6113|5
82
获得的设备描述符的idVendor, idProduct,bcdDevice的值老是变化的。 [复制链接]
每次读到的都不一样。怎么会这样啊。ddk下的。其他地方都没有改,就在FilterDispatchPnp中添加一段代码来获得设备描述符。但是问题如标题。每次运行
DebugPrint出来的idVendor, idProduct,bcdDevice的值老是变化的。
具体代码如下
NTSTATUS
FilterDispatchPnp (
    __in PDEVICE_OBJECT DeviceObject,
    __in PIRP Irp
Routine Description:
    The plug and play dispatch routines.
    Most of these the driver will completely ignore.
    In all cases it must pass on the IRP to the lower driver.
Arguments:
   DeviceObject - pointer to a device object.
   Irp - pointer to an I/O Request Packet.
Return Value:
      NT status code
    PDEVICE_EXTENSION           deviceExtension;
    PIO_STACK_LOCATION         irpStack;
    NTSTATUS                            status;
    KEVENT                               event;
        PURB pUrb = NULL;
        PUSB_DEVICE_DESCRIPTOR deviceDescriptor = NULL;
        ULONG dwSize;
        NTSTATUS Status = STATUS_SUCCESS;
        LARGE_INTEGER RunTime;
        KEVENT Event;
        IO_STATUS_BLOCK IoStatus;
        PIO_STACK_LOCATION NextStack;
        PIRP newIrp;
        USHORT myidVendor;
    PAGED_CODE();
    deviceExtension = (PDEVICE_EXTENSION) DeviceObject->DeviceExtension;
    irpStack = IoGetCurrentIrpStackLocation(Irp);
    //DbgPrint(("FilterDO %s IRP:0x%p \n",
    //            PnPMinorFunctionString(irpStack->MinorFunction), Irp));
   status = IoAcquireRemoveLock (&deviceExtension->RemoveLock, Irp);
    if (!NT_SUCCESS (status)) {
        Irp->IoStatus.Status = status;
        IoCompleteRequest (Irp, IO_NO_INCREMENT);
        return status;
        // Added         by me
        pUrb = (PURB)ExAllocatePool(NonPagedPool, sizeof(struct _URB_CONTROL_DESCRIPTOR_REQUEST));
        if(pUrb)
                //DbgPrint("URB OK\n");
                dwSize = sizeof(USB_DEVICE_DESCRIPTOR);
                deviceDescriptor = (PUSB_DEVICE_DESCRIPTOR)ExAllocatePool(NonPagedPool, dwSize);
                if(deviceDescriptor)
                        //DbgPrint("DeviceDescriptor OK\n");
                        UsbBuildGetDescriptorRequest(pUrb,
                                (USHORT)sizeof(struct _URB_CONTROL_DESCRIPTOR_REQUEST),
                                USB_DEVICE_DESCRIPTOR_TYPE,
                                0,
                                0,
                                deviceDescriptor,
                                NULL,
                                dwSize,
                                NULL);
                        RunTime.QuadPart = -2000 * 10;
                        KeInitializeEvent(&Event, NotificationEvent, FALSE);
                        newIrp = IoBuildDeviceIoControlRequest(IOCTL_INTERNAL_USB_SUBMIT_URB,
                                DeviceObject,
                                NULL,
                                0,
                                NULL,
                                0,
                                TRUE,
                                &Event,
                                &IoStatus);
                        NextStack = IoGetNextIrpStackLocation(newIrp);
                        NextStack->Parameters.Others.Argument1 = pUrb;
                        //DbgPrint("Before Call\n");
                        Status = IoCallDriver(DeviceObject, newIrp);
                        if(Status == STATUS_PENDING)
                                DbgPrint("Pending\n");
                                Status = KeWaitForSingleObject(
                                        &Event,
                                        Suspended,
                                        KernelMode,
                                        FALSE,
                                        &RunTime);
                                if(Status == STATUS_TIMEOUT)
                                        DbgPrint("Cancel\n");
                                        Status = STATUS_UNSUCCESSFUL;
                                        IoCancelIrp(newIrp);
                                                &Event,
                                                Suspended,
                                                KernelMode,
                                                FALSE,
                                                NULL);
                        DbgPrint(" idVendor: %d, bcdDevice:%d, idProduct:%d\n", deviceDescriptor->idVendor,deviceDescriptor->bcdDevice,deviceDescriptor->idProduct);
                        DbgPrint(" bDeviceClass: %d,bDeviceSubClass:%d\n",deviceDescriptor->bDeviceClass,deviceDescriptor->bDeviceSubClass);
                        myidVendor = deviceDescriptor->idVendor;
                        ExFreePool(deviceDescriptor);
                else
                        Status = STATUS_NO_MEMORY;
                        ExFreePool(pUrb);
        else
        DbgPrint("Return\n");
        // End of addition
    switch (irpStack->MinorFunction) {
    case IRP_MN_START_DEVICE:
help.不然帖子要沉了  详情 回复 发表于 2007-8-8 09:06
这个是ddk vista 6000版本的一个toast例子中的,我只是改写filter.c中的这段想获得设备描述符。
67
全国第一家虚拟主机:支持伪静态.有利于提高排名!!!
15G全能空间年付500元/月付70元 可免费试用
5GB 独立WEB空间、5GB 企业邮箱空间、5GB MSSQL数据库
IIS连接数据 500 个、500GB/月流量、共享日志文件空间
企业邮箱功能
赠送5GB 超大企业邮箱,500个Email企业邮箱用户
自动回复、自动转发、POP3、SMTP收发信、SMTP发信认证
邮件过滤、邮件拒收、邮件夹管理、邮件域管理、定制邮件数
数据库功能
支持5GB MSSQL数据库空间,5个用户数据库、Access
主机功能支持
采用安全稳定的Win2003 .net2.0 架构
支持ASP、PHP、ASP.NET、PERL等脚本、支持自定义CGI
全面支持.net2.0版本,独立的Application应用池,
支持SSI(Shtml),支持FrontPage扩展
可免费自行绑定5个域名、500个解析、500个子域名
详情咨询021-51695858   QQ:678500
官方网站  www.abcnic.com
ADD:上海市浦东新区金桥浙桥路289号建银大厦A座703-704
晕啊,我提问的帖怎么被人灌水啊。真是无语。各位兄弟请帮助啊。不吝赐教,非常感激了。
79
各位兄弟,给个建议。
help.不然帖子要沉了
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 11
