3417|0
77
请问,.net如何将csv文件直接读入dataSet [复制链接]
wince下没有odbc包,以下代码无法运行
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        Dim strConn As String
        Dim strSql As String = "select * from" + " 1.csv"
        Dim objConn As OdbcConnection
        Dim dataSet As DataSet = New DataSet
        Dim dataRow As DataRow
        Dim odbcCSVDataAdapter As New OdbcDataAdapter
        dataSet.Tables.Add(New DataTable())
        strConn = "Driver={Microsoft Text Driver (*.txt; *.csv)};Dbq="
        strConn += "e:\"
        strConn += ";Extensions=asc,csv,tab,txt;"
        objConn = New OdbcConnection(strConn)
        odbcCSVDataAdapter = New OdbcDataAdapter(strSql, objConn)
        odbcCSVDataAdapter.Fill(dataSet.Tables(0))
    End Sub
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
