : origin = 0x000CE0, length = 0x000020     /* PIE control registers */
   PIE_VECT    : origin = 0x000D00, length = 0x000100     /* PIE vector table */
   ECAN_A      : origin = 0x006000, length = 0x000100     /* eCAN registers */
   ECAN_AMBOX  : origin = 0x006100, length = 0x000100     /* eCAN mailboxes */
   SYSTEM      : origin = 0x007010, length = 0x000020     /* System control registers */
   SPI_A       : origin = 0x007040, length = 0x000010     /* SPI registers */
   SCI_A       : origin = 0x007050, length = 0x000010     /* SCI-A registers */
   XINTRUPT    : origin = 0x007070, length = 0x000010     /* External interrupt registers */
   GPIOMUX     : origin = 0x0070C0, length = 0x000020     /* GPIO mux registers */
   GPIODAT     : origin = 0x0070E0, length = 0x000020     /* GPIO data registers */
   ADC         : origin = 0x007100, length = 0x000020     /* ADC registers */
   EV_A        : origin = 0x007400, length = 0x000040     /* Event Manager A registers */
   EV_B        : origin = 0x007500, length = 0x000040     /* Event Manager B registers */
   SCI_B       : origin = 0x007750, length = 0x000010     /* SCI-B registers */
   MCBSP_A     : origin = 0x007800, length = 0x000040     /* McBSP registers */
   RAML0       : origin = 0x008000, length = 0x001000     /* on-chip RAM block L0 */
   RAML1       : origin = 0x009000, length = 0x001000     /* on-chip RAM block L1 */
   FLASHB      : origin = 0x3F4000, length = 0x002000     /* on-chip FLASH */
   CSM_PWL     : origin = 0x3F7FF8, length = 0x000008     /* CSM password locations in FLASHA */
/* Allocate sections to memory blocks.
   Note:
         codestart user defined section in DSP28_CodeStartBranch.asm used to redirect code
                   execution when booting to flash
         ramfuncs  user defined section to store functions that will be copied from Flash into RAM
SECTIONS
   /* Allocate program areas: */
  /* .cinit              : > RAMH0      PAGE = 0*/
  .cinit              : > FLASHA      PAGE = 0
  /*.text               : > RAMH0      PAGE = 0*/
  .text               : > FLASHC      PAGE = 0
   codestart           : > BEGIN      PAGE = 0
   ramfuncs            : LOAD = romfunc, RUN = ramfunc, PAGE = 0
   /*ramfuncs                           : > RAMH0      PAGE = 0*/
   /*ramfuncs                           : > FLASHC      PAGE = 0*/
   /* Allocate uninitalized data sections: */
   .stack              : > RAML0       PAGE = 1
   .bss                : > RAML1       PAGE = 1
   .ebss               : > RAML1       PAGE = 1
   .sysmem             : > RAMM1       PAGE = 1
   .esysmem            : > RAMM1       PAGE = 1
   /* Initalized sections go in Flash */
   .const              : > RAMM0      PAGE = 1
   .econst             : > RAMM1      PAGE = 1
   /* Allocate IQ math areas: */
   IQmath              : > RAMH0       PAGE = 0                 /* Math Code */
   IQmathTables        : > ROM         PAGE = 0, TYPE = NOLOAD   /* Math Tables In ROM */
   /* .reset indicates the start of _c_int00 for C Code.
   /* When using the boot ROM this section and the CPU vector
   /* table is not needed.  Thus the default type is set to
   /* DESECT */
   .reset              : > RESET,      PAGE = 0, TYPE = DSECT
   vectors             : > VECTORS     PAGE = 0, TYPE = DSECT
/* The following allocations are required for the DSP28 Header file
   examples.  Each allocation maps a structure defined in the DSP28
   header files to the memory location of those registers.
   /* Allocate Peripheral Frame 0 Register Structures:   */
   DevEmuRegsFile      : > DEV_EMU     PAGE = 1
   FlashRegsFile       : > FLASH_REGS  PAGE = 1
   CsmRegsFile         : > CSM         PAGE = 1
   XintfRegsFile       : > XINTF       PAGE = 1
   CpuTimer0RegsFile   : > CPU_TIMER0  PAGE = 1
   PieCtrlRegsFile     : > PIE_CTRL    PAGE = 1
   PieVectTable        : > PIE_VECT    PAGE = 1
   /* Allocate Peripheral Frame 2 Register Structures:   */
   ECanaRegsFile       : > ECAN_A      PAGE = 1
   ECanaMboxesFile     : > ECAN_AMBOX  PAGE = 1
   /* Allocate Peripheral Frame 1 Register Structures:   */
   SysCtrlRegsFile     : > SYSTEM      PAGE = 1
   SpiaRegsFile        : > SPI_A       PAGE = 1
   SciaRegsFile        : > SCI_A       PAGE = 1
   XIntruptRegsFile    : > XINTRUPT    PAGE = 1
   GpioMuxRegsFile     : > GPIOMUX     PAGE = 1
   GpioDataRegsFile    : > GPIODAT     PAGE = 1
   AdcRegsFile         : > ADC         PAGE = 1
   EvaRegsFile         : > EV_A        PAGE = 1
   EvbRegsFile         : > EV_B        PAGE = 1
   ScibRegsFile        : > SCI_B       PAGE = 1
   McbspaRegsFile      : > MCBSP_A     PAGE = 1
   /* CSM Password Locations */
   CsmPwlFile          : > CSM_PWL     PAGE = 1
这个警告,你可以通过在Project-Buildoption下具体记不清了,有stack size后面有框,填入比如500,可能就好了,我改过,好像是从阿甘的博客那里看到的。  详情 回复 发表于 2008-12-16 15:11
你好 我同样为烧写的问题困扰,一怒之下改成汇编语言了 不过告诉我一个和你不样的问题,我也不知道怎么解决  你能告诉我你烧写用的插件和你的CCS环境的版本吗 还有能让我看看你的程序吗?? 我的信箱:zhb-98@sohu.com 希望和你多多联系!
67
2812用C语言很好写程序,汇编我觉得比较麻烦.
估计程序不可能给你看的
78
