再利用ADC读取电位器的测试中,首先我们利用单线连接电位器输出引脚PB15与读取引脚PC0,接线图如下:
再使用demo中的ADC_SingleRead程序,代码如下:
* Copyright (c) 2022, Nations Technologies Inc.
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions are met:
* - Redistributions of source code must retain the above copyright notice,
* this list of conditions and the disclaimer below.
* Nations' name may not be used to endorse or promote products derived from
* this software without specific prior written permission.
* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY NATIONS "AS IS" AND ANY EXPRESS OR
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE
* DISCLAIMED. IN NO EVENT SHALL NATIONS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* [url=home.php?mod=space&uid=1307177]@File[/url] main.c
* [url=home.php?mod=space&uid=1315547]@author[/url] Nations
* [url=home.php?mod=space&uid=252314]@version[/url] v1.0.0
* @copyright Copyright (c) 2022, Nations Technologies Inc. All rights reserved.
#include "main.h"
/** @addtogroup ADC_ADC1_DMA
ADC_InitType ADC_InitStructure;
DMA_InitType DMA_InitStructure;
__IO uint16_t ADC1ConvertedValue[5],ADC2ConvertedValue[5],ADC3ConvertedValue[5],ADC4ConvertedValue[5];
void RCC_Configuration(void);
void GPIO_Configuration(void);
uint16_t ADC_GetData(ADC_Module* ADCx, uint8_t ADC_Channel);
void ADC_Initial(ADC_Module* ADCx);
/* ADC configuration ------------------------------------------------------*/
ADC_InitStructure.WorkMode = ADC_WORKMODE_INDEPENDENT;
ADC_InitStructure.MultiChEn = DISABLE;
ADC_InitStructure.ContinueConvEn = DISABLE;
ADC_InitStructure.ExtTrigSelect = ADC_EXT_TRIGCONV_NONE;
ADC_InitStructure.DatAlign = ADC_DAT_ALIGN_R;
ADC_InitStructure.ChsNumber = 1;
ADC_Init(ADCx, &ADC_InitStructure);
/* Enable ADC */
ADC_Enable(ADCx, ENABLE);
/*Check ADC Ready*/
while(ADC_GetFlagStatusNew(ADCx,ADC_FLAG_RDY) == RESET)
/* Start ADC calibration */
ADC_StartCalibration(ADCx);
/* Check the end of ADC calibration */
while (ADC_GetCalibrationStatus(ADCx))
* [url=home.php?mod=space&uid=159083]@brief[/url] Main program
int main(void)
/* System clocks configuration ---------------------------------------------*/
RCC_Configuration();
/* GPIO configuration ------------------------------------------------------*/
GPIO_Configuration();
ADC_Initial(ADC1);
ADC_Initial(ADC2);
ADC_Initial(ADC3);
ADC_Initial(ADC4);
while (1)
ADC1ConvertedValue[0]=ADC_GetData(ADC1,ADC1_Channel_06_PC0);
ADC1ConvertedValue[1]=ADC_GetData(ADC1,ADC1_Channel_07_PC1);
ADC2ConvertedValue[0]=ADC_GetData(ADC2,ADC2_Channel_08_PC2);
ADC2ConvertedValue[1]=ADC_GetData(ADC2,ADC2_Channel_09_PC3);
ADC3ConvertedValue[0]=ADC_GetData(ADC3,ADC3_Channel_07_PD10);
ADC3ConvertedValue[1]=ADC_GetData(ADC3,ADC3_Channel_08_PD11);
ADC4ConvertedValue[0]=ADC_GetData(ADC4,ADC4_Channel_09_PD12);
ADC4ConvertedValue[1]=ADC_GetData(ADC4,ADC4_Channel_10_PD13);
* @brief Configures the different system clocks.
/* Enable peripheral clocks ------------------------------------------------*/
/* Enable GPIOC clocks */
RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOF|RCC_APB2_PERIPH_GPIOG|RCC_APB2_PERIPH_GPIOA|RCC_APB2_PERIPH_GPIOB|RCC_APB2_PERIPH_GPIOC|RCC_APB2_PERIPH_GPIOD|RCC_APB2_PERIPH_GPIOE, ENABLE);
/* Enable ADC1, ADC2, ADC3 and ADC4 clocks */
RCC_EnableAHBPeriphClk(RCC_AHB_PERIPH_ADC1 | RCC_AHB_PERIPH_ADC2 | RCC_AHB_PERIPH_ADC3 | RCC_AHB_PERIPH_ADC4,
ENABLE);
/* RCC_ADCHCLK_DIV16*/
ADC_ConfigClk(ADC_CTRL3_CKMOD_AHB,RCC_ADCHCLK_DIV16);
RCC_ConfigAdc1mClk(RCC_ADC1MCLK_SRC_HSE, RCC_ADC1MCLK_DIV8); //selsect HSE as RCC ADC1M CLK Source
* @brief Configures the different GPIO ports.
GPIO_InitType GPIO_InitStructure;
/* Configure PC0 PC1 as analog input -------------------------*/
GPIO_InitStructure.Pin = GPIO_PIN_0 | GPIO_PIN_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_InitPeripheral(GPIOC, &GPIO_InitStructure);
/* Configure PC2 PC3 as analog input -------------------------*/
GPIO_InitStructure.Pin = GPIO_PIN_2 | GPIO_PIN_3;
/* Configure PD10 PD11 as analog input -------------------------*/
GPIO_InitStructure.Pin = GPIO_PIN_10 | GPIO_PIN_11;
GPIO_InitPeripheral(GPIOD, &GPIO_InitStructure);
/* Configure PD12 PD13 as analog input -------------------------*/
GPIO_InitStructure.Pin = GPIO_PIN_12 | GPIO_PIN_13;
uint16_t dat;
ADC_ConfigRegularChannel(ADCx, ADC_Channel, 1, ADC_SAMP_TIME_239CYCLES5);
/* Start ADC Software Conversion */
ADC_EnableSoftwareStartConv(ADCx, ENABLE);
while(ADC_GetFlagStatus(ADCx, ADC_FLAG_ENDC)==0){
ADC_ClearFlag(ADCx, ADC_FLAG_ENDC);
ADC_ClearFlag(ADCx, ADC_FLAG_STR);
dat=ADC_GetDat(ADCx);
return dat;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file pointer to the source file name
* @param line assert_param error line source number
void assert_failed(const uint8_t* expr, const uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
最终在旋钮位于最左边时读取PC0的值如下:
将旋钮调至最右边读取PC0的值:
发现PC1随着变化,于是将PC1接GND,接线图如下:
完成接线后读取旋钮位于最左边位置时的读数:
旋钮调至最右边的读数:
整体测试下来,ADC对于极限电压的抖动不大,感觉精度还是不错的。
