3621|4
75
WINCE中调用connect函数出错 [复制链接]
char *sIp="192.168.11.105";
        int nPort = 3000;
        int rc;
        WSADATA  wsaData;
        //SOCKET nConnect;
        sockaddr_in  sAddr;
        struct hostent *nhost=NULL;
        rc = WSAStartup( MAKEWORD(2 ,2 ), &wsaData );
        if( rc != 0 ){
                AfxMessageBox( TEXT("WSAStartup Error" ) );
                return;
        BYTE lb = LOBYTE( wsaData.wVersion );
        BYTE hb = HIBYTE( wsaData.wVersion );
        if( LOBYTE( wsaData.wVersion ) != 2 || HIBYTE( wsaData.wVersion ) != 2 ) {
                /* Tell the user that we could not find a usable */
                /* WinSock DLL.                                  */
                AfxMessageBox(TEXT("WSAStartup Version Error" ) );
                WSACleanup( );
                return;
        int nsock = socket (AF_INET, SOCK_STREAM, IPPROTO_TCP);
        if( nsock == INVALID_SOCKET ){
                AfxMessageBox(TEXT("socket  Error" ) );
                WSACleanup( );
                return;
        memset( &sAddr , 0 , sizeof( sAddr ) );
        sAddr.sin_family = AF_INET;
        sAddr.sin_port = htons( nPort );
        sAddr.sin_addr.s_addr = inet_addr(sIp );
        if( sAddr.sin_addr.s_addr == INADDR_NONE ){
      nhost = gethostbyname(sIp);
      if( nhost == NULL ){
        //return -2;
                AfxMessageBox(TEXT("gethostbyname  Error" ) );
                WSACleanup( );
                return;
      CopyMemory(&sAddr.sin_addr,nhost->h_addr_list[0],nhost->h_length);
        rc = connect( nsock , (struct sockaddr *)&sAddr , sizeof( sAddr ) );
        if( rc == SOCKET_ERROR ){
                AfxMessageBox(TEXT("connect  Error" ) );
                DWORD x = WSAGetLastError();
                CString s;
                s.Format(L"LastError=[%d]" , x );
                AfxMessageBox( s );
                WSACleanup( );
                return;
        closesocket( nsock );
        WSACleanup();
        AfxMessageBox( L"Connect Ok!" ) ;
以上是我的部分代码,程序在虚拟机中可以运行通过,但是在PPC机上,运行到connect的时候,将报错,出错代码是120,请问一下,这是怎么回事?
我解决了,不是你们说的原因。  详情 回复 发表于 2007-4-5 14:47
现在去注册米鼠会员
参加趣味问答就能拿积分
米鼠积分可以直接够买东西哦    1积分=1RMB
网址:www.mylinux.com.cn
66
SOCKET类型为什么要搞成int型呢,起码也是个UINT吧.
程序基本上没多大问题.
我解决了,不是你们说的原因。
