2681|1
这样写那里错了? [复制链接]
NTSTATUS
DriverEntry(IN PDRIVER_OBJECT pDriObj,IN PUNICODE_STRING pRegPath)
  //Attach Device
  status = IoAttachDevice(g_DevObj,&DevName,&g_OldDevObj);
NTSTATUS TdiCreateAddrComplate(IN PDEVICE_OBJECT pDevObj,IN PIRP Irp,IN PVOID Context){
      PIO_STACK_LOCATION Irps = IoGetCurrentIrpStackLocation(Irp);
      PIRP QueryIrp = (PIRP)Context;
      TDI_ADDRESS_INFO *pTai = (TDI_ADDRESS_INFO *)ExAllocatePool(NonPagedPool,sizeof    (TDI_ADDRESS_INFO_MAX));
      NTSTATUS status;
      if(pTai != NULL){
          PMDL pMdl = IoAllocateMdl(pTai,sizeof(TDI_ADDRESS_INFO_MAX),FALSE,FALSE,NULL);
          if (pMdl != NULL) {
          MmBuildMdlForNonPagedPool(pMdl);
          if (QueryIrp != NULL) {
        TdiBuildQueryInformation(QueryIrp,g_OldDevObj,Irps->FileObject,NULL,NULL,TDI_QUERY_ADDRESS_INFO,pMdl);
        status = IoCallDriver(g_OldDevObj,QueryIrp);//调用会蓝屏
    return status;
NTSTATUS TdiCreate(IN PDEVICE_OBJECT pDevObj,IN PIRP Irp){
  FILE_FULL_EA_INFORMATION *pEA = (FILE_FULL_EA_INFORMATION *)Irp->AssociatedIrp.SystemBuffer;
  PIRP QueryIrp;
  NTSTATUS status;
  if(pEA->EaNameLength == TDI_TRANSPORT_ADDRESS_LENGTH \
&& memcmp(pEA->EaName,TdiTransportAddress,TDI_TRANSPORT_ADDRESS_LENGTH) == 0){
QueryIrp = TdiBuildInternalDeviceControlIrp(TDI_QUERY_ADDRESS_INFO,g_OldDevObj,Irps->FileObject,NULL,NULL);
IoSkipCurrentIrpStackLocation(Irp);
IoSetCompletionRoutine(Irp,TdiCreateAddrComplate,QueryIrp,TRUE,TRUE,TRUE);
status = IoCallDriver(g_OldDevObj,,Irp);
  else{
          if(g_OldDevObj != NULL){
                status = IoCallDriver(g_OldDevObj,Irp);
        else{
        status = Irp->IoStatus.Status = STATUS_INVALID_PARAMETER;
        IoCompleteRequest (Irp, IO_NO_INCREMENT);
return status;
没有看出来什么地方写错了!呵呵!  详情 回复 发表于 2007-8-23 13:27
没有看出来什么地方写错了!呵呵!
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 11
