2267|0
81
WINCE60 编译错误 [复制链接]
我按参考文献安装了: VC2005 + SP1, WINCE60 + SP1, EMULATOR2。0 , NETWORK MACHINE, ACTIVESYN。。
在安装WINCE6。0 时候我只选了 ARMV41, 没有选 X86。
然后创建 OS工程,第一个BSP 选 EMULATOR ARMV41,编译运行很好。
但是我加上了第三方BSP(是基于X86的, MY BSP:X86)后,从CATALOG中选上。这样上面的工程中可以选 MY BSP Release 进行编译,却出错。
错误文件 BUILD。LOG 如下:
Starting sysgen phase for project ( common )
Found localized resources for Languages ()
Microsoft (R) Program Maintenance Utility Version CE-6.00.1893.0
Copyright (C) Microsoft Corporation.  All rights reserved.
Windows CE Version (Release) (Built on Jun 30 2006 16:52:46)
makefile.def: Invoked with predefined settings:
TARGETNAME: dummy
TARGETTYPE: dummy
RELEASETYPE:
TARGETLIBS:
SOURCELIBS:
makefile.def: Including E:\program_files\public\common\oak\misc\Sources.default
makefile.def: BUILDROOT is E:\program_files\public\common\cesysgen
makefile.def: Including E:\program_files\PUBLIC\COMMON\CESYSGEN\sources
makefile.def: Including E:\program_files\public\common\oak\misc\Sources.CE
Directory: E:\program_files\PUBLIC\COMMON\CESYSGEN
TARGETNAME: dummy
RELEASETYPE is not defined.  Using DEFAULT.
makefile.def: Including E:\program_files\public\common\oak\misc\sources.ReleaseType_DEFAULT
Creating appropriate directories and deleting COMMON.LOC
        mkdir E:\program_files\public\common\oak\lib\x86\retail\0409 > nul 2>&1
Copying resources to E:\program_files\public\common\oak\lib\x86\retail\oak\lib\x86\retail\0409
        for %f in (E:\program_files\public\common\oak\lib\x86\retail\*.res) do NMAKE /nologo %~df%~pf0409\%~nf%~xf > nul
NMAKE : fatal error U1077: 'for' : return code '0x35148'
Stop.
我该怎么办啊。。。安装了 MY BSP :X86 后。自己要新创建OSDesign的话,却没有 MY bsp 可以做平台选择。。是不是我要重新安装 WINCE6。0 把 X86也选上?  可是象我上面那样,不选也应该可以啊。为什么编译出错啊。。
请高人指点一二。
此帖出自WindowsCE论坛
