3656|3
如何用directsound实现音量调节 [复制链接]
如题。期待高手指点!
有点难度哦  详情 回复 发表于 2008-5-1 04:48
62
  1. if (S_OK == CoInitializeEx(NULL, COINIT_MULTITHREADED))
  2.         {
  3.                 RETAILMSG(DBGMSGON, (_T("\n\tInitializes the Component Object Model (COM)...OK\n")));
  4.         }
  5.         if(MMSYSERR_NOERROR == waveOutSetVolume(0, 0xffffffff))
  6.         {//设置系统音量
  7.                 RETAILMSG(DBGMSGON, (_T("MySystem Volume set...ok\n")));
  8.         }
  9.         if (S_OK == CoCreateInstance(CLSID_FilterGraph, NULL, CLSCTX_INPROC, IID_IGraphBuilder, (void **)&pGraph))
  10.         {
  11.                 RETAILMSG(DBGMSGON, (_T("\tCoCreateInstance ...OK\n\n")));
  12.         }
  13.         else
  14.         {
  15.                 RETAILMSG(DBGMSGON, (_T("\tCoCreateInstance ...failed\n\n")));
  16.                 return FALSE;
  17.         }
  18.         if(pGraph->QueryInterface(IID_IMediaControl, (void **)&pMediaControl) != NOERROR)
  19.         {
  20.                 RETAILMSG(DBGMSGON, (_T("QueryInterface IMediaControl failed")));
  21.                 return FALSE;
  22.         }
  23.         if(pGraph->QueryInterface(IID_IBasicAudio, (void **)&m_pBA) != NOERROR)
  24.         {//
  25.                 RETAILMSG(DBGMSGON, (_T("QueryInterface IBasicVideo failed")));
  26.                 return FALSE;
  27.         }
  28.         if(pGraph->QueryInterface(IID_IMediaEventEx, (void **)&m_pME) != NOERROR)
  29.         {
  30.                 RETAILMSG(DBGMSGON, (_T("QueryInterface IMediaEvent failed")));
  31.                 return FALSE;
  32.         }
  33.         m_pBA->put_Volume(lVolume);//-10000...0
  34.         m_pBA->put_Balance(lBalance);//-10000...0...10000
复制代码
省略了很多
79
如何拖动滑块,改变音量呢?
有点难度哦
