250|1
437
【极海APM32M3514电机通用评估板】 GPIO输入与输出 [复制链接]
搭建环境,测试开发板的GPIO输入与输出,波动K2开关,D7闪烁或关闭。
一、资料下载
极海官网资料下载地址:https://www.geehy.com/design/hardware_detail/77
SDK下载链接:https://www.geehy.com/uploads/tool/APM32M35xx_SDK_V1.0.0.zip
二、硬件部分
测试用到开发板上的D7指示灯和K2开关。
对应MCU端口
三、程序部分
3.1、led.c
#include "main.h"
void init_led(void)
	GPIO_Config_T gpioConfig;
	RCM_EnableAHBPeriphClock(LED_GPIO_CLK);
	gpioConfig.pin = LED_PIN;
	gpioConfig.mode = GPIO_MODE_OUT;
	gpioConfig.outtype = GPIO_OUT_TYPE_PP;
	gpioConfig.speed = GPIO_SPEED_50MHz;
	gpioConfig.pupd = GPIO_PUPD_NO;
	GPIO_Config(LED_GPIO_PORT, &gpioConfig);
3.2、led.h
#ifndef _LED_H
#define _LED_H
#define  LED_GPIO_CLK       			RCM_AHB_PERIPH_GPIOA
#define  LED_GPIO_PORT          	GPIOA
#define  LED_PIN           				GPIO_PIN_12
#define  led_on()  								GPIO_ClearBit(LED_GPIO_PORT, LED_PIN)
#define  led_off()  							GPIO_SetBit(LED_GPIO_PORT, LED_PIN)
void init_led(void);
#endif
3.3、mian.c
#include "main.h"
void init_swdir(void)
	RCM_EnableAHBPeriphClock(RCM_AHB_PERIPH_GPIOC);
	gpioConfig.pin = GPIO_PIN_13;
	gpioConfig.mode = GPIO_MODE_IN;
	gpioConfig.pupd = GPIO_PUPD_PU;
	GPIO_Config(GPIOC, &gpioConfig);
int main(void)
	APM_DelayInit();
	init_swdir();
	init_led();
	while (1)
		if(GPIO_ReadInputBit(GPIOC, GPIO_PIN_13) == 0)
			led_on();
			APM_DelayMs(200);
			led_off();
			APM_DelayMs(200);
		else
			led_off();
3.4、mian.h
#ifndef __MAIN_H
#define __MAIN_H
#ifdef __cplusplus
extern "C" {
#endif
/* Includes */
#include "Board.h"
#include "apm32m35xx.h"
#include "bsp_delay.h"
#include "apm32m35xx_rcm.h"
#include "apm32m35xx_gpio.h"
#include "apm32m35xx_misc.h"
#include <stdio.h>
#include <string.h>
#include "led/led.h"
#ifdef __cplusplus
#endif
#endif
四、运行结果
下载程序后,复位开发板运行,波动开关K2,D7闪烁和熄灭
gpio
老哥,RA8那个板载Flash,AF32  128那个QSPI的测试工程能够分享一下吗?   详情 回复 发表于 2024-12-9 12:01
点赞 关注(1)
6349
在爱好的道路上不断前进,在生活的迷雾中播撒光引
站长推荐上一条 1/5 下一条
