3369|5
65
EVC 下如何显示png图片? [复制链接]
   WinCE5.0平台,EVC 下如何显示png图片?
void LoadImageFromRes(HDC hDC,DWORD ImgID,HINSTANCE inst,RECT&rec) {         HINSTANCE OldHinstance = AfxGetResourceHandle();         AfxSetResourceHandle(inst);         CoInitializeEx(NULL, COINIT_MULTITHREADED);         IImagingFactory *g_pImgFactory;         //COM初始化省略         IImage *pImage;         SUCCEEDED(CoCreateInstance (CLSID_ImagingFactory, NULL,CLSCTX_INPROC_SERVER, IID_IImagingFactory, (void **)&g_pImgFactory));         //装载资源         HRSRC hr;//资源句柄         hr = FindResource(AfxGetResourceHandle(),MAKEINTRESOURCE(ImgID),_T("PNG"));         HGLOBAL hglobal= LoadResource(AfxGetResourceHandle(), hr );         LPVOID    lpVoid     = NULL;         lpVoid = LockResource(hglobal);         int nSize = 0;         nSize = (UINT)SizeofResource(AfxGetResourceHandle(), hr);         if(nSize CreateImageFromBuffer((BYTE*)hglobal, nSize, BufferDisposalFlagNone ,&pImage);         RECT rect;         rect.left=rec.left;         rect.top=rec.top;         rect.right=rec.right;         rect.bottom=rec.bottom;         //画picture到DC中         pImage->Draw(hDC, &rect, NULL);         UnlockResource(hglobal);         pImage->Release();         g_pImgFactory->Release();         AfxSetResourceHandle(OldHinstance); }   详情 回复 发表于 2009-9-17 14:23
67
EVC下和PC上没多大区别,可以使用CIMAGE
可以使用IImage接口来显示PNG图片!直接Draw就可以了!
67
CIMAGE显示
我要实现那种透明效果,即在一块区域加载一幅png图片后,不将下面的图片给覆盖掉~
        //COM初始化省略
        IImage *pImage;
        //装载资源
        HRSRC hr;//资源句柄
        int nSize = 0;
        if(nSize <= 0){return ;}
        HRESULT ret1 =g_pImgFactory-> CreateImageFromBuffer((BYTE*)hglobal, nSize, BufferDisposalFlagNone ,&pImage);
        RECT rect;
        rect.left=rec.left;
        rect.top=rec.top;
        //画picture到DC中
        pImage->Release();
