638|4
441
【匠芯创D133CBS】 RS485通信测试 [复制链接]
测试板卡上的RS485通信,通过命令来控制蜂鸣器开关。
一、硬件电路图
RS485部分电路图
二、外设配置
RS485采用2线制通信,在串口配置成RS485方式,配置如下:
2.1、使能串口1
2.2、选择RS485两线模式
三、程序
3.1、uart.c
//uart.c
#include <getopt.h>
#include <string.h>
#include <rtthread.h>
#include <aic_core.h>
#include "beep.h"
#define SAMPLE_UART_NAME "uart1"
#define TIMEOUT_NONE     -4096
static struct rt_semaphore rx_sem;
static rt_device_t serial;
static char str_send[] = "https://www.eeworld.com.cn/\n";
uint8_t g_recv_max = 128;
static int g_uart_test_result = 1;
static int g_exit = 0;
static int g_timeout = TIMEOUT_NONE;
static rt_timer_t  uart1_rx_timeout = RT_NULL;
char str_receive[128 + 1] = {0};
typedef struct
    uint8_t buf[128];
    uint8_t len;
    uint8_t rx_over;
} uart_rx_dat_t;
uart_rx_dat_t uart1_rx_dat = { 0 };
static void uart1_rx_timeout_cb(void *p)
    rt_timer_stop(uart1_rx_timeout);
    rt_kprintf("read_length: %d \n", uart1_rx_dat.len);
    uart1_rx_dat.rx_over = RT_TRUE;
rt_err_t uart1_input(rt_device_t dev, rt_size_t size)
    char ch;
    //rt_sem_release(&rx_sem);
    if(rt_device_read(serial, -1, &ch, 1)==1)
       uart1_rx_dat.buf[uart1_rx_dat.len++] = ch;
       rt_timer_start(uart1_rx_timeout);
    return RT_EOK;
void serial_uart1_thread_entry(void *parameter)
    uint8_t jx=0;
    char ch;
    int ret = 0;
    int cnt = 0;
    static int timeout_time = 0;
    static uint8_t rx_one_byte_flag = 1;
    while (1)
        if(uart1_rx_dat.rx_over == RT_TRUE)
            uart1_rx_dat.rx_over = RT_FALSE;
            rt_kprintf("read_dat: ");
            for(jx=0; jx<uart1_rx_dat.len; jx++)
                rt_kprintf("%02x  ", uart1_rx_dat.buf[jx]);
            rt_kprintf("\n");
             uart1_rx_dat.len=0;
            if( uart1_rx_dat.buf[0]==0xff &  uart1_rx_dat.buf[1]==0x2a)
                if(uart1_rx_dat.buf[2]==0x01)
                   beep_on();
                else if(uart1_rx_dat.buf[2]==0x00)
                    beep_off();
        rt_thread_mdelay(5);
int test_uart_sample(int argc, char *argv[])
    int c = 0;
    rt_err_t ret = RT_EOK;
    static rt_uint8_t open_cnt = 0;
    //查找串口设备
    serial = rt_device_find(SAMPLE_UART_NAME);
    if (!serial)
        rt_kprintf("find %s failed!\n", SAMPLE_UART_NAME);
        return -RT_ERROR;
    //初始化信号量
    rt_sem_init(&rx_sem, "rx_sem", 0, RT_IPC_FLAG_FIFO);
    //打开串口设备
    ret = rt_device_open(serial, RT_DEVICE_OFLAG_RDWR | RT_DEVICE_FLAG_INT_RX);
    if (ret != RT_EOK)
        rt_kprintf("open %s failed : %d !\n", SAMPLE_UART_NAME, ret);
        return -RT_ERROR;
    //设置接收回调函数
    rt_device_set_rx_indicate(serial, uart1_input);
    rt_device_write(serial, 0, str_send, (sizeof(str_send) - 1));
    //创建 serial 线程
    rt_thread_t thread = rt_thread_create("serial", serial_uart1_thread_entry, RT_NULL, 1024*2, 26, 10);
    if (thread != RT_NULL) {
        rt_thread_startup(thread);
    } else {
        rt_device_close(serial);
        return -RT_ERROR;
    //创建接收超时定时器
    uart1_rx_timeout = rt_timer_create("serial_timer", uart1_rx_timeout_cb, RT_NULL, 50, RT_TIMER_FLAG_PERIODIC);
    return ret;
MSH_CMD_EXPORT(test_uart_sample,  Uart Test);
四、程序运行
下载程序后,串口发送控制命令
4.1、执行测试命令
4.2、打开蜂鸣器
4.3、关闭蜂鸣器
也就是进入到me,配置串口1为rs485 compact io 即可是么?这个我配置成功了,并且我用的是官方的原helloworld例程,原bsp文件夹下有个uart.c文件,我替换成你提供的c文件,编译没报错,但是发送test_uart_sample ,提示没找到该命令。正常操作是将你的uart.c复制到工程里就行吧?   详情 回复 发表于 2024-9-23 09:40
点赞(1) 关注
294
大佬,这个例程我也试了一下,但是用串口ttl发送test_uart_sample提示我没有这个命令,是我这个函数没包含到主程序之中吗?是不是将uart.c复制到工程之中就可以呀?正常创建rtt线程是不是就算是包含到工程之中呢?
默认例程是没有打开的,需要在menuconfig中,打开此例程。  详情 回复 发表于 2024-9-23 09:36
441
yangjiaxu 发表于 2024-9-23 00:20 大佬,这个例程我也试了一下,但是用串口ttl发送test_uart_sample提示我没有这个命令,是我这个函数没包含 ...
也就是进入到me,配置串口1为rs485 compact io 即可是么?这个我配置成功了,并且我用的是官方的原helloworld例程,原bsp文件夹下有个uart.c文件,我替换成你提供的c文件,编译没报错,但是发送test_uart_sample ,  详情 回复 发表于 2024-9-23 09:40
294
TL-LED 发表于 2024-9-23 09:36 默认例程是没有打开的,需要在menuconfig中,打开此例程。
我是复制例程的代码,在此基础上修改,重新命名的。  详情 回复 发表于 2024-9-23 17:26
441
yangjiaxu 发表于 2024-9-23 09:40 也就是进入到me,配置串口1为rs485 compact io 即可是么?这个我配置成功了,并且我用的是官方的原hellow ...
