4633|4
nt式usb过滤驱动,无法拦截到write操作.Windows xp [复制链接]
主要代码:
Windows xp
extern "C" NTSTATUS DriverEntry(IN PDRIVER_OBJECT    DriverObject,
                                IN PUNICODE_STRING    RegistryPath
    NTSTATUS    status;
    DriverObject->DriverUnload = DriverUnload;
    for(ULONG i = 0; i < IRP_MJ_MAXIMUM_FUNCTION; i++)
        DriverObject->MajorFunction = DispatchGeneral;
    DriverObject->MajorFunction[IRP_MJ_WRITE]    = DispatchWrite;
    DriverObject->MajorFunction[IRP_MJ_SCSI]    = DispatchWrite;  // 加了这句后仍然不能过滤掉写入
    DriverObject->MajorFunction[IRP_MJ_POWER]    = OnPower;
    DriverObject->MajorFunction[IRP_MJ_PNP]        = OnPnp;
                    // attach到usb驱动上
    status = AttachUsbDriver(DriverObject);
    return status;
// 打算用这个来处理写入请求.结果不工作.
NTSTATUS DispatchWrite(IN PDEVICE_OBJECT    DeviceObject,
                       IN PIRP                Irp)
    KdPrint(("Write!\n"));
    return STATUS_ACCESS_DENIED;
// 这个是attach到上层驱动,用device tree看了下,能正常工作.
NTSTATUS AttachUsbDriver(IN PDRIVER_OBJECT    DriverObject)
    NTSTATUS        status;
    UNICODE_STRING    ustrName;
    PDRIVER_OBJECT    usbDriver;
    PDEVICE_OBJECT    usbDevice;
    PDEVICE_OBJECT    pfltDevice;
    PDEVICE_OBJECT    pLowerDevice;
    PDEVICE_EXTENSION    pdx;
    RtlInitUnicodeString(&ustrName, L"\\Driver\\USBSTOR");
    status = ObReferenceObjectByName(&ustrName, OBJ_CASE_INSENSITIVE,
                                        NULL, 0, IoDriverObjectType,
                                        KernelMode, NULL, (PVOID*)&usbDriver);
    if(!NT_SUCCESS(status))
        KdPrint(("Couldn't get usb driver\n"));
        return status;
    usbDevice = usbDriver->DeviceObject;
    // 遍历usb设备对象.
    while(NULL != usbDevice)
        status = IoCreateDevice(DriverObject, sizeof(DEVICE_EXTENSION), NULL,
                                usbDevice->DeviceType, usbDevice->Characteristics,
                                FALSE, &pfltDevice);
            ObDereferenceObject(usbDriver);
            KdPrint(("Create fltdevice failed!\n"));
            return status;
        // 附加到上层驱动.
        pLowerDevice = IoAttachDeviceToDeviceStack(pfltDevice, usbDevice);
        if(NULL == pLowerDevice)
            KdPrint(("attach usb device error!\n"));
            IoDeleteDevice(pfltDevice);
            pfltDevice = NULL;
            return STATUS_UNSUCCESSFUL;
        pdx = (PDEVICE_EXTENSION)(pfltDevice->DeviceExtension);
        InitDevExt(pdx, pLowerDevice, pfltDevice, usbDevice);         // 这个函数将有用的信息放到device_extension结构中了.
                                          // 设置属性跟标志位
        pfltDevice->DeviceType        = pLowerDevice->DeviceType;
        pfltDevice->Characteristics    = pLowerDevice->Characteristics;
        pfltDevice->StackSize        = pLowerDevice->StackSize + 1;
        pfltDevice->Flags            |= pLowerDevice->Flags & (DO_BUFFERED_IO | DO_DIRECT_IO | DO_POWER_PAGABLE);
        pfltDevice->Flags            = pfltDevice->Flags & (~DO_DEVICE_INITIALIZING);
        // 移动到下个设备
        usbDevice = usbDevice->NextDevice;
    KdPrint(("Attach OK!\n"));
    return STATUS_SUCCESS;
网上也搜了下,结果没什么收获,
看了下ms的例子,是用wdm写的.attach到低层的驱动.
能过滤到pnp例程.却不能过滤读写?
是不是attach到上层驱动就不可以过滤还是???
搞了一整天,快吐血了.......
剛好也在學習 關注一下  详情 回复 发表于 2010-6-7 13:50
96
搞了两天,快崩溃了...
谁有例子,传个上来,感激涕零...
自己顶
59
没人回啊...晕死..
84
剛好也在學習
關注一下
