3837|0
关于Hook ZwReadFile问题。 [复制链接]
NTSTATUS NewNtReadFile(
IN HANDLE  FileHandle,
    IN HANDLE  Event  OPTIONAL,
    IN PIO_APC_ROUTINE  ApcRoutine  OPTIONAL,
    IN PVOID  ApcContext  OPTIONAL,
    OUT PIO_STATUS_BLOCK  IoStatusBlock,
    OUT PVOID  Buffer,
    IN ULONG  Length,
    IN PLARGE_INTEGER  ByteOffset  OPTIONAL,
    IN PULONG  Key  OPTIONAL)
        NTSTATUS status = 0;
    CHAR aProcessName[PROCNAMELEN];
        ANSI_STRING ansiName;
        UNICODE_STRING un;
        IO_STATUS_BLOCK file_status;
        FILE_STANDARD_INFORMATION fpi;
        FILE_POSITION_INFORMATION psi;
        FILE_POSITION_INFORMATION tmp;
        PIO_STATUS_BLOCK pstat = NULL;
        PLARGE_INTEGER byteset = NULL;
        CHAR buf[10];
    ULONG len = 10;
        GetProcessName( aProcessName );
        if(0 != strncmp(aProcessName,"wordpad.exe",strlen("wordpad.exe")))
                return OldNtReadFile(FileHandle,Event,
            ApcRoutine,ApcContext,IoStatusBlock,Buffer,Length,ByteOffset,Key);
        status = ZwQueryInformationFile(FileHandle,&file_status,&tmp,
                sizeof(FILE_POSITION_INFORMATION),FilePositionInformation);
        ZwQueryInformationFile(FileHandle, &file_status, &fpi,
                sizeof(FILE_STANDARD_INFORMATION), FileStandardInformation);
        if(fpi.EndOfFile.LowPart == 37)
                if(KeGetCurrentIrql() != PASSIVE_LEVEL)
                        DbgPrint("Not PSSIVE_LEVEL\n");
                byteset = (PLARGE_INTEGER)ExAllocatePool(NonPagedPool,sizeof(LARGE_INTEGER));
                if(NULL == byteset)
                        DbgPrint("byteset err\n");
                psi = tmp;
                psi.CurrentByteOffset.LowPart = 20;
                status = ZwSetInformationFile(FileHandle,&file_status,&psi,
                ASSERT(KeGetCurrentIrql() == PASSIVE_LEVEL);
                  pstat = IoStatusBlock;
        //        DbgPrint("%d,%d\n",Buffer,buf);
                status = OldNtReadFile(FileHandle,NULL,
            NULL,NULL,pstat,buf,len,NULL,NULL);
                if(NT_SUCCESS(status))
                //        memcpy(buf,Buffer,6);
                        buf[9] = '\0';
                        DbgPrint(" %s \n",buf);
                else
                        DbgPrint(" ReadFile failed. \n");
                ZwSetInformationFile(FileHandle,&file_status,&tmp,
                if(NULL != byteset)
                        ExFreePool(byteset);
根据网上某大牛的Hook ZwCreteProcess文章,我改成Hook ZwReadFile。发现能Hook到,但是在进入我的NewReadFile里面后,用OldZwReadFile(系统的)读取文件某一部分内容,比如读取文件第20个字节后的10个字节。这时发现,用我定义的pstat,buf两个参数传进OldZwReadFile后,总是ZwReadFile失败。即这行语句:status = OldNtReadFile(FileHandle,NULL,
                        buf[9] = '\0';
                else
而换成系统传进的参数却可以成功:
            NULL,NULL,IoStatusBlock,Buffer,len,NULL,NULL);
                        buf[9] = '\0';
                else
本人也是才学驱动编程,搞了两天也没弄出所以然,不知哪位知道原因,不胜感谢。
