2867|2
串口通信编程问题 [复制链接]
请教下,在uclinux下面已经写好了我的串口1的驱动,移植到44b0下面了,串口0自带了驱动。现在的问题是,想不明白,怎么进行两台pc各接一个串口,一台发,一台收,中间的过程是怎么样的?帮忙看下啊。想昏了。
跟单片机差不多,无非就是打开一个串口,设置串口的属性,设置收发触发事件.  详情 回复 发表于 2007-8-27 21:32
79
Win32环境下COM口通信
      DCB dcb;  //
      COMMTIMEOUTS CommTimeouts1;
      DWORD dwEvtMask;
      OVERLAPPED hOverlapped;
      HANDLE hCOM;
      hCOM = CreateFile("COM1"
                       GENERIC_READ | GENERIC_WRITE,
                     0,     //comm devices must be opened w/exclusive-access
                     NULL,  //no security attrs
                     OPEN_EXISTING, // comm devices must use OPEN_EXISTING
                     FILE_FLAG_OVERLAPPED,     //not overlapped I/O
                     NULL   //hTemplate must be NULL for comm devices
      if (GlobalDataForm->hGPSCom == INVALID_HANDLE_VALUE)
        sprintf(Str,"打开GPS_COM错误代号%d",GetLastError());
        MessageBox(NULL,Str,"错误",MB_OK);
      else
        if (!GetCommState(GlobalDataForm->hGPSCom, &dcb))
          sprintf(Str,"获取GPS_COM状态错误代号%d",GetLastError());
        else
          dcb.BaudRate = 9600;        //波特率9600
          dcb.ByteSize = 8;           //8个数据位
          dcb.Parity = NOPARITY;      //没有校验
          dcb.StopBits = ONESTOPBIT;  //1个停止位
          if (!SetCommState(GlobalDataForm->hGPSCom, &dcb))
            sprintf(Str,"设置GPS_COM状态错误代号%d",GetLastError());
          else
            if (!GetCommTimeouts(GlobalDataForm->hGPSCom,&CommTimeouts1))
              sprintf(Str,"获取GPS_COM超时状态错误,错误代号%d",GetLastError());
            else
              //CommTimeouts1.ReadIntervalTimeout=0xffffffff;
              CommTimeouts1.ReadTotalTimeoutConstant=100;
              if (!SetCommTimeouts(GlobalDataForm->hGPSCom,&CommTimeouts1))
                sprintf(Str,"设置GPS_COM超时状态错误,错误代号%d",GetLastError());
              else
                /*if (!SetCommMask(GlobalDataForm->hGPSCom,EV_DSR))
                  sprintf(Str,"设置GPS_COM屏蔽状态错误,错误代号%d",GetLastError());
                else
                  hOverlapped.hEvent=CreateEvent(NULL,
                                                 FALSE,
                                                 FALSE,
                                                 NULL
                  assert(hOverlapped.hEvent);
                  if (WaitCommEvent(GlobalDataForm->hGPSCom,&dwEvtMask,&hOverlapped))
                  //  sprintf(Str,"等待GPS_COM通信事件错误,错误代号%d",GetLastError());
                  //  MessageBox(NULL,Str,"错误",MB_OK);
                  //else
                    if (dwEvtMask & EV_DSR)
                      MessageBox(NULL,"GPS数据准备好","提示",MB_OK);
                mrAnswer=IDOK;
                GlobalDataForm->mGPSCom=true;
      break;
/*      DCB dcb;
      DWORD dwEvtMask;
      GlobalDataForm->hGPSCom = CreateFile(GlobalDataForm->GPSComName,
                            0,    // comm devices must be opened w/exclusive-access
                            NULL, // no security attrs
                            OPEN_EXISTING, /* comm devices must use OPEN_EXISTING
                            0,    // not overlapped I/O
                            NULL  // hTemplate must be NULL for comm devices
      else
        else
          else
              sprintf(Str,"获取超时状态错误,错误代号%d",GetLastError());
            else
                sprintf(Str,"设置超时状态错误,错误代号%d",GetLastError());
              else
                mrAnswer=IDOK;
      break;*/
    case mOFF:{
      GlobalDataForm->mGPSCom=false;
      CloseHandle(GlobalDataForm->hGPSCom);
      mrAnswer=IDOK;
      break;
78
