2344|2
65
虚拟机安装问题 [复制链接]
安装虚拟机时出现:There is not enough free disk space for setup to proceed. To continue, free 166mb
                of disk space and click Retry. Otherwise, click Cancel to abort setup。
                  Preparing'VMware Workstation'for installation...
问题是:          我那个盘实际上有足够的空间,却始终显示这个。。。
                                 ------------------------------初学者不懂,希望高手来帮助指教啊!先谢谢啊!
Try setting the TEMP variable to point to a folder on a different disk. Right-click My Computer..Properties... Advanced...Environmental Variables.. Change TMP and TEMP to point someplace else. Try re-running the install. It should allow you to install to a different disk. Running your system with such little free space isn't good FWIW. mike 在国外的网站上抄来的,可以参考一下。  详情 回复 发表于 2008-8-6 18:45
75
以后需再关注,现在先帮你顶一下
75
mike
在国外的网站上抄来的,可以参考一下。
