3114|1
78
读cf,sd卡的问题 [复制链接]
我想读取各种存储卡的serial number,代码如下:
#include "stdafx.h"
#include "windows.h"
#include "winioctl.h"
// retrieve the properties of a storage device or adapter.
typedef struct _STORAGE_DEVICE_DESCRIPTOR {  ULONG  Version;  ULONG  Size;  UCHAR  DeviceType;  UCHAR  DeviceTypeModifier;  BOOLEAN  RemovableMedia;
BOOLEAN  CommandQueueing;  ULONG  VendorIdOffset;  ULONG  ProductIdOffset;  ULONG  ProductRevisionOffset;  ULONG  SerialNumberOffset;  STORAGE_BUS_TYPE  BusType;
ULONG  RawPropertiesLength;  UCHAR  RawDeviceProperties[1];} STORAGE_DEVICE_DESCRIPTOR, *PSTORAGE_DEVICE_DESCRIPTOR;
typedef enum _STORAGE_QUERY_TYPE {
PropertyStandardQuery = 0,
PropertyExistsQuery,
PropertyMaskQuery,
PropertyQueryMaxDefined
} STORAGE_QUERY_TYPE, *PSTORAGE_QUERY_TYPE;
typedef enum _STORAGE_PROPERTY_ID {
StorageDeviceProperty = 0,
StorageAdapterProperty,
StorageDeviceIdProperty
} STORAGE_PROPERTY_ID, *PSTORAGE_PROPERTY_ID;
typedef struct _STORAGE_PROPERTY_QUERY {
STORAGE_PROPERTY_ID PropertyId;
STORAGE_QUERY_TYPE QueryType;
UCHAR AdditionalParameters[1];
} STORAGE_PROPERTY_QUERY, *PSTORAGE_PROPERTY_QUERY;
int _tmain(int argc, _TCHAR* argv[])
         HANDLE hnd;
     STORAGE_PROPERTY_QUERY  Query;
         PSTORAGE_DEVICE_DESCRIPTOR pDevDesc;
     DWORD dwOutBytes;
         char tzCFCardID[20];
     hnd = CreateFile("\\\\.\\g:", GENERIC_READ|GENERIC_WRITE,
         FILE_SHARE_READ|FILE_SHARE_WRITE, NULL, OPEN_EXISTING, 0, NULL);
         Query.PropertyId = StorageDeviceProperty;
     Query.QueryType = PropertyStandardQuery;
         pDevDesc=(STORAGE_DEVICE_DESCRIPTOR *)LocalAlloc(LMEM_ZEROINIT,3000);
         if(!DeviceIoControl(hnd, CTL_CODE(IOCTL_STORAGE_BASE, 0x0500, METHOD_BUFFERED, FILE_ANY_ACCESS), // info of device property
                 &Query, sizeof(STORAGE_PROPERTY_QUERY), // input data buffer
                 (LPVOID)pDevDesc, pDevDesc->Size, // output data buffer
                 &dwOutBytes, // out's length
                (LPOVERLAPPED)NULL))
         sprintf(tzCFCardID, "ERRORID:%lu", GetLastError());
                 printf("%s\n",tzCFCardID);
         printf("serial number offset:%lu\n",pDevDesc->SerialNumberOffset);
     LocalFree(pDevDesc);
         CloseHandle(hnd);
        return 0;
但是pDevDesc->SerialNumberOffset的值总是0,能帮下我吗?
谢谢!
不是很明白你的程序  详情 回复 发表于 2007-7-25 21:16
77
不是很明白你的程序
