7572|27
67
一个关于Eboot跳转OAL的问题 [复制链接]
原来的系统是正常的,现在由于需要将NK的位置向后一段,于是在CONFIG.BIB中做了如下更改:
EMORY
    RESERVED     80000000        00008000        RESERVED
    DRV_GLB      80008000        00001000        RESERVED
    CS8950       80010000        00030000        RESERVED
    EDBG         80040000        00080000        RESERVED
    FRAMEBUF     800C0000        00200000        RESERVED
    RAM          802C0000        01D40000        RAM
    NK           88080000        01d40000        RAMIMAGE
                (原先为88000000)
CONFIG
    COMPRESSION=ON
    PROFILE=OFF
    ROMSTART=88080000(原先为88000000)
    ROMSIZE=1d40000
    ROMWIDTH=32
    ; Used for making a copy to RAM 0x80000000
    ; 0x88000000 + 0xD8000000 = 0x60000000
    ROMOFFSET=0xD8000000
    ROMFLAGS=1
    KERNELFIXUPS=OFF
    AUTOSIZE=ON
其中88000000为FLASH起始地址对应物理地址为60000000
改好后发现OS无法启动,通过点灯发现没有进入到OAL的STARTUP中.烧写过程应该没问题
这个是超级终端的信息
INFO: Found file 'nk.bin' (start cluster = 0x00000000:00000003 size = 0x17F45CF)
Downloading BIN file using Hard Drive/CF card.
System ready!
Preparing for download...
Reading Image File.Erasing flash blocks: start Addr = 0x60080000  length = 0x182
7758
.......................OK
Continue to Erase the rest of Flash.
Flash Erase Successfully Finished
Writing to flash at Address= 0x60080000, Length = 0x1827758
................Found pTOC signature.
ROMHDR at Address 60080044h
RomHdr.ulRAMStart=00FF0C07h RomHdr.physfirst=29A00C07h.
INFO: Jumping to image at 0x60081006...
这个是原来可以启动的信息
INFO: Found file 'nk.bin' (start cluster = 0x00000000:00000003 size = 0x17CECD3)
System ready!
Reading Image File.Erasing flash blocks: start Addr = 0x60000000  length = 0x180
0504
Writing to flash at Address= 0x60000000, Length = 0x1800504
ROMHDR at Address 60000044h
RomHdr.ulRAMStart=00FF0C07h RomHdr.physfirst=29900C07h.
INFO: Jumping to image at 0x60001006...
Windows CE Kernel for ARM (Thumb Enabled) Built on Mar 13 2003 at 22:52:56
ProcessorType=0920  Revision=0
sp_abt=ffff5000 sp_irq=ffff2800 sp_undef=ffffc800 OEMAddre) Sp=ffffc7cc
ERROR: f:\wince420\platform\ep931x\drivers\wavdev\wav.cpp line 730: AudioDriver:
:Initialize: Failed to initialize AC97Codec
                                           Data Abort: Thread=83ffcbb4 Proc=802e
90b0 'device.exe'
AKY=00000005 PC=031a6d58 RA=031a6d50 BVA=06000004 FSR=00000007
Init Raster engine
Clearing screen
Returning from DDI init
OEMResetWakeupSource dwSource = 0x11
OEMSetWakeupSource dwSource = 0x11
已经搞定了,是烧FLASH时的一个地址没有偏移,导致烧进去的数据不对,感谢各位的帮助,结贴  详情 回复 发表于 2009-8-3 15:03
你要看看在你的EBOOT中是否还有这些类似的地址或地址长度的定义,好好查查你的EBOOT程序,
77
用的是NOR?怎么没拷贝到ram里面运行?看起来是有RAM的虚拟地址的。
正确的镜像->写入flash成功->写入正确的地址->跳转到正确的地址->执行就肯定正确。
要判断这个,最简单的是在eboot时将0x60081006开始的N个block都读出来并打印出来,跟正确的nb0文件进行对比,就知道是否写入成功,以及写入的地址是否正确。
85
引用 2 楼 shuiyan 的回复:
用得是NOR 在FLASH本地运行的
如果要把这些地址读出来的话该怎么操作,能不能直接打印这些地址的数据,还是要写个类似FLASH驱动的东西.还有我的是.BIN的文件
82
96
刚才又去做了下实验,发现可以跑到STARTUP里了,一直到调用了KENKELSTART,然后就不动了
STARTUP.S文件
SMCBCR_IDCY_MASK        EQU         0x0000000F
SMCBCR_IDCY_SHIFT       EQU         0
SMCBCR_WST1_MASK        EQU         0x000003E0
SMCBCR_WST1_SHIFT       EQU         5
SMCBCR_RBLE             EQU         0x00000400
SMCBCR_WST2_MASK        EQU         0x0000F800
SMCBCR_WST2_SHIFT       EQU         11
SMCBCR_WPERR            EQU         0x02000000
SMCBCR_WP               EQU         0x04000000
SMCBCR_PME              EQU         0x08000000
SMCBCR_MASK             EQU         0x30000000
SMCBCR_MW_8BIT          EQU         0x00000000
SMCBCR_MW_16BIT         EQU         0x10000000
SMCBCR_MW_32BIT         EQU         0x20000000
SMCBCR_EBIBRKDIS        EQU         0x40000000
ROMHDR_dllfirst         EQU         0x8
ROMHDR_dlllast          EQU         0xC
ROMHDR_physfirst        EQU         0x10
ROMHDR_physlast         EQU         0x14
                IMPORT          KernelStart
                IMPORT          OEMAddressTable
                IMPORT          SysconSetup
                IMPORT          SdramCfg
                IMPORT          pTOC
;  StartUp routine to initialize the processor.
                STARTUPTEXT
                DCB             "CRUS", 0
                LEAF_ENTRY      StartUp
;  Kill watch dog timer. Before any thing else.
                ldr             r0, =0x80940000
                ldr             r1, =0xAA55
                str             r1, [r0]
; ensure SVC32 mode with IRQ and FIQ disabled
                mov             r0, #0xd3
                msr             cpsr_c, r0
; Check to see if we are executing in flash, if so we may need to
; setup SDRAM.
                cmp             pc, #0x60000000
                bls             DontConfigureSDRAM
; If we loaded through eboot, SDRAM is already configured.
; Check the CLKSET1 register to see if it has been modified.
                ldr             r0, =0x80930020
                ldr             r1, [r0]
                ldr             r0, =CLKSET1DEFAULT
                cmp             r0, r1
                bne             DontConfigureSDRAM
; Configure SDRAM
                bl              SdramCfg
DontConfigureSDRAM
; Turn off the MMU
                ldr             r0, =0xC0001078
                mcr             p15, 0, r0, c1, c0, 0
; Configure the flash chips
                ldr             r0, =((4:SHL:SMCBCR_WST2_SHIFT)  :or: \
                                      (15:SHL:SMCBCR_WST1_SHIFT) :or: \
                                      (1 :and:SMCBCR_IDCY_MASK)  :or: \
                                      SMCBCR_MW_32BIT            :or: \
                                      SMCBCR_WP                  :or: \
                                      SMCBCR_PME                 :or: \
                                      SMCBCR_RBLE)
                ldr             r1, =0x80080018
                str             r0, [r1]
                nop
ExecuteFromRam
                mov             sp, #0x40000
                bl              SysconSetup
; clear out magic words for memory and heap
; (r0) = physical address of OEMAddressTable
; Calculate the physical address of the table.
; r0 - Virtual address of OEMAddressTable
; r1 - Physical Address of Startup
; r2 - Virtual Address of Startup
; r0 = r0 - r2 + r1 = Physical address of OEMAddressTable
                ldr             r0,=OEMAddressTable
                adr             r1,StartUp
                ldr             r2,=StartUp
                add             r0, r0, r1
                sub             r0, r0, r2
===============================================到这里也可以点灯                bl              KernelStart
; KernelStart should never return:
    =============================================点不亮,说明跳到KERNELSTART里去了
spin            b               spin
还有个问题,我发现我的WINCE4.2没有PRIVATE这个目录,也找不到KERNELSTART这个函数,不知道为什么
找到了,原来是安装的时候没选,现在感觉应该是卡在OMEINIT前面了,奇怪的是为什么原来的能起来,就把NK往后移一段就起不来了,都已经跳到STARTUP了。
82
wince就是有很多不慕名的东东
87
顶一下
63
引用 7 楼 xyj0663 的回复:
wince就是有很多不慕名的东东
那可能是因为我们大家对WINCE掌控的还不够吧
84
确实,现在感到很莫名,都已经到KERNELSTART里的,缺运行不下去,这段都是微软的代码吧,不需要修改的。
今天又发现烧在600C0000后面就跳不到STARTUP里的,前面的就可以了。
75
是不是后面的地址有别的用到
64
引用 3 楼 fan0311 的回复:
引用 2 楼 shuiyan 的回复:
用得是NOR 在FLASH本地运行的
BIN文件能够在flash中xip吗?不是nb0才可以吗?
引用 11 楼 xyj0663 的回复:
是不是后面的地址有别的用到
没有啊,我的FLASH就是一个EBOOT和一个NK,没其他东西
82
确实是用XIP方式运行的,起来可以看到RAM的全部空间用做内存了
还有一种COPY到RAM中运行的方式我也试过,也行.
早上去又去试了下,发现不是0X60C0000后不能运行,而是随即的!同样一个NK,有时下去可以到STARTUP,有时就到不了,我无语了
up
建议 LZ 将   DCB            "CRUS", 0
改为         DCB            "CRUS", 0, 0, 0, 0
ARM instruction 必须是 32-bits alignment, 不然系统应该是会有问题
这个东西在 LZ 另一个帖子有说过了, 但不知 LZ 试的如何
Paul, Chao @ Techware
引用 16 楼 paul_chao 的回复:
建议 LZ 将? DCB? ? ? ? ? ? "CRUS", 0
改为? ? ? ? DCB? ? ? ? ? ? "CRUS", 0, 0, 0, 0
我试了下,JUMP地址到0x60081008了,但是还是一样系统起不来,现象和原来一样
79
UP
有时候你把一个值做了更改, 你找到了你所能找的所以地方,但其实,有些地方没有改到!
LZ的问题我没遇到过,   只是一种感觉!
config.bib 的设置,在flash的驱动、 bootloader,..等地方都要改吧
主你好运!
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
