911|5
7059
【国民技术车规MCU N32A455开发板】2、驱动LCD屏 [复制链接]
【国民技术车规MCU N32A455开发板】1、开发板测试 - 汽车电子
接上篇,我的作业是需要用到LCD屏的,所以先驱动LCD屏。
【屏与GPIO的选择】
1、屏手头上有多种,前面有大佬写了一个stm7735的,所以就"学习”了一下他的帖子【国民技术车规MCU N32A455开发板】测评 - 4 - 中景园TFT_LCD移植+SPI2测试 - 测评中心专版。在此特别感谢@裴红恩大佬。主要是最近手头上的东西太多了。
2、GPIO的选择,为后期准备硬件SPI来驱动,考虑到速度的选择,我这里选取了SPI1来做接口。具体的引脚选择见下面的宏定义代码:
#define LCD_SPI                SPI1
#define LCD_SPI_CLK            RCC_APB2_PERIPH_SPI1
#define LCD_SPI_SCK_PIN        GPIO_PIN_5 /* PA.05 */
#define LCD_SPI_SCK_GPIO_PORT  GPIOA      /* GPIOA */
#define LCD_SPI_SCK_GPIO_CLK   RCC_APB2_PERIPH_GPIOA
#define LCD_SPI_MISO_PIN       GPIO_PIN_6 /* PA.06 */
#define LCD_SPI_MISO_GPIO_PORT GPIOA      /* GPIOA */
#define LCD_SPI_MISO_GPIO_CLK  RCC_APB2_PERIPH_GPIOA
#define LCD_SPI_MOSI_PIN       GPIO_PIN_7 /* PA.07 */
#define LCD_SPI_MOSI_GPIO_PORT GPIOA      /* GPIOA */
#define LCD_SPI_MOSI_GPIO_CLK  RCC_APB2_PERIPH_GPIOA
#define LCD_CS_PIN             GPIO_PIN_10 /* PE.10 */
#define LCD_CS_GPIO_PORT       GPIOE      /* GPIOE */
#define LCD_CS_GPIO_CLK        RCC_APB2_PERIPH_GPIOE
#define LCD_RES_PIN             GPIO_PIN_8 /* PE.8 */
#define LCD_RES_GPIO_PORT       GPIOE      /* GPIOE */
#define LCD_RES_GPIO_CLK        RCC_APB2_PERIPH_GPIOE
#define LCD_BL_PIN             GPIO_PIN_9 /* PE.9 */
#define LCD_BL_GPIO_PORT       GPIOE      /* GPIOE */
#define LCD_BL_GPIO_CLK        RCC_APB2_PERIPH_GPIOE
3、在屏的驱动中,我使用了软件SPI与硬件SPI兼容的模式,使用宏#define SPI_Soft   来切换使用哪种方式。
4、GPIO的初始化,我目前用到的只是输出接口,所以5个IO全部初始化为输出50MHz的速度:
void LCD_GPIO_Init(void)
	GPIO_InitType GPIO_InitStructure;
	RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOE, ENABLE);
	RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA, ENABLE);
	GPIO_InitStructure.Pin        =  LCD_CS_PIN | LCD_RES_PIN | LCD_BL_PIN;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;
#ifdef  SPI_Soft
	GPIO_InitPeripheral(GPIOE, &GPIO_InitStructure);
	GPIO_InitStructure.Pin        = LCD_SPI_SCK_PIN | LCD_SPI_MISO_PIN | LCD_SPI_MOSI_PIN ;
  GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
#else
	  RCC_EnableAPB2PeriphClk(LCD_SPI_CLK, ENABLE);
    /*!< Configure sFLASH_SPI pins: SCK */
    GPIO_InitStructure.Pin        = LCD_SPI_SCK_PIN;
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
    GPIO_InitPeripheral(LCD_SPI_SCK_GPIO_PORT, &GPIO_InitStructure);
    /*!< Configure sFLASH_SPI pins: MOSI */
    GPIO_InitStructure.Pin = LCD_SPI_MOSI_PIN;
    GPIO_InitPeripheral(LCD_SPI_MOSI_GPIO_PORT, &GPIO_InitStructure);
    /*!< Configure sFLASH_SPI pins: MISO */
    GPIO_InitStructure.Pin       = LCD_SPI_MISO_PIN;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitPeripheral(LCD_SPI_MISO_GPIO_PORT, &GPIO_InitStructure);
#endif
同时修改SPI输出数据的函数:
      函数说明:LCD串行数据写入函数
      入口数据:dat  要写入的串行数据
      返回值:  无
void LCD_Writ_Bus(u8 dat)
	u8 i;
	LCD_CS_Clr();
#ifdef  SPI_Soft
	for(i=0;i<8;i++)
		LCD_SCLK_Clr();
		if(dat&0x80)
		   LCD_MOSI_Set();
		else
		   LCD_MOSI_Clr();
		LCD_SCLK_Set();
		dat<<=1;
#else
	SPI_I2S_TransmitData(LCD_SPI, dat);
	while (SPI_I2S_GetStatus(LCD_SPI, SPI_I2S_TE_FLAG) == RESET)
#endif
  LCD_CS_Set();
这样就完成了移植代码的工作。其实如果是单个显示屏的话,可以不用初始化CS与BLK,CS直接接地,BLK直接接VCC,这样就可以使用4线就可以驱动好了。
5、字库的制作,打开PCtoLCD,创建24*24的字体:
在设置中选择如下图所示。
最后在如下图所示的地方输入需要的汉字,生成字模,然后把生成的内容复制到字库之中去。
  接着在主程序中编写测试代码:
#include "main.h"
#include "log.h"
#include "lcd_init.h"
#include "lcd.h"
int main(void)
    log_init();
		LCD_Init();//LCD初始化
		LCD_Fill(0,0,LCD_W,LCD_H,WHITE);
		LCD_ShowChinese(10,0,"国民技术",RED,WHITE,24,0);
		LCD_ShowString(24,30,"N32A455",RED,WHITE,16,0);
		while(1)
下载到开发板后,效果如下图所示:
但是我使用spi还没有驱动好屏,后面再试试。附工程源码。
ST7735_LDC.zip (8.37 MB, 下载次数: 8)
此帖出自汽车电子论坛
是非常好的芯片,争取多让他发一点光。 大佬会使用这款芯片在自己的工程中吗?   详情 回复 发表于 2024-4-6 14:23
赞赏
查看全部赞赏
点赞(1) 关注(1)
1286
请问N32A455对标是哪个系列的车用MCU?NXP的S32K144/6/8前几年市场推广很强
此帖出自汽车电子论坛
这个我不是很清梦呀,我只管用。不过车规以前是NXP、英飞凌占大部分。  详情 回复 发表于 2024-3-22 15:34
7059
beyond_笑谈 发表于 2024-3-22 15:11 请问N32A455对标是哪个系列的车用MCU?NXP的S32K144/6/8前几年市场推广很强
此帖出自汽车电子论坛
刚才看了一下规格书,这个MCU可以做一些非主动功能安全的车规级控制器,导航系统和影音娱乐系统除外。  详情 回复 发表于 2024-3-22 16:33
1286
lugl4313820 发表于 2024-3-22 15:34 这个我不是很清梦呀,我只管用。不过车规以前是NXP、英飞凌占大部分。
此帖出自汽车电子论坛
是非常好的芯片,争取多让他发一点光。  详情 回复 发表于 2024-3-22 16:48
7059
beyond_笑谈 发表于 2024-3-22 16:33 刚才看了一下规格书,这个MCU可以做一些非主动功能安全的车规级控制器,导航系统和影音娱乐系统除外。
是非常好的芯片,争取多让他发一点光。
此帖出自汽车电子论坛
37
是非常好的芯片,争取多让他发一点光。
大佬会使用这款芯片在自己的工程中吗?
此帖出自汽车电子论坛
