14131|26
ADC采集的数据怎么那么不准 [复制链接]
我在他的AD上外部接了干电池, 我把电压调整到2.8V,采样250次后 我看数据, 发现数据 从3470----3420 的数据都有,真的叫人郁闷 请问香主 他的误差有那么大么.
我把电路贴出来, 不知道那位采的数据精确点啊
此帖出自stm32/stm8论坛
                                 ADC1的时钟越高越稳定 还是越低越稳定?   详情 回复 发表于 2009-6-25 17:32
85
我再贴下程序
   RCC_ADCCLKConfig(RCC_PCLK2_Div8);
   RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOC
                           RCC_APB2Periph_ADC1,   ENABLE);
 RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|
                                 GPIO_Pin_6;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
   GPIO_Init(GPIOA, &GPIO_InitStructure);
   ADC_DeInit(ADC1);
   ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;                    //ADC1 configuration
   ADC_InitStructure.ADC_ScanConvMode = ENABLE;
   ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
   ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T4_CC4;
   ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
   ADC_InitStructure.ADC_NbrOfChannel = 6;
   ADC_Init(ADC1, &ADC_InitStructure);
   for (cnt = 0; cnt < 6; cnt++) {
       ADC_RegularChannelConfig(ADC1, Adc_ChallArr[cnt], cnt+1, ADC_SampleTime_13Cycles5); //ADC1 regular channelx configuration
  // ADC int  dma and trugle source enable ------------------------------//
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);                                                 // Enable ADC1 DMA
  ADC_ExternalTrigConvCmd(ADC1, ENABLE);                                 //Enable ADC1 external trigger
                                                 // Enable ADC1
  //ADC Calibration model------------------------------------------------//
  ADC_ResetCalibration(ADC1);                                            // Enable ADC1 reset calibaration register
  while(ADC_GetResetCalibrationStatus(ADC1));                            //Check the end of ADC1 reset calibration register
  ADC_StartCalibration(ADC1);                                            //tart ADC1 calibaration
  while(ADC_GetCalibrationStatus(ADC1));                                 //Check the end of ADC1 calibration
此帖出自stm32/stm8论坛
用示波器看一下VDDA和VREF……然后看一下信号
                                 布线布局情况未知,不好说。不过一般说来ADC只跳变2bit是很容易做到的
此帖出自stm32/stm8论坛
81
注意VDDA和VREF+上的滤波电容应尽可能地靠近芯片
                                 同时要保证VDDA和VREF+上的电压稳定。
此帖出自stm32/stm8论坛
我贴下PCB
此帖出自stm32/stm8论坛
77
怎么没人回答
此帖出自stm32/stm8论坛
79
Vdd和Vdda的差值最好小于0.3V
此帖出自stm32/stm8论坛
62
我使用 的TL431 输出的是3.3V
此帖出自stm32/stm8论坛
AD脚输入阻抗如何?
                                 我4楼引用的帖子就是TL431线路没搞好。
此帖出自stm32/stm8论坛
79
我看了帖子了 我的TL431很稳定
                                 TL431输出的是3.3341V 我的带了 10UF和 0.1UF的电容 在TL431的输出
此帖出自stm32/stm8论坛
84
STM32的AD没那么难
                                 可以用示波器测量单片机的模拟电源和输入脚 的纹波,建议用交流档测。
此帖出自stm32/stm8论坛
61
没看到AD端怎样接的
逐次逼近型模拟数字转换器
必需在输入端接个电容
我的当时也是不准,后来AD端接了个10nF的电容后就准了
此帖出自stm32/stm8论坛
88
AD输入端接个电容?
                                 可是AD的输入端的管脚那么密  ,怎么放那么多电容, 到底怎么放啊, 是否在信号的输出端加10NF电容? yjgyiy 能加我QQ么  729184380
此帖出自stm32/stm8论坛
87
TO 楼上
不好意思
不班不能QQ
可以在信号的输出端加10nF电容
不是10NF
此帖出自stm32/stm8论坛
66
AD输入端接个电容
  AD输入端(或者信号的输出端)接个小电容,只是在信号是直流或者接近直流时才这么做,否则信号就被小电容滤掉了。
  对于很多AD(包括STM32的AD)来说,这个小电容不是必须的。
此帖出自stm32/stm8论坛
77
bu 不接小电容的话 就是测直流都跳的很很厉害
此帖出自stm32/stm8论坛
64
IJK 可以加我么
                                 帮我看看板子  给点指导啊
此帖出自stm32/stm8论坛
81
ijk 你出来啊 说下你是怎么测试的
                                 可以加我的QQ  729184380 么  我跟你讨论下 可以不
此帖出自stm32/stm8论坛
测直流
  曾经在ST的官方板子(STM3210B)上面测过直流,就是测10k电位器的电压(电位器的输出应该没有接电容),效果挺好:
1)~4000
    min        4058
    max        4064
2)~3000
    min        2952
    max        2956
3)~2000
    min        2027
    max        2030
4)~1000
    min        980
    max        982
5)<100
    min        51
    max        52
从结果来看, ADC转换的结果挺稳定 (ADC转换结果取了 4次的平均)
此帖出自stm32/stm8论坛
注意事项
                                   STM32的AD使用注意事项,上面已经说了很多了,没什么好多说的。
此帖出自stm32/stm8论坛
