2691|1
77
pb找不到当前活动的设备 [复制链接]
刚接触wince,我的板子是用cf卡启动的,nk.bin,eboot.bin都可以生成,用eboot启动,用这句启动Loadcepc /v/e:0:11:10.1.12.155 eboot.bin,这个ip和我主机是在一个子网通过路由器连接的 ,启动后目标机会出现"jumping xxxxx",网上说这时pb但是target->connectivity options->ethernet里面的活动项目应该出现,可我的还是空的不知道什么原因.
wince 6.0系统,硬件是GENE_9310这个,以下是他的帮助文档,大虾们看看应该是什么问题
Support Platform:
AAEON M/B(GENE-9310)
H/W Settings:
GENE-9310
a. BIOS settings to default except:
b. H/W settings:
        - Parallel port set to IRQ=7, IOBase=378
        - Com1=3F8/4, Com2=2F8/3
INSTALLATION INSTRUCTIONS
1. Decompress all files from "AAEON-BSP ZIP file" to temp (temporary) directory in your HDD.
2. Double click "Setup.bat" file icon , install all drivers and BSP files.
3. Execute the Visual Studio 2005 and select Menu Item "File -> Open -> Project/Solution..." to Open "\WINCE600\OSDesigns\GENE_9310_PRJ\GENE_9310.sln".
4. From "Solution configurations" ComboBox, Choose active configuration (meaning Model Name).
5. From the "Build" Menu, choose "Rebuild GENE_9310" to build a new Windows CE image.
6. If you get error message, then please do once again ("Build -> Rebuild Solution").
7. Delete all Decompress files (Option).
PRODUCT INFORMATION
Dependencies:
Windows CE 6.0 R2
Release note:
    This Windows CE BSP package release is version 600-20080325.
    This BSP is Intel chipsets Based BSP and should be applicable to AAEON M/B(GENE-9310)
顶下,有人知道吗...  详情 回复 发表于 2008-11-9 21:17
63
顶下,有人知道吗...
