2949|1
55
CEPC选择"Enable Kernel Debugger"后出现错误 [复制链接]
1.我用CEPC创建了一个工程,但是发现使用KITL和"Enable Full Kernel Mode"项后,是可以启动的
2.增加"Enable Kernel Debugger"项后,CEPC无法起来
  弹出"The Debugger KITL packet receive has timed out. Do you wish to retry?"
  同时在串口中输出如下的信息:
VBridge:: VB_INITIALIZED returns [1]
nit()...TX = [16384] bytes -- Rx = [16384] bytes
x buffer [0xA20AA200] to [0xA20AE200].
RTL8139:: MulticastRegs set to : 0-0-0-0-0-0-0-0
RTL8139:: Set Ndis filter [0xB] -> [0x101E]
VBridge:: Current VMini packet filter = [0xB]
Bad RX packet [Header: 0x6F55 -- Length : [65520]]...
0x83e70938: Exception 00e Thread=83e70938 Proc=c3ea9852 ''
0x83e70938: AKY=ffffffff PC=802a9606(NK.EXE+0x00089606) ESP=c205f44c
EA=c2060000
0x83e70938: Recursively calling KDEnableInt(FALSE, psvdThread != NULL) 1
time(s). This OK if KdStub stumbling on its own BP.
  KdTrap: Exception in debugger, Addr=0x802A9606 -  attempting to recover
  KdTrap: Exception in debugger, Addr=0x802A9606 -  unable to recover
0x83e70938:
Unhandled exception c0000005:
0x83e70938: Terminating thread 83e70938
0x83e70938: Secondary thread in proc c3ea9852 (gwes.exe) faulted!
0x83e70938: <<< Unloading module coredll.dll at address
0x03F50000-0x03FF3000 (RW data at 0x01FFE000-0x01FFF765)
  KdTrap: Exception in debugger, Addr=0x802601B3 -  attempting to recover
  KdTrap: Exception in debugger, Addr=0x802601B3 -  unable to recover
我目标机器上的网卡是RTL8139
大侠们,帮帮忙呀  详情 回复 发表于 2007-7-4 22:43
66
大侠们,帮帮忙呀
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
第2场直播:融合热仿真与热测试提升产品可靠性
直播时间:04月17日 14:00 - 15:00
