3102|0
1379
裸片初长成(中级)
[单片机]DS1302读写程序 [复制链接]
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
uchar sec,min,hr;
sbit clk=P1^0;
sbit dat=P1^1;
sbit rst=P1^2;
sbit A0=ACC^0;
sbit A1=ACC^1;
sbit A2=ACC^2;
sbit A3=ACC^3;
sbit A4=ACC^4;
sbit A5=ACC^5;
sbit A6=ACC^6;
sbit A7=ACC^7;
sbit blue=P1^5;
sbit green=P1^6;
sbit red=P1^7;
void InputByte(uchar dd)//mcu to ds1302
     uchar i;
     ACC=dd;
     for(i=8;i>0;i--)
       dat=A0;
       clk=1;
       clk=0;
       ACC=ACC>>=1;
uchar OutputByte(void) //ds1302 to mcu
     uchar i;
     dat=1;
     for(i=8;i>0;i--)
        ACC=ACC>>1;
        A7=dat;
        clk=1;
        clk=0;
      return(ACC);
void Write(uchar addr,uchar num)
    rst=0;
    clk=0;
    rst=1;
    InputByte(addr);   // address
    InputByte(num);    //data
    clk=1;
    rst=0;
uchar Read(uchar addr)
    uchar dd=0;
    rst=0;
    clk=0;
    rst=1;
    InputByte(addr);
    dd=OutputByte();
    clk=1;
    rst=0;
    return(dd);
uchar ReadSec()
   uchar dd;
   dd=Read(0x81);
   return(dd);
uchar ReadMin()
   uchar dd;
   dd=Read(0x83);
   return(dd);
uchar ReadHr()
    uchar dd;
    dd=Read(0x85);
    return(dd);
uchar ReadWe()
    uchar dd;
    dd=Read(0x8b);
    return(dd);
uchar ReadDay()
    uchar dd;
    dd=Read(0x87);
    return(dd);
uchar ReadMn()
    uchar dd;
    dd=Read(0x89);
    return(dd);
uchar ReadYs()
    uchar dd;
    dd=Read(0x8d);
    return(dd);
void WriteSec(uchar num)
       Write(0x80,num);
void WriteMin(uchar num)
    Write(0x82,num);
void WriteHr(uchar num)
    Write(0x84,num);
void WriteDay(uchar num)
   Write(0x86,num);
void WriteMn(uchar num)
    Write(0x88,num);
void WriteWe(uchar num)
   Write(0x8a,num);
void WriteYs(uchar num)
    Write(0x8c,num);
void DisableWP(void)        //write data,read 0
   Write(0x8e,0x00);
void EnableWP(void)              //can'd write,read data
   Write(0x85,0x80);
   void delay()
   {uint i,j;
   for(i=0;i<1000;i++)
     for(j=0;j<40;j++){}
   void main(void)
DisableWP();
 WriteSec(0x00);
  WriteMin(0x57);
 WriteHr(0x10);
WriteDay(0x07);
WriteMn(0x06);
  WriteWe(0x02);
 WriteYs(0x05);
此帖出自单片机论坛
