4316|6
86
S3C2440A_IOPORT_REG 中每个字段的含义是什么? [复制链接]
  1. typedef struct {
  2.     UINT32 GPACON;                  // Port A - offset 0
  3.     UINT32 GPADAT;                  // Data
  4.     UINT32 PAD1[2];
  5.     UINT32 GPBCON;                  // Port B - offset 0x10
  6.     UINT32 GPBDAT;                  // Data
  7.     UINT32 GPBUP;                   // Pull-up disable
  8.     UINT32 PAD2;
  9.     UINT32 GPCCON;                  // Port C - offset 0x20
  10.     UINT32 GPCDAT;                  // Data
  11.     UINT32 GPCUP;                   // Pull-up disable
  12.     UINT32 PAD3;
  13.
  14.     UINT32 GPDCON;                  // Port D - offset 0x30
  15.     UINT32 GPDDAT;                  // Data
  16.     UINT32 GPDUP;                   // Pull-up disable
  17.     UINT32 PAD4;
  18.
  19.     UINT32 GPECON;                  // Port E - offset 0x40
  20.     UINT32 GPEDAT;                  // Data
  21.     UINT32 GPEUP;                   // Pull-up disable
  22.     UINT32 PAD5;
  23.
  24.     UINT32 GPFCON;                  // Port F - offset 0x50
  25.     UINT32 GPFDAT;
  26.     UINT32 GPFUP;
  27.     UINT32 PAD6;
  28.
  29.     UINT32 GPGCON;                  // Port G - offset 0x60
  30.     UINT32 GPGDAT;
  31.     UINT32 GPGUP;
  32.     UINT32 PAD7;
  33.
  34.     UINT32 GPHCON;                  // Port H - offset 0x70
  35.     UINT32 GPHDAT;
  36.     UINT32 GPHUP;
  37.     UINT32 PAD8;
  38.     UINT32 MISCCR;                  // misc control reg - offset 0x80
  39.     UINT32 DCLKCON;                 // DCLK0/1 control reg
  40.
  41.     UINT32 EXTINT0;                 // external interrupt control reg 0
  42.     UINT32 EXTINT1;                 // external interrupt control reg 1
  43.     UINT32 EXTINT2;                 // external interrupt control reg 2
  44.
  45.     UINT32 EINTFLT0;                // reserved
  46.     UINT32 EINTFLT1;                // reserved
  47.     UINT32 EINTFLT2;                // external interrupt filter reg 2
  48.     UINT32 EINTFLT3;                // external interrupt filter reg 3
  49.     UINT32 EINTMASK;                // external interrupt mask reg
  50.     UINT32 EINTPEND;                // external interrupt pending reg
  51.     UINT32 GSTATUS0;                // external pin status
  52.     UINT32 GSTATUS1;                // chip ID
  53.     UINT32 GSTATUS2;                // reset status
  54.     UINT32 GSTATUS3;                // inform register
  55.     UINT32 GSTATUS4;                // inform register
  56.         UINT32 FLTOUT;                                        // C0 - added by simon
  57.         UINT32 DSC0;
  58.         UINT32 DSC1;
  59.         UINT32 MSLCON;
  60.         UINT32 GPJCON;                                        // D0
  61.         UINT32 GPJDAT;
  62.         UINT32 GPJUP;
  63.         UINT32 PDA9;
  64.
  65. } S3C2440A_IOPORT_REG, *PS3C2440A_IOPORT_REG;
  66. //------------------------------------------------------------------------------
复制代码
比如初始化调试串口的时候有两句:
  1.     CLRREG32(&pIOPortReg->GPHCON, (3 << 8)|(3 << 10));
  2.     SETREG32(&pIOPortReg->GPHCON, (2 << 8)|(2 << 10));
复制代码
在这里GPHCON这个32位的字段每一位是个什么意思?这样设置又是什么意思?
恩,是这么个情况  详情 回复 发表于 2008-11-27 18:34
C/C++ code
-------------------C语言的位操作啊。
看来你要好好看一下C语言才行。你可以直接赋值,但是这样不够清晰,使用了位操作很明显的知道对寄存器的哪位做了操作。
你只要仔细看程序你就会发现,这样写的巧妙。
——结构体的存储方式和2440的寄存器地址紧密联系,紧密合作。
我知道这是位操作,也看了CLRREG32这个宏的定义,
我是想明白结构里面GPHCON和它所操作的端口是怎么对于的,
为什么给这几个位赋值就可以对串口进行初始化?
就是我想明白GPHCON这个32位的变量怎么对串口进行设置的
58
在S3C2440的datasheet上找到详细的定义了
结贴
63
引用 4 楼 kaios1 的回复:
结贴
哈哈,2440的手册过于简明,有时候很久才能找到答案。
63
恩,是这么个情况
