4409|1
569
windows下用ultraedit编辑verilog遇到的问题 [复制链接]
我现在准备用ultraedit编辑verilog,在wordfile中加入了如下代码,想得到自动缩进和代码折叠功能,但是现在不知道什么原因不能得到自己想要的功能,不能折叠也不能缩进,还请高人指点,不甚感激!!
/L14"verilog" Line Comment = // Block Comment On = /* Block Comment Off = */ String Chars = " File Extensions = V VMD
/Delimiters = ~!@%^&*()-+=|\/{}[]:;"<> ,        .?
/Function String = "%[a-z0-9]+[ ^t]+[a-z_0-9]+[ ^t]+("
/Indent Strings = "begin""case""fork" "if" "else"
/Unindent Strings = "end""endcase""join" "else"
/Open Fold Strings = "begin""case"
/Close Fold Strings = "end""endcase"
/C1
此帖出自FPGA/CPLD论坛
然后双击打开,在wordfile.txt内添加如下内容: /L15"VHDL" Line Comment = -- Nocase String Chars = " File Extensions = VHD VHO /Delimiters = ; (    )'<>=:+-/*|& /C1"VHDL reserved words" abs access after alias all and architecture array assert attribute begin block body buffer bus case component configuration constant disconnect downto else elsif end entity exit file for function generate generic group guarded if impure in inertial inout is label library linkage literal loop map mod  nand new next nor not null of on open or others out package port postponed procedure process pure range record register reject rem report return rol ror select severity signal shared sla sll sra srl subtype then to transport type  unaffected untis until use variable wait when while with  xnor xor /C2"VHDL attributes" active ascending ascending  base  delayed driving driving_value event  falling_edge high  image instance_name  last_active last_event last_value left leftof length low  path_name pos pred  quiet  reverse_range right rightof rising_edge simple_name stable succ  transaction  val value /C3"VHDL stings" " /C4"VHDL types" bit bit_vector boolean  character integer line natural positive real signed std_logic std_logic_vector string text time unsigned /C5"VHDL Procedures" endfile file_close file_open read readline write writeline 如果需要UltraEdit支持其他语言,可以到http://www.ultraedit.com/downloads/extras.html下载其他语言的wordfile.txt,然后自己添加进去就可以啦~   详情 回复 发表于 2010-10-25 15:21
6892
disconnect downto
file for function
map mod
variable
xnor xor
base
event
falling_edge
high
image instance_name
path_name pos pred
quiet
transaction
val value
/C3"VHDL stings"
/C4"VHDL types"
character
integer
line
natural
positive
real
text time
unsigned
endfile
read readline
write writeline
此帖出自FPGA/CPLD论坛
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
开源项目 更多>>
