2796|0
77
WinCE启动步骤第一步疑问 [复制链接]
The process of changing an EXE or DLL program file after it has been loaded to reflect the actual load address is called “fixing up”.
哪位朋友能帮我解释下这个fix up的意思么?
还有这样一句:
kernel.dll is also ‘fixed up’ by the ROMIMAGE program to live at a specific virtual address in memory。
感谢!
此帖出自WindowsCE论坛
