关于Modelsim仿真Altera中LPM_ROM的问题 做的是功能仿真,总是提示以下错误: # ** Error: (vsim-7) Failed to open VHDL file "my_rom.hex" in rb mode. # No such file or directory. (errno = ENOENT) # Time: 0 ns Iteration: 0 Instance: /test_rom/uut/ip1/altsyncram_component # ** Fatal: (vsim-7) Failed to open VHDL file "my_rom.hex" in rb mode. # No such file or directory. (errno = ENOENT) # Time: 0 ns Iteration: 0 Process: /test_rom/uut/ip1/altsyncram_component/memory File: E:/programfiles/altera/90/quartus/eda/sim_lib/altera_mf.vhd # Fatal error in Process memory at E:/programfiles/altera/90/quartus/eda/sim_lib/altera_mf.vhd line 38968 # # HDL call sequence: # Stopped at E:/programfiles/altera/90/quartus/eda/sim_lib/altera_mf.vhd 38968 Subprogram read_my_memory # called from E:/programfiles/altera/90/quartus/eda/sim_lib/altera_mf.vhd 40690 Process memory
在网上看到,有人这样做:在ModelSim安装的目录下找到modelsim.ini文件,将其只读属性去掉,在vsim部分里添加一行 “Veriuser = D:/altera/quartus50/eda/mentor/modelsim/convert_hex2ver.dll”,保存文件,将只读属性改回来。当然, 这里的路径要改成实际上您Quartus的安装路径。其中的convert_hex2ver.dll就是把hex文件转换成ModelSim能认出来的ver文件的动态链接库文件; 我用这种方法尝试了,还是出现上面的提示错误,我用的是Quartus II9.0+Modelsim SE 6.4b,VHDL语言。是不是这种方法只是针对verilog语言的。
