2424|1
请大虾们帮忙 [复制链接]
1.  What does diagnostics test?generally?cover?
A. ASIC
B. Memory
C. Component
D. Data Path
E. All of the above
2.  If ASIC, component A, transmits data to ASIC, component B, an error occurred.
A. 50% component A, 50% component B
B. Component A has higher failure probability
C. Component B has higher failure probability
3. What is?the most effective parametric test corner?
A. High temperature / high voltage
B. Low temperature / low voltage
C. Low temperature / high voltage
D. High temperature / low voltage
这个怎么看像是ASIC设计的笔试题? 1. E 2. A 3. D   详情 回复 发表于 2008-6-15 20:36
这个怎么看像是ASIC设计的笔试题?
1. E
2. A
3. D
