3026|3
刚装的WinCE,用PB编译模拟器时找不着WZCDeleteIntfObjEx等? [复制链接]
刚装的WinCE,用PB编译模拟器时找不着WZCDeleteIntfObjEx等,WZCDeleteIntfObjEx在哪个文件里有啊?
出错内容:
wzctool.lib(wzctool.obj) : error LNK2019: unresolved external symbol _WZCDeleteIntfObjEx referenced in function "void __cdecl DoQueryCache(unsigned short *)" (?DoQueryCache@@YAXPAG@Z)
wzctool.lib(wzctool.obj) : error LNK2019: unresolved external symbol _WZCQueryInterfaceEx referenced in function "void __cdecl DoQueryCache(unsigned short *)" (?DoQueryCache@@YAXPAG@Z)
wzctool.lib(wzctool.obj) : error LNK2019: unresolved external symbol _WZCSetInterfaceEx referenced in function "void __cdecl AddToPreferredNetworkList(unsigned short *,struct WZC_WLAN_CONFIG &,unsigned short *)" (?AddToPreferredNetworkList@@YAXPAGAAUWZC_WLAN_CONFIG@@0@Z)
wzctool.lib(wzctool.obj) : error LNK2019: unresolved external symbol _WZCRefreshInterfaceEx referenced in function "void __cdecl DoRefreshWzc(int,unsigned short * * const)" (?DoRefreshWzc@@YAXHQAPAG@Z)
C:\WINCE500\PBWorkspaces\cn_simu\WINCE500\Emulator_x86\cesysgen\oak\target\x86\retail\wzctool.exe : fatal error LNK1120: 4 unresolved externals
NMAKE : fatal error U1077: 'link' : return code '0x460'
Stop.
NMAKE : fatal error U1077: 'C:\WINCE500\sdk\bin\i386\nmake.exe' : return code '0x2'
Stop.
此帖出自WindowsCE论坛
嗯,把WIFI干掉就没这些错误了 不过以后要用到wifi岂不是又麻烦了:(  详情 回复 发表于 2008-9-23 10:35
75
零分的帖子,偶只会路过
此帖出自WindowsCE论坛
估计你是多选了Wireless的组件。
此帖出自WindowsCE论坛
嗯,把WIFI干掉就没这些错误了
此帖出自WindowsCE论坛
