902|3
1249
67
【STM32H7S78-DK】测评+ADC DMA采集1024点FFT计算速度测评 [复制链接]
在前面帖子实现ADC DMA采集、DSP库添加的基础上,本帖将采集1024点数据进行FFT运算,评估STM32H7S78的DSP性能。
测试代码如下:
  • /* USER CODE END Header */
  • /* Includes ------------------------------------------------------------------*/
  • #include "main.h"
  • /* Private includes ----------------------------------------------------------*/
  • /* USER CODE BEGIN Includes */
  • #include "stdio.h"
  • #include "arm_math.h"
  • #include "perf_counter.h"
  • /* USER CODE END Includes */
  • /* Private typedef -----------------------------------------------------------*/
  • /* USER CODE BEGIN PTD */
  • /* USER CODE END PTD */
  • /* Private define ------------------------------------------------------------*/
  • /* USER CODE BEGIN PD */
  • #define VDDA_APPLI (3300UL)
  • #define VAR_CONVERTED_DATA_INIT_VALUE (__LL_ADC_DIGITAL_SCALE(LL_ADC_RESOLUTION_12B) + 1)
  • #define ADC_CONVERTED_DATA_BUFFER_SIZE 1024
  • ALIGN_32BYTES (uint16_t uhADCxConvertedData[ADC_CONVERTED_DATA_BUFFER_SIZE]);
  • uint16_t uhADCxConvertedData_Voltage_mVolt[ADC_CONVERTED_DATA_BUFFER_SIZE];
  • //0: DMA transfer is not completed
  • //1: DMA transfer is completed
  • //2: DMA transfer has not yet been started yet (initial state)
  • __IO uint8_t ubDmaTransferStatus = 2U;
  • /* USER CODE END PD */
  • /* Private macro -------------------------------------------------------------*/
  • /* USER CODE BEGIN PM */
  • /* USER CODE END PM */
  • /* Private variables ---------------------------------------------------------*/
  • ADC_HandleTypeDef hadc2;
  • DMA_HandleTypeDef handle_GPDMA1_Channel0;
  • TIM_HandleTypeDef htim6;
  • UART_HandleTypeDef huart4;
  • /* USER CODE BEGIN PV */
  • /* USER CODE END PV */
  • /* Private function prototypes -----------------------------------------------*/
  • static void MPU_Config(void);
  • static void MX_GPIO_Init(void);
  • static void MX_GPDMA1_Init(void);
  • static void MX_TIM6_Init(void);
  • static void MX_UART4_Init(void);
  • static void MX_ADC2_Init(void);
  • /* USER CODE BEGIN PFP */
  • /* USER CODE END PFP */
  • /* Private user code ---------------------------------------------------------*/
  • /* USER CODE BEGIN 0 */
  • int __io_putchar(int ch)
  • HAL_UART_Transmit(&huart4 , (uint8_t *)&ch, 1, 0xFFFF);
  • return ch;
  • void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef *hadc)
  • ubDmaTransferStatus = 1;
  • int tmp_index;
  • #define FFT_LENGTH ADC_CONVERTED_DATA_BUFFER_SIZE
  • float fft_inputbuf[FFT_LENGTH * 2];
  • float fft_outputbuf[FFT_LENGTH];
  • uint32_t ifftFlag = 0;
  • uint32_t fftSize = 0;
  • #define TEST_LENGTH_SAMPLES 1024
  • static float32_t testOutput_f32[TEST_LENGTH_SAMPLES*2];
  • static float32_t testOutputMag_f32[TEST_LENGTH_SAMPLES*2];
  • static float32_t testInput_f32[TEST_LENGTH_SAMPLES*2];
  • static float32_t Phase_f32[TEST_LENGTH_SAMPLES*2];
  • void PowerPhaseRadians_f32(float32_t *_ptr, float32_t *_phase, uint16_t _usFFTPoints, float32_t _uiCmpValue)
  • float32_t lX, lY;
  • uint16_t i;
  • float32_t phase;
  • float32_t mag;
  • for (i=0; i <_usFFTPoints; i++)
  • lX= _ptr[2*i];//实部
  • lY= _ptr[2*i + 1];//虚部
  • phase = atan2f(lY, lX);//atan2求解的结果范围是(-pi, pi], 弧度
  • arm_sqrt_f32((float32_t)(lX*lX+ lY*lY), &mag);//求模
  • if(_uiCmpValue > mag)
  • Phase_f32[i] = 0;
  • else
  • Phase_f32[i] = phase* 180.0f/3.1415926f;//将求解的结果由弧度转换为角度
  • static void arm_rfft_f32_app2(void)
  • uint16_t i;
  • arm_rfft_fast_instance_f32 S;
  • //正变换
  • ifftFlag = 0;
  • //初始化结构体S中的参数
  • arm_rfft_fast_init_f32(&S, TEST_LENGTH_SAMPLES);
  • for(i=0; i<TEST_LENGTH_SAMPLES; i++)
  • //测试波形
  • //testInput_f32[i] = 1 + cos(2*3.1415926f*50*i/1024 + 3.1415926f/3);
  • testInput_f32[i * 2] = uhADCxConvertedData_Voltage_mVolt[i];
  • testInput_f32[i * 2 + 1] = 0;//虚部赋值,固定为0.
  • //1024点实序列快速变换
  • arm_rfft_fast_f32(&S, testInput_f32, testOutput_f32, ifftFlag);
  • arm_cmplx_mag_f32(testOutput_f32, testOutputMag_f32, TEST_LENGTH_SAMPLES);
  • PowerPhaseRadians_f32(testOutput_f32, Phase_f32, TEST_LENGTH_SAMPLES, 0.5f);
  • //串口打印求解的幅频和相频
  • //printf("%f, %f\r\n", testOutputMag_f32[i], Phase_f32[i]);
  • /* USER CODE END 0 */
  • * [url=home.php?mod=space&uid=159083]@brief[/url] The application entry point.
  • * @retval int
  • int main(void)
  • /* USER CODE BEGIN 1 */
  • /* USER CODE END 1 */
  • /* MPU Configuration--------------------------------------------------------*/
  • MPU_Config();
  • /* MCU Configuration--------------------------------------------------------*/
  • /* Update SystemCoreClock variable according to RCC registers values. */
  • SystemCoreClockUpdate();
  • /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  • HAL_Init();
  • /* USER CODE BEGIN Init */
  • init_cycle_counter(true);
  • /* USER CODE END Init */
  • /* USER CODE BEGIN SysInit */
  • /* USER CODE END SysInit */
  • /* Initialize all configured peripherals */
  • MX_GPIO_Init();
  • MX_GPDMA1_Init();
  • MX_TIM6_Init();
  • MX_UART4_Init();
  • MX_ADC2_Init();
  • /* USER CODE BEGIN 2 */
  • start_cycle_counter();
  • //DSP_RMS();
  • int64_t lCycleUsed = stop_cycle_counter();
  • printf("ADC DMA DEMO\n");
  • for (tmp_index = 0; tmp_index < ADC_CONVERTED_DATA_BUFFER_SIZE; tmp_index++)
  • uhADCxConvertedData[tmp_index] = VAR_CONVERTED_DATA_INIT_VALUE;
  • if (HAL_ADCEx_Calibration_Start(&hadc2, ADC_SINGLE_ENDED) != HAL_OK)
  • printf("ADC Calibration Err\n");
  • Error_Handler();
  • printf("ADC Calibration End\n");
  • /* USER CODE END 2 */
  • /* Infinite loop */
  • /* USER CODE BEGIN WHILE */
  • while (1)
  • /* USER CODE END WHILE */
  • /* USER CODE BEGIN 3 */
  • HAL_GPIO_TogglePin(LD4_GPIO_Port, LD4_Pin);
  • if (HAL_ADC_Start_DMA(&hadc2,(uint32_t *)uhADCxConvertedData,ADC_CONVERTED_DATA_BUFFER_SIZE) != HAL_OK)
  • Error_Handler();
  • HAL_Delay(50);
  • if (ubDmaTransferStatus == 1)
  • ubDmaTransferStatus = 0;
  • uhADCxConvertedData_Voltage_mVolt[tmp_index] = __LL_ADC_CALC_DATA_TO_VOLTAGE(VDDA_APPLI, uhADCxConvertedData[tmp_index], LL_ADC_RESOLUTION_12B);
  • //printf("voltage[%d]=%d mV\n",tmp_index,uhADCxConvertedData_Voltage_mVolt[tmp_index]);
  • //printf("%d\n",uhADCxConvertedData_Voltage_mVolt[tmp_index]);
  • arm_rfft_f32_app2();
  • printf("cycle counter = %lld\n",lCycleUsed);
  • /* USER CODE END 3 */
主要用到的函数是arm_rfft_fast_f32,函数原型是
  • void arm_rfft_fast_f32(
  • const arm_rfft_fast_instance_f32 * S,
  • float32_t * p,
  • float32_t * pOut,
  • uint8_t ifftFlag)
这个函数用于单精度浮点实数FFT,函数有4个参数:
S是FFT实例化句柄,调用函数arm_rfft_fast_init_f32初始化得到,然后供此函数arm_rfft_fast_f32调用。支持32, 64, 128, 256, 512, 1024, 2048, 4096点FFT。
比如做1024点FFT,代码如下:
arm_rfft_fast_init_f32(&S, 1024);
p是实数地址,比如我们要做1024点实数FFT,要保证有1024个缓冲。
pOut是FFT转换结果,转换结果不是实数了,而是复数,按照实部,虚拟,实部,虚部,依次排列。比如做1024点FFT,这里的输出也会有1024个数据,即512个复位。
ifftFlag用于设置正变换和逆变换,ifftFlag=0表示正变换,ifftFlag=1表示逆变换。
测试结果:
调用arm_rfft_fast_f32计算1024点FFT耗时184个时钟周期,主频配置的是600MHz,即1/600*184=0.307us,下图是大佬测试的STM32F4和F1的数据,可见1024点FFT性能可以说是F4的369.25/0.307=1202倍
此帖出自stm32/stm8论坛
1024点数据进行FFT运算看起来有点麻烦,整这么多代码   详情 回复 发表于 2024-11-12 08:32
7023
此帖出自stm32/stm8论坛
此帖出自stm32/stm8论坛
算法调用不麻烦  详情 回复 发表于 2024-11-14 17:16
1249
67
王1979 发表于 2024-11-12 08:32 **** 作者被禁止或删除 内容自动屏蔽 ****
算法调用不麻烦
此帖出自stm32/stm8论坛
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
