7957|7
1379
裸片初长成(中级)
PIC CCS C语言程序范例 [复制链接]
#include <16c74.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#include <input.c>
#byte port_b = 6
#define FOUR_PHASE TRUE
#ifdef FOUR_PHASE
byte const POSITIONS[4] = {0b0101,
                           0b1001,
                           0b1010,
                           0b0110};
#else
byte const POSITIONS[8] = {0b0101,
                           0b0001,
                           0b1001,
                           0b1000,
                           0b1010,
                           0b0010,
                           0b0110,
                           0b0100};
#endif
drive_stepper(byte speed, char dir, byte steps) {
   static byte stepper_state = 0;
   byte i;
   for(i=0;i<steps;++i) {
     delay_ms(speed);
     set_tris_b(0xf0);
     port_b = POSITIONS[ stepper_state ];
     if(dir!='R')
       stepper_state=(stepper_state+1)&(sizeof(POSITIONS)-1);
     else
       stepper_state=(stepper_state-1)&(sizeof(POSITIONS)-1);
use_pot() {
  byte value;
  setup_adc(adc_clock_internal);
  set_adc_channel( 1 );
  printf("\r\n");
  while( TRUE ) {
    value=read_adc();
    printf("%2X\r",value);
    if(value<0x80)
       drive_stepper(value,'R',8);
    else if(value>0x80)
       drive_stepper(128-(value-128),'F',8);
use_switch(byte speed, char dir) {
   byte steps;
   printf("\n\rSteps per press: ");
   steps = gethex();
   while(true) {
      while(input(PIN_B7)) ;
      drive_stepper(speed,dir,steps);
      while(!input(PIN_B7)) ;
      delay_ms(100);
main() {
   byte speed,steps;
   char dir;
   setup_port_a(RA0_RA1_ANALOG);
   while (TRUE) {
       printf("\n\rSpeed (hex): ");
       speed = gethex();
       if(speed==0)
          use_pot();
       printf("\n\rDirection (F,R): ");
       dir=getc()|0x20;
       putc(dir);
       printf("\n\rSteps (hex): ");
       steps = gethex();
       if(steps==0)
          use_switch(speed,dir);
Seconds Timer
////                          EX_STWT.C                            ////
//// This program uses the RTCC (timer0) and interrupts to keep a  ////
//// real time seconds counter.  A simple stop watch function is   ////
//// then implemented.                                             ////
//// Configure the CCS prototype card as follows:                  ////
////     Insert jumpers from: 11 to 17 and 12 to 18.               ////
#include <16C84.H>
#use rs232(baud=9600, xmit=PIN_A3, rcv=PIN_A2)
#define INTS_PER_SECOND 76     // (20000000/(4*256*256))
byte seconds;      // A running seconds counter
byte int_count;    // Number of interrupts left before a
   // second has elapsed
#int_rtcc          // This function is called every time
clock_isr() {      // the RTCC (timer0) overflows (255->0).
                   // For this program this is apx 76 times
    if(--int_count==0) {           // per second.
      ++seconds;
      int_count=INTS_PER_SECOND;
main() {
   byte start;
   set_rtcc(0);
   setup_counters( RTCC_INTERNAL, RTCC_DIV_256);
   enable_interrupts(RTCC_ZERO);
   enable_interrupts(GLOBAL);
   do {
      printf("Press any key to begin.\n\r");
      getc();
      start=seconds;
      printf("Press any key to stop.\n\r");
      getc();
      printf("%u seconds.\n\r",seconds-start);
   } while (TRUE);
Simple A/D
////                          EX_ADMM.C                              ////
////  This program displays the min and max of 30 A/D samples over   ////
////  the RS-232 interface.  The process is repeated forever.        ////
////      Insert jumpers from: 11 to 17, 12 to 18 and 9 to 16        ////
////      Use the #9 POT to vary the voltage.                        ////
#include <16C71.H>
#use delay(clock=15000000)
#use rs232(baud=9600,xmit=PIN_A3,rcv=PIN_A2)
main() {
   int i,value,min,max;
   printf("Sampling:");
   setup_port_a( ALL_ANALOG );
   setup_adc( ADC_CLOCK_INTERNAL );
   set_adc_channel( 0 );
   do {
      min=255;
      max=0;
      for(i=0;i<=30;++i) {
         delay_ms(100);
         value = Read_ADC();
         if(value < min)
            min=value;
         if(value > max)
            max=value;
      printf("\n\rMin: %2X  Max: %2X\r\n",min,max);
   } while (TRUE);
Output Listing
....................       min=255;
008D:  MOVLW  FF
008E:  MOVWF  28
....................       max=0;
008F:  CLRF   29
....................       incc=TRUE;
0090:  BSF    2B,0
....................       for(i=0;i<=30;++i) {
0091:  CLRF   26
0092:  MOVLW  1F
0093:  SUBWF  26,W
0094:  BTFSC  03,0
0095:  GOTO   0AC
....................          delay_ms(100);
0096:  MOVLW  64
0097:  MOVWF  2C
0098:  GOTO   02D
....................          value = Read_ADC();
0099:  BSF    1F,2
009A:  BTFSC  1F,2
009B:  GOTO   09A
009C:  MOVF   1E,W
009D:  MOVWF  27
....................          if(value < min)
009E:  MOVF   28,W
009F:  SUBWF  27,W
00A0:  BTFSC  03,0
00A1:  GOTO   0A4
....................             min=value;
00A2:  MOVF   27,W
00A3:  MOVWF  28
....................          if(value > max)
00A4:  MOVF   27,W
00A5:  SUBWF  29,W
00A6:  BTFSC  03,0
00A7:  GOTO   0AA
....................             max=value;
00A8:  MOVF   27,W
00A9:  MOVWF  29
00AA:  INCF   26,F
00AB:  GOTO   092
....................       if (incc)
00AC:  BTFSC  2B,0
....................         counter++;
00AD:  INCF   2A,F
帮我看看我的程序有什么问题?我无法读写EEPROM93LC66B内的数据  详情 回复 发表于 2006-9-3 10:00
1564
禁止发言
Re: PIC CCS C语言程序范例
不懂
Re: PIC CCS C语言程序范例
我也用CCS编程,能否请教些问题
1379
裸片初长成(中级)
Re: PIC CCS C语言程序范例
我也一般就找一些例子做一下 没有自己编写过
Re: PIC CCS C语言程序范例
#ifndef EEPROM_SELECT #define EEPROM_SELECT PIN_C0 #define EEPROM_CLK PIN_C1 #define EEPROM_DI PIN_C2 #define EEPROM_DO PIN_C3 #endif #define EEPROM_ADDRESS long int #define EEPROM_SIZE 512 #define hi(x) (*(&x+1)) void init_ext_eeprom() { BYTE cmd[2]; BYTE i; output_low(EEPROM_DI); output_low(EEPROM_CLK); output_low(EEPROM_SELECT); cmd[0]=0xc0; cmd[1]=0x4; for(i=1;i<=5;++i) shift_left(cmd,2,0); output_high(EEPROM_SELECT); for(i=1;i<=11;++i) { output_bit(EEPROM_DI, shift_left(cmd,2,0)); output_high(EEPROM_CLK); output_low(EEPROM_CLK); } output_low(EEPROM_DI); output_low(EEPROM_SELECT); } void write_ext_eeprom(EEPROM_ADDRESS address, long data) { BYTE cmd[3]; BYTE i; cmd[0]=data; cmd[1]=(BYTE)address; cmd[2]=0xa|hi(address); for(i=1;i<=4;++i) shift_left(cmd,3,0); output_high(EEPROM_SELECT); for(i=1;i<=27;++i) { if(i==4) output_high(EEPROM_SELECT); output_bit(EEPROM_DI, shift_left(cmd,3,0)); output_high(EEPROM_CLK); output_low(EEPROM_CLK); } output_low(EEPROM_DI); output_low(EEPROM_SELECT); delay_ms(11); } BYTE read_ext_eeprom(EEPROM_ADDRESS address) { BYTE cmd[3]; BYTE i; long data; cmd[0]=0; cmd[1]=(BYTE)address; cmd[2]=0xc|hi(address); for(i=1;i<=4;++i) shift_left(cmd,3,0); output_high(EEPROM_SELECT); for(i=1;i<=27;++i) { output_bit(EEPROM_DI, shift_left(cmd,3,0)); output_high(EEPROM_CLK); output_low(EEPROM_CLK); if(i>11) shift_left(&data,1,input(EEPROM_DO)); } output_low(EEPROM_SELECT); return(data); } 这是对93LC66B、EEPROM16位的调用函数,请大家看看有什么问题,
1379
裸片初长成(中级)
Re: PIC CCS C语言程序范例
先 研究一下
1782
至上芯片
Re: PIC CCS C语言程序范例
好 顶 L  1
Re: PIC CCS C语言程序范例
