3155|4
DS18B20传感器问题 [复制链接]
我下了个DS18B20的驱动程序,按到arm板上后进行读数,能复位,但就是在发出温度转换信号后那里卡住了,读不出数。
驱动程序如下:
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define DEVICE_NAME "DS18B20"
#define DS18B20_MAJOR 229
#define DS_PIN S3C2410_GPF0
#define OUT S3C2410_GPF0_OUTP
#define IN S3C2410_GPF0_INP
#define DIS_UP 1
#define EN_UP 0
#define Search 0x00F0
#define Read_ROM 0x0033 //just for one
#define Skip_ROM 0x00CC
#define Convert 0x0044
#define Write 0x004E //TH---TL---Config
#define Read 0x00BE
#define bit_9 0x001F
#define bit_10 0x003F
#define bit_11 0x005F
#define bit_12 0x007F
#define uint16 unsigned int
//unsigned int ROM_DATA[8];
void usdelay(unsigned int i) //延时 i us 对于不同系统可能会有所差别,请适当修改
        unsigned int j;
        for(i=i;i>0;i--)
        for(j=90;j>0;j--);
void msdelay(unsigned int i) //延时 i us
        for(i=i;i>0;i--)
        usdelay(1000);
void SetL(void)
        s3c2410_gpio_cfgpin(DS_PIN,OUT);
        s3c2410_gpio_setpin(DS_PIN,0);
void SetH(void)
        s3c2410_gpio_setpin(DS_PIN,1);
unsigned int Read_DS(void)
        unsigned int i;
        s3c2410_gpio_cfgpin(DS_PIN,IN);
        s3c2410_gpio_pullup(DS_PIN,EN_UP);
        __asm("nop");
        __asm("nop");
        __asm("nop");
        i=s3c2410_gpio_getpin(DS_PIN);
        if(i!=0)
                i=1;
        return i;
unsigned int ds_start(void)
        unsigned int flag=1;
        int err=0;
        SetL();
        usdelay(500); //560
        SetH();
        usdelay(1);
        while(Read_DS()!=0)
        // printk(DEVICE_NAME "Wait....\n");
                usdelay(5);
                err++;
                        if(err==20)
                           printk(DEVICE_NAME "start fail\n");
                           return -1;
    printk(DEVICE_NAME "start sucess\n");
        flag=0;
        SetH();
        usdelay(400);
        return flag;
void ds_send(unsigned int uidata)
        unsigned int i;
        for(i=0;i<8;i++)
                SetL();
                if((uidata&1)!=0)
                   usdelay(3); //3
                   SetH();
                   usdelay(80);
                else
                   usdelay(80);
                   SetH();
                   usdelay(5); //
                uidata>>=1;
unsigned int ds_read(void)
        unsigned int uidata=0;unsigned int i;
        for(i=0;i<8;i++)
                SetL();
                usdelay(4); //2 3
                SetH();
                usdelay(7); //1 2 3 4 5(e)
                if(Read_DS()==1)
                   uidata+=0x0100;
                uidata>>=1;
                SetH();
                usdelay(65);
        return uidata;
void ds_init(unsigned int TH,unsigned int TL,unsigned int bit_nmb)
        SetH();
        usdelay(80);
        if(ds_start()==0)
                ds_send(Skip_ROM); //复位
                ds_send(Write); //跳过ROM匹配
                ds_send(TH); //TH
                ds_send(TL); //TL
                ds_send(bit_nmb); //转换位数
unsigned int read_tem(void)
        unsigned int th=0,tl=0;int err=0;
        ds_init(100,0,bit_12);
        th=tl=0;
        ds_start();
        ds_start();
        ds_start();
        ds_send(Skip_ROM);
        ds_send(Convert);
        msdelay(50);
        while(Read_DS()==0)
        // printk(DEVICE_NAME "Convert....\n");
                msdelay(50);
                err++;
                if(err==10)
                   printk(DEVICE_NAME "convert fail\n");
                   return -1;
        ds_start();
        ds_start();
        ds_send(Skip_ROM);
        ds_send(Read);
        tl=ds_read();
        th=ds_read();
        ds_start();
        ds_start();
        th<<=8;
        tl|=th;
        return tl;
void read_ROM(void)
unsigned int i;
ds_start();
ds_send(Read_ROM);
for(i=0;i<8;i++)
ROM_DATA=ds_read();
static int ds18b20_ioctl(
        struct inode *inode,
        struct file *file,
        unsigned int cmd,unsigned long arg)
        return 0;
static ssize_t ds18b20_read(struct file *pFile, uint16 __user *pData, size_t count, loff_t *off )
    uint16 tmp,ret;
    tmp =read_tem();
    ret=copy_to_user(pData, &tmp, sizeof(tmp));    //将读取得的DS18B20数值复制到用户区
        if(ret>0)
                printk("copy data failed\n");
                return -1;
    return 0;
static struct file_operations ds18b20_fops = {
        .owner = THIS_MODULE,
        .ioctl = ds18b20_ioctl,
        .read = ds18b20_read,
static int __init ds18b20_init(void)
        int ret;
        ret = register_chrdev(DS18B20_MAJOR, DEVICE_NAME, &ds18b20_fops);
        if (ret < 0) {
           printk(DEVICE_NAME " can't register major number\n");
           return ret;
        devfs_mk_cdev(MKDEV(DS18B20_MAJOR, 0), S_IFCHR | S_IRUSR | S_IWUSR | S_IRGRP, DEVICE_NAME);
        s3c2410_gpio_cfgpin(DS_PIN, OUT);
        s3c2410_gpio_setpin(DS_PIN, 1);
        printk(DEVICE_NAME " initialized\n");
        return 0;
static void __exit ds18b20_exit(void)
        devfs_remove(DEVICE_NAME);
        unregister_chrdev(DS18B20_MAJOR, DEVICE_NAME);
        printk(DEVICE_NAME " rmmodule\n");
module_init(ds18b20_init);
module_exit(ds18b20_exit);
MODULE_DESCRIPTION("DS18B20 Driver");   // 一些描述信息
MODULE_LICENSE("GPL");                              // 遵循的协议
运行到unsigned int read_tem(void)函数那是出现了printk(DEVICE_NAME "convert fail\n")这句的终端语句,然后就返回了-1,没有读出正确温度,读出了-1。
这是什么问题?
while(Read_DS()==0)
                msdelay(50);
                err++;
                if(err==10)
                   return -1;
这个循环为什么没过去呢?
我换了另一个驱动程序后,因为那个驱动没有这个循环,它读出的全是0,这又说明了什么?
是不是我的接口有问题,还是传感器出了问题?
我这没有调试的工具,所以也不知道具体原因,希望有经验的朋友来讲解一下!谢谢啦!
问题解决  详情 回复 发表于 2009-8-14 22:47
上班一直在看代码所以不好意思我没有看你的代码,脑袋发胀了。我想你可以检查一下时序对不对,ds1820温度转换过程(一个ds18b20)是:发命令复位->发命令跳过Match ROM->发命令进行转换->CPU等待转换结束->发命令复位->发命令跳过Match ROM->发命令读取温度,注意有两个复位。你看一下你的代码是不是这样的。
顺便提一下建议:贴代码的时候顺便写一下你的程序构想,看代码很枯燥的。
78
引用 1 楼 cokewei 的回复:
是这样的,程序里是这样写的,但就是在“->CPU等待转换结束”这一布上出了问题,程序在这里等不到信号,循环了10次后就跳出了,没有向下进行。下面的函数中跳出,输出了红色的那条语句。
th=tl=0;
ds_start();
ds_start();
ds_start();
ds_send(Skip_ROM);
ds_send(Convert);
msdelay(50);
while(Read_DS()==0)
msdelay(50);
err++;
if(err==10)
  return -1;
ds_start();
ds_start();
ds_send(Skip_ROM);
ds_send(Read);
tl=ds_read();
th=ds_read();
ds_start();
ds_start();
th < <=8;
tl|=th;
return tl;
我用的是2440板子的GPF1这个口,这个口的时序好吗?它好想有上拉电阻,VDD33V。
问题解决
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
