2729|1
78
请帮助看一下下面的代码,不知道是什么意思??谢谢,最好可以帮助注释一下 [复制链接]
为2410BOOTLODER中的一端代码
ResetEntry
        ;1)The code, which converts to Big-endian, should be in little endian code.
        ;2)The following little endian code will be compiled in Big-Endian mode.
        ;  The code byte order should be changed as the memory bus width.
        ;3)The pseudo instruction,DCD can't be used here because the linker generates error.
        ASSERT        :DEF:ENDIAN_CHANGE ;报告指示符号
        [ ENDIAN_CHANGE
            ASSERT  :DEF:ENTRY_BUS_WIDTH ;判断某个符号是否定义
            [ ENTRY_BUS_WIDTH=32
                        b        ChangeBigEndian            ;DCD 0xea000007
            [ ENTRY_BUS_WIDTH=16
                andeq        r14,r7,r0,lsl #20   ;DCD 0x0007ea00
            [ ENTRY_BUS_WIDTH=8
                streq        r0,[r0,-r10,ror #1] ;DCD 0x070000ea
        b        ResetHandler
        b        HandlerUndef        ;handler for Undefined mode
        b        HandlerSWI                ;handler for SWI interrupt
        b        HandlerPabort        ;handler for PAbort
        b        HandlerDabort        ;handler for DAbort
        b        .                                ;reserved
        b        HandlerIRQ                ;handler for IRQ interrupt
        b        HandlerFIQ                ;handler for FIQ interrupt
;@0x20
        b        EnterPWDN
ChangeBigEndian
;@0x24
            DCD        0xee110f10        ;0xee110f10 => mrc p15,0,r0,c1,c0,0
            DCD        0xe3800080        ;0xe3800080 => orr r0,r0,#0x80;  //Big-endian
            DCD        0xee010f10        ;0xee010f10 => mcr p15,0,r0,c1,c0,0
            DCD 0x0f10ee11
            DCD 0x0080e380
            DCD 0x0f10ee01
        [ ENTRY_BUS_WIDTH=8
            DCD 0x100f11ee
            DCD 0x800080e3
            DCD 0x100f01ee
        DCD 0xffffffff  ;swinv 0xffffff is similar with NOP and run well in both endian mode.
        DCD 0xffffffff
        DCD 0xffffffff
        DCD 0xffffffff
        DCD 0xffffffff
        b ResetHandler
ASSERT :DEF:ENDIAN_CHANGE [ ENDIAN_CHANGE      ASSERT  :DEF:ENTRY_BUS_WIDTH      [ ENTRY_BUS_WIDTH=32   b ChangeBigEndian     ;DCD 0xea000007      ]            [ ENTRY_BUS_WIDTH=16   andeq r14,r7,r0,lsl #20   ;DCD 0x0007ea00      ]            [ ENTRY_BUS_WIDTH=8   streq r0,[r0,-r10,ror #1] ;DCD 0x070000ea      ] |      b ResetHandler   ] 1、ASSERT :DEF:ENDIAN_CHANGE ASSERT 是断言伪指令,语法是:ASSERT +逻辑表达式 def 是逻辑伪操作符,格式为: :DEF:label,作用是:判断label是否定义过 2、四句蓝色的指令能且只能执行一句,并且前三句若执行跳转后处理程序的最后一句也是 b ResetHandler   3、" [ " 相当于 if       " | "相当于else       " ] " 相当于endif   详情 回复 发表于 2008-9-17 08:56
63
[ ENDIAN_CHANGE
     [ ENTRY_BUS_WIDTH=8
     b ResetHandler
b ResetHandler
3、" [ " 相当于 if
      " | "相当于else
      " ] " 相当于endif
