2700|1
【紧急求助】 xilinx cordic ip 核 仿真时遇到的问题 [复制链接]
我用cordic 核实现开方功能,但是用modelsim  仿真的时候输出一直是蓝线,提示很多很多warning
# Loading work.sqare_test_tb
# Loading work.square_test
# Loading D:\X\ISE\verilog\mti_se\XilinxCoreLib_ver.C_REG_FD_V7_0
# Loading D:\X\ISE\verilog\mti_se\XilinxCoreLib_ver.C_SHIFT_RAM_V7_0
# Loading D:\X\ISE\verilog\mti_se\XilinxCoreLib_ver.C_ADDSUB_V7_0
# Loading D:\X\ISE\verilog\mti_se\XilinxCoreLib_ver.C_MUX_BIT_V7_0
# Loading D:\X\ISE\verilog\mti_se\unisims_ver.LUT4
# Loading D:\X\ISE\verilog\mti_se\unisims_ver.BUF
# Loading work.glbl
# ** Warning: (vsim-3017) square.v(872): [TFMPC] - Too few port connections. Expected 10, found 4.
#         Region: /sqare_test_tb/uut/YourInstanceName/BU20
# ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'SINIT'.
# ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'SSET'.
# ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'SCLR'.
# ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'AINIT'.
# ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'ASET'.
# ** Warning: (vsim-3722) square.v(872): [TFMPC] - Missing connection for port 'CE'.
# ** Warning: (vsim-3017) square.v(902): [TFMPC] - Too few port connections. Expected 10, found 4.
#         Region: /sqare_test_tb/uut/YourInstanceName/BU89
# ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'SINIT'.
# ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'SSET'.
# ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'SCLR'.
# ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'AINIT'.
# ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'ASET'.
# ** Warning: (vsim-3722) square.v(902): [TFMPC] - Missing connection for port 'CE'.
# ** Warning: (vsim-3017) square.v(932): [TFMPC] - Too few port connections. Expected 10, found 4.
另请教高手们,我现在要实现的算法,好像不大容易避免开方,有没有别的办法实现开方 或者 对一个复数求模值呢
warning
cordic 核的设置1
cordic 核的设置2
cordic 核的设置3
cordic 核的设置4
modeisim 仿真
[url=][/url]
warning
此帖出自FPGA/CPLD论坛
讲的非常好,看了收获很多,十分感谢   详情 回复 发表于 2020-9-20 12:46
78
讲的非常好,看了收获很多,十分感谢
此帖出自FPGA/CPLD论坛
