2520|2
59
这是写usb驱动,??????的一行该怎么写
int installDev() {
        DevDelete("USB Network Interface"); //delete unknow device first
    if (OS_VERSION == OS_WIN98) {
        //MessageBox(NULL,"WIN98 OS","Debug",0);
            if (CopyFileWin9x(".\\usb8023w.sys",".\\rndismpw.sys"));
          //MessageBox(NULL,"The Usb Driver have been installed","Install successfully",0);
        else if (OS_VERSION == OS_WINME) {
          if (CopyFileWin9x(".\\usb8023m.sys",".\\rndismpm.sys"));
        else if (OS_VERSION == OS_WINNT) {
          if (SetupCopyOEMInf(".\\bcmdslur.inf",NULL,SPOST_PATH,0,NULL,0,NULL,NULL));
        else if (OS_VERSION == OS_VISTA) {
        else
         //MessageBox(NULL,"Not Support to install automatically in this OS,please install manually","Install unsuccessfully",0);
    return 0;
解决了  谢谢  详情 回复 发表于 2007-3-28 00:05
85
找vista的DDK看。
82
解决了  谢谢
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
