下载MNIST数据集
- # MNIST数据集,用于训练,一次抓60 size
- self._train_loader = torch.utils.data.DataLoader(
- torchvision.datasets.MNIST('./data/', train=True, download=True,
- transform=torchvision.transforms.Compose([
- torchvision.transforms.ToTensor(),
- torchvision.transforms.Normalize(
- (0.1307,), (0.3081,))
- batch_size=60, shuffle=True)
- # 用于测试,一次抓500 size
- self._test_loader = torch.utils.data.DataLoader(
- torchvision.datasets.MNIST('./data/', train=False, download=True,
- batch_size=500, shuffle=True)
编辑网络
- # 连接序列
- self._conv1_layer = nn.Sequential(
- # 卷积
- nn.Conv2d(1,15,5),
- # 激活函数
- nn.ReLU(),
- # 最大池化,减少特征量,选特征最大的数,是一种下采样
- nn.MaxPool2d(kernel_size=2, stride=2),
- self._conv2_layer = nn.Sequential(
- nn.Conv2d(15,30,5),
- nn.ReLU(),
- self._full_layer = nn.Sequential(
- # 卷积层都是四维张量,展平为二维张量给连接层用
- nn.Flatten(),
- nn.Linear(in_features=480, out_features=60),
- nn.ReLU(),
- nn.Linear(in_features=60, out_features=10),
判断是否可以是否GPU训练
- if torch.cuda.is_available():
- print("Use CUDA training!")
- self._device = torch.device("cuda")
- else:
- print("Use CPU training!")
- self._device = torch.device("cpu")
训练
- def train(self):
- loss_d = []
- for epoch in range(1, self._epochs + 1):
- self._cnn.train(mode=True)
- for idx, (train_img, train_label) in enumerate(self._train_loader):
- # 复制到device中
- train_img = train_img.to(self._device)
- train_label = train_label.to(self._device)
- outputs = self._cnn(train_img)
- # 清除梯度
- self._optim.zero_grad()
- loss = self._loss_func(outputs, train_label)
- # 反向传播
- loss.backward()
- # 更新权重
- self._optim.step()
- # print('Train epoch {}: loss: {:.6f}'.format(epoch,loss.item()))
- loss_d.append(loss.item())
- plt.plot(range(0,len(loss_d)),loss_d)
- plt.show()
Train的loss分布
Test的loss以及准确率
识别的结果
保存的pth和onnx模型
- def savePthModel(self, pth_name:str):
- torch.save(self._cnn.state_dict(), pth_name)
- def saveOnnxModel(self, onnx_name:str):
- input = torch.randn(1,1,28,28)
- torch.onnx.export(self._cnn, input, onnx_name, verbose=True)
完整代码
- import torch
- import torch.nn as nn
- import torchvision.datasets
- import matplotlib.pyplot as plt
- import numpy as np
- class CNN(nn.Module):
- def __init__(self):
- super(CNN, self).__init__()
- # 连接序列
- # 卷积
- # 激活函数
- nn.ReLU(),
- nn.ReLU(),
- nn.Flatten(),
- nn.ReLU(),
- def forward(self, input):
- # 层层连接,两个卷积层,最后全连接层
- output = self._conv1_layer(input)
- output = self._conv2_layer(output)
- output = self._full_layer(output)
- return output
- class Test:
- # 训练次数
- self._epochs = 3
- self._cnn = CNN()
- # 交叉熵损失函数,刻画的是两个概率分布的距离,交叉熵越小,概率分布越接近
- self._loss_func = nn.CrossEntropyLoss()
- # 优化器
- self._optim = torch.optim.Adam(self._cnn.parameters(), lr=0.01)
- else:
- def train(self):
- loss_d = []
- # 复制到device中
- # 清除梯度
- # 反向传播
- loss.backward()
- # 更新权重
- plt.show()
- def test(self):
- correct_num = 0
- total_num = 0
- loss_d = []
- self._cnn.train(mode=False)
- with torch.no_grad():
- for idx, (test_img, test_label) in enumerate(self._test_loader):
- test_img = test_img.to(self._device)
- test_label = test_label.to(self._device)
- total_num += test_label.size(0)
- outputs = self._cnn(test_img)
- loss = self._loss_func(outputs, test_label)
- predictions = torch.argmax(outputs, dim=1)
- correct_num += torch.sum(predictions == test_label)
- acc_num = ((correct_num.item()/total_num)*100)
- title_str ="Accuracy:"+str(acc_num)+"%"
- plt.title(title_str)
- plt.show()
- def plotTestResult(self):
- iteration = enumerate(self._test_loader)
- idx, (test_img, test_label) = next(iteration)
- fig = plt.figure()
- for i in range(4 * 2):
- plt.subplot(4, 2, i + 1)
- plt.tight_layout()
- plt.imshow(test_img[0], cmap='gray', interpolation='none')
- plt.title('real: {}, predict: {}'.format(
- test_label, outputs.data.max(1, keepdim=True)[1].item()
- plt.xticks([])
- plt.yticks([])
- plt.show()
- if __name__ == "__main__":
- mt = Test()
- mt.train()
- mt.test()
- mt.plotTestResult()
- mt.savePthModel("model.pth")
- mt.saveOnnxModel("model.onnx")
视频讲解
