关于驱动结构体 platform_driver 和 file_operations
static struct platform_driver hello_driver = {
.probe = hello_probe,
.remove = hello_remove,
.driver = {
.name = HELLO_DEV_NAME,
.owner = THIS_MODULE,
static struct file_operations hello_fops = {
.open = hello_open, //外部测试调用open打开设备文件时触发
.release = hello_close, //外部调用close时触发
.read = hello_read, //外部 write 时触发
.write = hello_write, //外部 read 时触发
请问上面的怎么用?什么时候触发呢?
下面是两个LED灯的驱动程序 一个用platform_driver 另一个用file_operations 不知有什么区别? 请帮忙解释下 谢谢了。
#include
#include
#include
#include
#include
#include
#include
/* our context */
struct s3c24xx_gpio_led {
struct led_classdev cdev;
struct s3c24xx_led_platdata *pdata;
static inline struct s3c24xx_gpio_led *pdev_to_gpio(struct platform_device *dev)
return platform_get_drvdata(dev);
static inline struct s3c24xx_gpio_led *to_gpio(struct led_classdev *led_cdev)
return container_of(led_cdev, struct s3c24xx_gpio_led, cdev);
static void s3c24xx_led_set(struct led_classdev *led_cdev,
enum led_brightness value)
struct s3c24xx_gpio_led *led = to_gpio(led_cdev);
struct s3c24xx_led_platdata *pd = led->pdata;
/* there will be a short delay between setting the output and
* going from output to input when using tristate. */
s3c2410_gpio_setpin(pd->gpio, (value ? 1 : 0) ^
(pd->flags & S3C24XX_LEDF_ACTLOW));
if (pd->flags & S3C24XX_LEDF_TRISTATE)
s3c2410_gpio_cfgpin(pd->gpio,
value ? S3C2410_GPIO_OUTPUT : S3C2410_GPIO_INPUT);
static int s3c24xx_led_remove(struct platform_device *dev)
struct s3c24xx_gpio_led *led = pdev_to_gpio(dev);
led_classdev_unregister(&led->cdev);
kfree(led);
return 0;
static int s3c24xx_led_probe(struct platform_device *dev)
struct s3c24xx_led_platdata *pdata = dev->dev.platform_data;
struct s3c24xx_gpio_led *led;
int ret;
led = kzalloc(sizeof(struct s3c24xx_gpio_led), GFP_KERNEL);
if (led == NULL) {
dev_err(&dev->dev, "No memory for device\n");
return -ENOMEM;
platform_set_drvdata(dev, led);
led->cdev.brightness_set = s3c24xx_led_set;
led->cdev.default_trigger = pdata->def_trigger;
led->cdev.name = pdata->name;
led->pdata = pdata;
/* no point in having a pull-up if we are always driving */
if (pdata->flags & S3C24XX_LEDF_TRISTATE) {
s3c2410_gpio_setpin(pdata->gpio, 0);
s3c2410_gpio_cfgpin(pdata->gpio, S3C2410_GPIO_INPUT);
} else {
s3c2410_gpio_pullup(pdata->gpio, 0);
s3c2410_gpio_cfgpin(pdata->gpio, S3C2410_GPIO_OUTPUT);
/* register our new led device */
ret = led_classdev_register(&dev->dev, &led->cdev);
if (ret < 0) {
dev_err(&dev->dev, "led_classdev_register failed\n");
goto exit_err1;
return 0;
exit_err1:
kfree(led);
return ret;
#ifdef CONFIG_PM
static int s3c24xx_led_suspend(struct platform_device *dev, pm_message_t state)
led_classdev_suspend(&led->cdev);
return 0;
static int s3c24xx_led_resume(struct platform_device *dev)
led_classdev_resume(&led->cdev);
return 0;
#else
#define s3c24xx_led_suspend NULL
#define s3c24xx_led_resume NULL
#endif
static struct platform_driver s3c24xx_led_driver = {
.probe = s3c24xx_led_probe,
.remove = s3c24xx_led_remove,
.suspend = s3c24xx_led_suspend,
.resume = s3c24xx_led_resume,
.driver = {
.name = "s3c24xx_led",
static int __init s3c24xx_led_init(void)
return platform_driver_register(&s3c24xx_led_driver);
static void __exit s3c24xx_led_exit(void)
platform_driver_unregister(&s3c24xx_led_driver);
module_init(s3c24xx_led_init);
module_exit(s3c24xx_led_exit);
MODULE_AUTHOR("Ben Dooks ");
MODULE_DESCRIPTION("S3C24XX LED driver");
MODULE_LICENSE("GPL");
MODULE_ALIAS("platform:s3c24xx_led");
另一个如下:
#include
#include
#include
#define DEVICE_NAME "leds"
static unsigned long led_table [] = {
S3C2410_GPB5,
S3C2410_GPB6,
S3C2410_GPB7,
S3C2410_GPB8,
static unsigned int led_cfg_table [] = {
S3C2410_GPB5_OUTP,
S3C2410_GPB6_OUTP,
S3C2410_GPB7_OUTP,
S3C2410_GPB8_OUTP,
static int sbc2440_leds_ioctl(
struct inode *inode,
struct file *file,
unsigned int cmd,
unsigned long arg)
switch(cmd) {
case 0:
case 1:
if (arg > 4) {
return -EINVAL;
s3c2410_gpio_setpin(led_table[arg], !cmd);
return 0;
default:
return -EINVAL;
static struct file_operations dev_fops = {
.ioctl = sbc2440_leds_ioctl,
static struct miscdevice misc = {
.minor = MISC_DYNAMIC_MINOR,
.name = DEVICE_NAME,
.fops = &dev_fops,
static int __init dev_init(void)
int ret;
int i;
for (i = 0; i < 4; i++) {
s3c2410_gpio_cfgpin(led_table, led_cfg_table);
s3c2410_gpio_setpin(led_table, 0);
ret = misc_register(&misc);
printk (DEVICE_NAME"\tinitialized\n");
return ret;
static void __exit dev_exit(void)
misc_deregister(&misc);
module_init(dev_init);
module_exit(dev_exit);
MODULE_AUTHOR("FriendlyARM Inc.");
