2533|2
75
驱动开发 [复制链接]
如何向一个寄存器的某一位写值呢?
我在开发一个led的驱动,用2440的cpu,将这个led接在一个gpio口上,用寄存器的某一位控制led的关灭,但是没成功,希望哪位大侠能给我提点建议,小弟万分感谢!
CE下 #include "stdafx.h" #include "KEY.h" volatile IOPreg         *s2440IOP = (IOPreg *)IOP_BASE; HANDLE hthread; DWORD KeyThread(LPVOID lpParameter); BOOL APIENTRY DllMain( HANDLE hModule,                        DWORD  ul_reason_for_call,                        LPVOID lpReserved                                          ) {     switch (ul_reason_for_call)         {                case DLL_PROCESS_ATTACH:                 RETAILMSG(1,(TEXT("STRINGS:DLL_PROCESS_ATTACH\n")));                   return TRUE;         case DLL_THREAD_ATTACH:          RETAILMSG(1,(TEXT("STRINGS:DLL_THREAD_ATTCH\n")));                  break;         case DLL_THREAD_DETACH:         RETAILMSG(1,(TEXT("STRINGS:DLL_THREAD_DETACH\n")));                  break;         case DLL_PROCESS_DETACH:                 RETAILMSG(1,(TEXT("STRINGS:DLL_PROCESS_DETACH\n")));                  break;                             }     return TRUE; } // This is an example of an exported variable KEY_API int nKEY=0; // This is an example of an exported function. KEY_API int fnKEY(void) {         return 42; } KEY_API DWORD KEY_Init(DWORD dwContext) {         DWORD dwRet=0;         RETAILMSG(1,(TEXT("MYSTRINGS:KEY_Init********\n")));         dwRet=1;     s2440IOP->rGPFCON&=~(3  详情 回复 发表于 2008-7-25 22:35
123
你这个好象是单片机的用法??
66
CE下
#include "stdafx.h"
#include "KEY.h"
HANDLE hthread;
                       LPVOID lpReserved
                  return TRUE;
                 break;
                 break;
                 break;
    return TRUE;
KEY_API int nKEY=0;
        return 42;
        DWORD dwRet=0;
        dwRet=1;
    s2440IOP->rGPFCON&=~(3<<14); //控制LED的亮灭进行初始化
    s2440IOP->rGPFCON|=(1<<14);
    s2440IOP->rGPFUP&=~(1<<7);
    s2440IOP->rGPFUP|=1<<7;
    hthread=CreateThread(NULL,NULL,KeyThread,NULL,CREATE_SUSPENDED,NULL);
                          //创建一个线程,并挂起,传入的地址可用this
    ResumeThread(hthread);  //恢复运行
        return dwRet;
KEY_API BOOL KEY_Deinit(DWORD hDeviceContext)
  BOOL bRet=TRUE;
  RETAILMSG(1,(TEXT("MYSTRINGS:KEY_Deinit\n")));
  TerminateThread(hthread,0);//线程直接终止,但不会通过return 0退出,而是直接终//止
  return bRet;
KEY_API DWORD KEY_Open(DWORD hDeviceContext,DWORD AccessCode,DWORD ShareMode)
        DWORD dwRet=0;
        RETAILMSG(1,(TEXT("MYSTRINGS:KEY_Open\n")));
        dwRet=1;
        return dwRet;
KEY_API BOOL KEY_Close(DWORD hOpenContext)
        BOOL bRet=TRUE;
        RETAILMSG(1,(TEXT("MYSTRINGS:KEY_Close\n")));
        return bRet;
KEY_API BOOL KEY_IOControl(DWORD hOpenContext,
                                   DWORD dwCode,
                                   PBYTE pBufIn,
                                   DWORD dwLenIn,
                                   PBYTE pBufOut,
                                   DWORD dwLenOut,
                                   PDWORD pdwActualOut
        BOOL bRet=TRUE;
        RETAILMSG(1,(TEXT("MYSTRINGS:KEY_IOControl\n")));
        return bRet;
KEY_API void KEY_PowerDown(DWORD hDeviceContext)
        RETAILMSG(1,(TEXT("MYSTRINGS:KEY_PowerDown\n")));
KEY_API void KEY_PowerUp(DWORD hDeviceContext)
    RETAILMSG(1,(TEXT("MYSTRINGS:KEY_PowerUp\n")));
KEY_API DWORD KEY_Read(DWORD hOpenContext,LPVOID pBuffer,DWORD Count)
        DWORD dwRet=0;
    RETAILMSG(1,(TEXT("MYSTRINGS:KEY_Read\n")));
        return dwRet;
KEY_API DWORD KEY_Seek(DWORD hOpenContext,long Amount,DWORD Type)
        DWORD dwRet=0;
    RETAILMSG(1,(TEXT("MYSTRINGS:KEY_Seek\n")));
        return dwRet;
KEY_API DWORD KEY_Write(DWORD hOpenContext,LPCVOID pSourceBytes,DWORD NumberOfBytes)
        DWORD dwRet=0;
    RETAILMSG(1,(TEXT("MYSTRINGS:KEY_Write\n")));
    return dwRet;
//key thread
        BOOL bit=0;
        while(1)
          Sleep(2000);
          if(bit)                       //LED在线跟里亮与灭交替进行
          {s2440IOP->rGPFDAT|=1<<7;
              RETAILMSG(1,(TEXT("test fhg\n")));
                  keybd_event ('4',0,0,0);
          else
                  s2440IOP->rGPFDAT&=~(1<<7);
                      RETAILMSG(1,(TEXT("kill fhg\n")));
                          keybd_event ('6',0,0,0);
          bit=~bit;
        return 0;
// This is the constructor of a class that has been exported.
// see KEY.h for the class definition
CKEY::CKEY()
        return;
