在不清楚开发板硬件设计的情况下,要实现定时闹钟功能的稳妥办法是用外部的开发板进行控制处理,将泰坦触觉开发套件作为振动器件来使用,两种的中间桥梁则为 串口通讯。
这里作为外部控制的是ETEB-6001DPX-V1开发板,它负责RTC计时及显示驱动等功能,显示器件为串行数码管。
数码管与开发板的连接关系为:
CLK----P2.2
DIN----P2.3
CS ----P2.4
输出高低电平的语句定义为:
#define CLK_SetLow GPIO_WritePin(GPIO2, GPIO_PIN_02, RESET)
#define CLK_SetHigh GPIO_WritePin(GPIO2, GPIO_PIN_02, SET)
#define DIN_SetLow GPIO_WritePin(GPIO2, GPIO_PIN_03, RESET)
#define DIN_SetHigh GPIO_WritePin(GPIO2, GPIO_PIN_03, SET)
#define CS_SetLow GPIO_WritePin(GPIO2, GPIO_PIN_04, RESET)
#define CS_SetHigh GPIO_WritePin(GPIO2, GPIO_PIN_04, SET)
为进行串口通讯,使用串口为 UART0,其使用的引脚如图1所示。
图1 串口使用引脚
UART0的初识化函数为:
static void UART0_printf_init(void)
UART_InitTypeDef init;
init.baudRate = 115200;
init.wordLength = UART_WORDLENGTH_8B;
init.stopBits = UART_STOPBITS_1;
init.parity = UART_PARITY_NONE;
init.mode = UART_MODE_NORMAL;
init.DMAMode = UART_DMA_MULTI_MODE;
init.irqEnableFlag = UART_IT_NONE;
init.hwFlowCtl = UART_HWFLOW_DISABLE;
init.TXFIFOThreshold = UART_TXFIFO_THRESHOLD_0BYTES;
init.RXFIFOThreshold = UART_RXFIFO_THRESHOLD_1BYTES;
UART_Init(UART0, &init);
使用的RTC初始化函数为:
static void RTC_Calendar_init(void)
RTC_InitTypeDef init;
rtcDatetime time;
/* set default RTC parameter */
RTC_StructInit(&init);
/* init RTC peripheral */
RTC_Init(&init);
/* set start calendar time */
time.year = 2025;
time.month =1;
time.day = 16;
time.hour = 7;
time.minute = 4;
time.second = 50;
if(RTC_SetDatetime(&time) != DRV_OK)
while(1);
/* start count */
RTC_Enable();
以触觉马达振动实现电子闹钟功能的主程序为:
int main(void)
rtcDatetime calendar;
uint8_t tick = 0;
RTC_Calendar_init();
UART0_printf_init();
EVB_LEDInit();
Init_MAX7219();
Write_Max7219(1,1);
Write_Max7219(2,0);
Write_Max7219(3,10);
Write_Max7219(4,0);
Write_Max7219(5,0);
Write_Max7219(6,10);
Write_Max7219(7,0);
Write_Max7219(8,0);
while (1)
/* get current date time */
RTC_GetDatetime(&calendar);
if(tick != calendar.second)
tick = calendar.second;
Write_Max7219(1,calendar.second%10);
Write_Max7219(2,calendar.second/10);
Write_Max7219(4,calendar.minute%10);
Write_Max7219(5,calendar.minute/10);
Write_Max7219(7,calendar.hour%10);
Write_Max7219(8,calendar.hour/10);
if((calendar.hour==7)&&(calendar.minute==5)&&(calendar.second==0))
printf("vibrate 150 0.5 1000 0.5 0.5;");
printf("\nCurrent time is %02d:%02d:%02d\n",calendar.hour, calendar.minute, calendar.second);
整体的电路连接如图2所示,经程序的编译与调试运行,串口的输出信息如图3所示,即在得到设置时间时,会发出控制触觉马达的振动指令。
图2 电路连接
图3 输出信息
演示视频:
VID_20250116_223237
