在上一节中,我们获得了retinaface和facenet的onnx模型,在这一节中我们将其转换为RKNPU能够识别并运行的rknn格式。
环境安装
参考我之前写的一篇博客:https://bbs.elecfans.com/jishu_2454118_1_1.html
模型转换
retinaface
数据集准备
首先上传一张包含人脸的校准数据集,并将其路径存放至retinaface_dataset.txt文件中。
retinaface_dataset.txt内容如下:
../../img/detection/face.jpg
模型转换
编写模型转换脚本:
import sys
from rknn.api import RKNN
def parse_arg():
if len(sys.argv) < 5:
print("Usage: python3 {} [onnx_model_path] [dataset_path] [output_rknn_path] [model_type]".format(sys.argv[0]));
exit(1)
model_path = sys.argv[1]
dataset_path= sys.argv[2]
output_path = sys.argv[3]
model_type = sys.argv[4]
return model_path, dataset_path, output_path,model_type
if __name__ == '__main__':
model_path, dataset_path, output_path, model_type= parse_arg()
rknn = RKNN(verbose=False)
print('--> Config model')
if model_type == 'Retinaface':
rknn.config(mean_values=[[104, 117, 123]], std_values=[[1, 1, 1]], target_platform='rv1103',
quantized_algorithm="normal", quant_img_RGB2BGR=True,optimization_level=0)
print("Use retinaface mode")
else:
rknn.config(mean_values=[[0, 0, 0]], std_values=[[255, 255, 255]], target_platform='rv1103')
print('done')
print('--> Loading model')
ret = rknn.load_onnx(model=model_path)
if ret != 0:
print('Load model failed!')
exit(ret)
print('done')
print('--> Building model')
ret = rknn.build(do_quantization=True, dataset=dataset_path)
if ret != 0:
print('Build model failed!')
exit(ret)
print('done')
print('--> Export rknn model')
ret = rknn.export_rknn(output_path)
if ret != 0:
print('Export rknn model failed!')
exit(ret)
print('done')
rknn.release()
执行convert.py进行模型转换:
python convert.py ../model_zoo/export/retinaface.onnx ./dataset/retinaface_dataset.txt ../model_zoo/retinaface.rknn Retinaface
facenet
数据集准备
首先上传一张包含人脸的校准数据集,并将其路径存放至facenet_dataset.txt文件中。
facenet_dataset.txt内容如下:
../../img/recongnition/calib.jpg
模型转换
执行convert.py进行模型转换:
python convert.py ../model_zoo/export/facenet.onnx ./dataset/facenet_dataset.txt ../model_zoo/facenet.rknn Facenet
转换完成后,就能够分别得到两个相应的rknn模型文件于model_zoo目录下:
模型评估
数据集准备
首先准备验证数据集:
目录结构如下:
eval
├── dataset
│ ├── facenet
│ └── retinaface
├── facenet.py
└── retinaface.py
retinaface
import os
import sys
import urllib
import urllib.request
import time
import numpy as np
import cv2
from math import ceil
from itertools import product as product
DATASET_PATH = '../dataset/retinaface_dataset.txt'
DEFAULT_QUANT = True
def letterbox_resize(image, size, bg_color):
letterbox_resize the image according to the specified size
:param image: input image, which can be a NumPy array or file path
:param size: target size (width, height)
:param bg_color: background filling data
:return: processed image
if isinstance(image, str):
image = cv2.imread(image)
target_width, target_height = size
image_height, image_width, _ = image.shape
aspect_ratio = min(target_width / image_width, target_height / image_height)
new_width = int(image_width * aspect_ratio)
new_height = int(image_height * aspect_ratio)
image = cv2.resize(image, (new_width, new_height), interpolation=cv2.INTER_AREA)
result_image = np.ones((target_height, target_width, 3), dtype=np.uint8) * bg_color
offset_x = (target_width - new_width) // 2
offset_y = (target_height - new_height) // 2
result_image[offset_y:offset_y + new_height, offset_x:offset_x + new_width] = image
return result_image, aspect_ratio, offset_x, offset_y
def PriorBox(image_size):
anchors = []
min_sizes = [[16, 32], [64, 128], [256, 512]]
steps = [8, 16, 32]
feature_maps = [[ceil(image_size[0] / step), ceil(image_size[1] / step)] for step in steps]
for k, f in enumerate(feature_maps):
min_sizes_ = min_sizes[k]
for i, j in product(range(f[0]), range(f[1])):
for min_size in min_sizes_:
s_kx = min_size / image_size[1]
s_ky = min_size / image_size[0]
dense_cx = [x * steps[k] / image_size[1] for x in [j + 0.5]]
dense_cy = [y * steps[k] / image_size[0] for y in [i + 0.5]]
for cy, cx in product(dense_cy, dense_cx):
anchors += [cx, cy, s_kx, s_ky]
output = np.array(anchors).reshape(-1, 4)
print("image_size:",image_size," num_priors=",output.shape[0])
return output
def box_decode(loc, priors):
"""Decode locations from predictions using priors to undo
the encoding we did for offset regression at train time.
Args:
loc (tensor): location predictions for loc layers,
Shape: [num_priors,4]
priors (tensor): Prior boxes in center-offset form.
Shape: [num_priors,4].
variances: (list[float]) Variances of priorboxes
Return:
decoded bounding box predictions
variances = [0.1, 0.2]
boxes = np.concatenate((
priors[:, :2] + loc[:, :2] * variances[0] * priors[:, 2:],
priors[:, 2:] * np.exp(loc[:, 2:] * variances[1])), axis=1)
boxes[:, :2] -= boxes[:, 2:] / 2
boxes[:, 2:] += boxes[:, :2]
return boxes
def decode_landm(pre, priors):
"""Decode landm from predictions using priors to undo
Args:
pre (tensor): landm predictions for loc layers,
Shape: [num_priors,10]
Return:
decoded landm predictions
landmarks = np.concatenate((
priors[:, :2] + pre[:, :2] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 2:4] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 4:6] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 6:8] * variances[0] * priors[:, 2:],
priors[:, :2] + pre[:, 8:10] * variances[0] * priors[:, 2:]
), axis=1)
return landmarks
def nms(dets, thresh):
"""Pure Python NMS baseline."""
x1 = dets[:, 0]
y1 = dets[:, 1]
x2 = dets[:, 2]
y2 = dets[:, 3]
scores = dets[:, 4]
areas = (x2 - x1 + 1) * (y2 - y1 + 1)
order = scores.argsort()[::-1]
keep = []
while order.size > 0:
i = order[0]
keep.append(i)
xx1 = np.maximum(x1<i>, x1[order[1:]])
yy1 = np.maximum(y1<i>, y1[order[1:]])
xx2 = np.minimum(x2<i>, x2[order[1:]])
yy2 = np.minimum(y2<i>, y2[order[1:]])
w = np.maximum(0.0, xx2 - xx1 + 1)
h = np.maximum(0.0, yy2 - yy1 + 1)
inter = w * h
ovr = inter / (areas<i> + areas[order[1:]] - inter)
inds = np.where(ovr <= thresh)[0]
order = order[inds + 1]
return keep
rknn = RKNN()
rknn.config(mean_values=[[104, 117, 123]], std_values=[[1, 1, 1]], target_platform="rv1106",
quantized_algorithm="normal", quant_img_RGB2BGR=True)
print('done')
ret = rknn.load_onnx(model="../../model_zoo/export/retinaface.onnx")
if ret != 0:
exit(ret)
print('done')
ret = rknn.build(do_quantization=True, dataset=DATASET_PATH)
if ret != 0:
exit(ret)
print('done')
img = cv2.imread('./dataset/retinaface/j1.jpg')
img_height, img_width, _ = img.shape
model_height, model_width = (640, 640)
letterbox_img, aspect_ratio, offset_x, offset_y = letterbox_resize(img, (model_height,model_width), 114)
infer_img = letterbox_img[..., ::-1]
print('--> Init runtime environment')
ret = rknn.init_runtime()
if ret != 0:
print('Init runtime environment failed!')
exit(ret)
print('done')
print('--> Running model')
outputs = rknn.inference(inputs=[infer_img])
loc, conf, landmarks = outputs
priors = PriorBox(image_size=(model_height, model_width))
boxes = box_decode(loc.squeeze(0), priors)
scale = np.array([model_width, model_height,
model_width, model_height])
boxes = boxes * scale // 1
boxes[...,0::2] =np.clip((boxes[...,0::2] - offset_x) / aspect_ratio, 0, img_width)
boxes[...,1::2] =np.clip((boxes[...,1::2] - offset_y) / aspect_ratio, 0, img_height)
scores = conf.squeeze(0)[:, 1]
landmarks = decode_landm(landmarks.squeeze(
0), priors)
scale_landmarks = np.array([model_width, model_height, model_width, model_height,
landmarks = landmarks * scale_landmarks // 1
landmarks[...,0::2] = np.clip((landmarks[...,0::2] - offset_x) / aspect_ratio, 0, img_width)
landmarks[...,1::2] = np.clip((landmarks[...,1::2] - offset_y) / aspect_ratio, 0, img_height)
inds = np.where(scores > 0.5)[0]
boxes = boxes[inds]
landmarks = landmarks[inds]
scores = scores[inds]
boxes = boxes[order]
landmarks = landmarks[order]
scores = scores[order]
dets = np.hstack((boxes, scores[:, np.newaxis])).astype(
np.float32, copy=False)
keep = nms(dets, 0.2)
dets = dets[keep, :]
landmarks = landmarks[keep]
dets = np.concatenate((dets, landmarks), axis=1)
for data in dets:
if data[4] < 0.5:
continue
print("face @ (%d %d %d %d) %f"%(data[0], data[1], data[2], data[3], data[4]))
text = "{:.4f}".format(data[4])
data = list(map(int, data))
cv2.rectangle(img, (data[0], data[1]),
(data[2], data[3]), (0, 0, 255), 2)
cx = data[0]
cy = data[1] + 12
cv2.putText(img, text, (cx, cy),
cv2.FONT_HERSHEY_DUPLEX, 0.5, (255, 255, 255))
cv2.circle(img, (data[5], data[6]), 1, (0, 0, 255), 5)
cv2.circle(img, (data[7], data[8]), 1, (0, 255, 255), 5)
cv2.circle(img, (data[9], data[10]), 1, (255, 0, 255), 5)
cv2.circle(img, (data[11], data[12]), 1, (0, 255, 0), 5)
cv2.circle(img, (data[13], data[14]), 1, (255, 0, 0), 5)
img_path = './result.jpg'
cv2.imwrite(img_path, img)
print("save image in", img_path)
rknn.release()
执行结果如下:
facenet
import numpy as np
import cv2
import os
from PIL import Image
from sklearn import preprocessing
from scipy.spatial.distance import pdist
os.environ['RKNN_DRAW_DATA_DISTRIBUTE']="1"
BUILD_QUANT = True
rknn = RKNN()
print('--> config model')
print('done')
print('--> Lccoading model')
ret = rknn.load_onnx(model='../../model_zoo/export/facenet.onnx')
if ret != 0:
print('Load facenet failed!')
exit(ret)
print('done')
ret = rknn.build(do_quantization=True, dataset='../dataset/facenet_dataset.txt')
if ret != 0:
exit(ret)
print('done')
if ret != 0:
print('Init runtime environment failed')
exit(ret)
print('done')
image_1 = Image.open("./dataset/facenet/1_001.jpg")
image_1 = image_1.resize((160,160), Image.BICUBIC)
img1 = np.asarray(image_1, np.uint8)
outputs1 = np.array(rknn.inference(data_format='nhwc', inputs=[img1])[0])
outputs1 = preprocessing.normalize(outputs1, norm='l2')
image_2 = Image.open("./dataset/facenet/1_002.jpg")
image_2 = image_2.resize((160,160), Image.BICUBIC)
img2 = np.asarray(image_2, np.uint8)
outputs2 = np.array(rknn.inference(data_format='nhwc', inputs=[img2])[0])
outputs2 = preprocessing.normalize(outputs2, norm='l2')
distance = np.linalg.norm(outputs2 - outputs1, axis=1)
print("distance:", distance)
rknn.release()
执行结果如下:
工程文件在附录中。
