2130|2
63
帮忙找个语法错误 [复制链接]
  下面有标注的地方有错误,提示信息是“syntax error near 'else'”,出错的地方在下文中标出,请大家帮忙找一下,谢谢了
#include
unsigned char keyboard[]={0x7E,0xBE,0xDE,0xEE,  //0,1,2,3
                          0x7D,0xBD,0xDD,0xED,  //4,5,6,7
                          0x7B,0xBB,0xDB};      //8,9,sure
unsigned char search[]={0x7F,0xBF,0xDF,0xEF};
unsigned char keychange[8]={0,1,2,3,4,5,6,7};
unsigned char i,m,n=0,j=0;
bit flag=0;
sbit P3_0=P3^0;
sbit P3_1=P3^1;
sbit P3_2=P3^2;
sbit P3_3=P3^3;
sbit P3_4=P3^4;
sbit P3_5=P3^5;
unsigned char soso(unsigned char keynum);
void readkey(unsigned char number);
void inputkey(unsigned char key);
void delay200ms(void);
void delay1s(void);
void main()
  P3_0=0;
  while(1){
  delay200ms();
  do{P1=0x0F;
     m=P1;}while(m==P1);
  P3_3=0;delay1s();P3_3=0;
  i=0;
  do{P1=search;
     m=P1; }while(m==search[i++]);
   i=soso(m);
   if(P3_1==0) {if(j<8) inputkey(i);
                else {n=0;j=0;P3_5=0;delay1s();P3_5=1;};
   else        //????错误的箭头指向这行,提示“syntax error near 'else'”
     {if(i==10) {if(flag==0) {P3_1=0;P3_0=1;}; //open
                 else {P3_5=0;delay1s();P3_5=1;};
                                 n=0;j=0;flag=0;};
      else readkey(i);
   }//while
}//main
{   i=0;
   while(keynum!=keyboard)
   {++i;}
   return i;
   if(n<8)
    {if(number!=keychange[j++])  flag=1;
     else  ++j;}
   else flag=1;
   ++n;
   key=keychange[j++];
void int_0() interrupt 1
  void delay200ms();
  P3_1=1;
  P3_0=0;//close
  n=0;
  j=0;
{ unsigned char a,b,c;
for(a=5;a>0;a--)
for(b=132;b>0;b--)
for(c=150;c>0;c--); }
void delay1s(void)
{ unsigned char a,b,c,d;
for(a=5;a>0;a--)
for(b=4;b>0;b--)
for(c=116;c>0;c--)
for(d=214;d>0;d--); }
}; ????  详情 回复 发表于 2009-2-27 21:42
57
已解决,谢谢大家
