5262|7
如何设定指定地址的FLASH的值? [复制链接]
                                 在 IAR 中,如何在编译时直接设定指定地址的 FLASH 的值
此帖出自stm32/stm8论坛
                                 location Syntax #pragma location={address|SEGMENT_NAME} Parameters  address  The absolute address of the global or static variable for which you want an absolute location.  SEGMENT_NAME  A user-defined segment name; cannot be a segment name predefined for use by the compiler and linker.  Description Use this pragma directive to specify the location—the absolute address—of the global or static variable whose declaration follows the pragma directive. The variable must be declared either __no_init or const. Alternatively, the directive can take a string specifying a segment for placing either a variable or a function whose declaration follows the pragma directive. Example #pragma location=0xFFFF0400 __no_init volatile char PORT1; /* PORT1 is located at address                                   0xFFFF0400 */  #pragma location="foo"  char PORT1; /* PORT1 is located in segment foo */  /* A better way is to use a corresponding mechanism */ #define FLASH _Pragma("location="FLASH"") ... FLASH int i; /* i is placed in the FLASH segment */ See also For additional information and examples, see the ARM® IAR C/C++ Compiler Reference Guide.   详情 回复 发表于 2008-10-31 20:02
64
直接赋值
                                 *((unsigned int*)0x68000000) = 100;
此帖出自stm32/stm8论坛
84
好象不行
                                 在编译时设置和在运行时改写是不同的
此帖出自stm32/stm8论坛
67
如何不同?你是如何写的?
此帖出自stm32/stm8论坛
82
绝对定位或修改烧录(下载)文件
此帖出自stm32/stm8论坛
把一个变量可以定位在 FLASH 中的绝对地址上,但该变量不能赋初值。
程序运行中修改 FLASH 是 IAP 方式,我要的是编译后烧写就完成指定地址
的设置
此帖出自stm32/stm8论坛
66
使用const属性
此帖出自stm32/stm8论坛
67
location
Syntax
Parameters
Example
                                  0xFFFF0400 */
See also
此帖出自stm32/stm8论坛
【TI有奖直播报名中】
直播时间:4月24日(周四)上午10:00
直播奖励:好礼等您拿!
