834|0
349
【得捷电子Follow me第4期】补充项目材料 [复制链接]
终极任务二  使用主控板内存储和以太网接口,实现轻量ftp文件服务器,可以上传、下载、删除文件
       参考大佬们的方案,采用microPython 进行开发,开发板重新刷入microPython固件。然后采用相同局域网网段的PC电脑对开发板进行FTP访问。
import socket
import network
import uos
import gc
from time import localtime
from machine import Pin,SPI
import time
def w5x00_init():
    #spi init
    spi=SPI(0,2_000_000, mosi=Pin(19),miso=Pin(16),sck=Pin(18))
    nic = network.WIZNET5K(spi,Pin(17),Pin(20)) #spi,cs,reset pin
    nic.active(True)#network active
    nic.ifconfig(('192.168.1.100','255.255.255.0','192.168.1.1','8.8.8.8'))#Set static network address information
    while not nic.isconnected():
        time.sleep(1)
        print(nic.regs())#Print register information
    #Print network address information
    print("IP Address:",nic.ifconfig()[0])
    print("Subnet Mask:",nic.ifconfig()[1])
    print("Gateway:",nic.ifconfig()[2])
    print("DNS:",nic.ifconfig()[3])
    return nic
month_name = ["", "Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"]
def send_list_data(path, dataclient, full):
    try: # whether path is a directory name
        for fname in uos.listdir(path):
            dataclient.sendall(make_description(path, fname, full))
    except: # path may be a file name or pattern
        pattern = path.split("/")[-1]
        path = path[:-(len(pattern) + 1)]
        if path == "": path = "/"
            if fncmp(fname, pattern) == True:
def make_description(path, fname, full):
    if full:
        stat = uos.stat(get_absolute_path(path,fname))
        file_permissions = "drwxr-xr-x" if (stat[0] & 0o170000 == 0o040000) else "-rw-r--r--"
        file_size = stat[6]
        tm = localtime(stat[7])
        if tm[0] != localtime()[0]:
            description = "{}    1 owner group {:>10} {} {:2} {:>5} {}\r\n".format(
                file_permissions, file_size, month_name[tm[1]], tm[2], tm[0], fname)
        else:
            description = "{}    1 owner group {:>10} {} {:2} {:02}:{:02} {}\r\n".format(
                file_permissions, file_size, month_name[tm[1]], tm[2], tm[3], tm[4], fname)
    else:
        description = fname + "\r\n"
    return description
def send_file_data(path, dataclient):
    with open(path, "r") as file:
        chunk = file.read(512)
        while len(chunk) > 0:
            dataclient.sendall(chunk)
def save_file_data(path, dataclient, mode):
    with open(path, mode) as file:
        chunk = dataclient.read(512)
            file.write(chunk)
def get_absolute_path(cwd, payload):
    # Just a few special cases "..", "." and ""
    # If payload start's with /, set cwd to /
    # and consider the remainder a relative path
    if payload.startswith('/'):
        cwd = "/"
    for token in payload.split("/"):
        if token == '..':
            if cwd != '/':
                cwd = '/'.join(cwd.split('/')[:-1])
                if cwd == '':
                    cwd = '/'
        elif token != '.' and token != '':
            if cwd == '/':
                cwd += token
            else:
                cwd = cwd + '/' + token
    return cwd
# compare fname against pattern. Pattern may contain
# wildcards ? and *.
def fncmp(fname, pattern):
    pi = 0
    si = 0
    while pi < len(pattern) and si < len(fname):
        if (fname[si] == pattern[pi]) or (pattern[pi] == '?'):
            si += 1
            pi += 1
        else:
            if pattern[pi] == '*': # recurse
                if (pi + 1) == len(pattern):
                    return True
                while si < len(fname):
                    if fncmp(fname[si:], pattern[pi+1:]) == True:
                        return True
                    else:
                        si += 1
                return False
            else:
                return False
    if pi == len(pattern.rstrip("*"))  and si == len(fname):
        return True
    else:
        return False
def ftpserver():
    DATA_PORT = 13333
    ftpsocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
    datasocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
    ftpsocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
    datasocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
    ftpsocket.bind(socket.getaddrinfo("0.0.0.0", 21)[0][4])
    datasocket.bind(socket.getaddrinfo("0.0.0.0", DATA_PORT)[0][4])
    ftpsocket.listen(1)
    datasocket.listen(1)
    datasocket.settimeout(10)
    msg_250_OK = '250 OK\r\n'
    msg_550_fail = '550 Failed\r\n'
    try:
        dataclient = None
        fromname = None
        while True:
            cl, remote_addr = ftpsocket.accept()
            cl.settimeout(300)
            cwd = '/'
            try:
                # print("FTP connection from:", remote_addr)
                cl.sendall("220 Hello, this is the ESP8266.\r\n")
                while True:
                    gc.collect()
                    data = cl.readline().decode("utf-8").rstrip("\r\n")
                    if len(data) <= 0:
                        print("Client disappeared")
                        break
                    command = data.split(" ")[0].upper()
                    payload = data[len(command):].lstrip()
                    path = get_absolute_path(cwd, payload)
                    print("Command={}, Payload={}, Path={}".format(command, payload, path))
                    if command == "USER":
                        cl.sendall("230 Logged in.\r\n")
                    elif command == "SYST":
                        cl.sendall("215 UNIX Type: L8\r\n")
                    elif command == "NOOP":
                        cl.sendall("200 OK\r\n")
                    elif command == "FEAT":
                        cl.sendall("211 no-features\r\n")
                    elif command == "PWD":
                        cl.sendall('257 "{}"\r\n'.format(cwd))
                    elif command == "CWD":
                        try:
                            files = uos.listdir(path)
                            cwd = path
                            cl.sendall(msg_250_OK)
                        except:
                            cl.sendall(msg_550_fail)
                    elif command == "CDUP":
                        cwd = get_absolute_path(cwd, "..")
                    elif command == "TYPE":
                        # probably should switch between binary and not
                        cl.sendall('200 Transfer mode set\r\n')
                    elif command == "SIZE":
                        try:
                            size = uos.stat(path)[6]
                            cl.sendall('213 {}\r\n'.format(size))
                        except:
                    elif command == "QUIT":
                        cl.sendall('221 Bye.\r\n')
                        break
                    elif command == "PASV":
                        addr = nic.ifconfig()[0]
                        cl.sendall('227 Entering Passive Mode ({},{},{}).\r\n'.format(
                            addr.replace('.',','), DATA_PORT>>8, DATA_PORT%256))
                        dataclient, data_addr = datasocket.accept()
                        # print("FTP Data connection from:", data_addr)
                    elif command == "LIST" or command == "NLST":
                        if not payload.startswith("-"):
                            place = path
                        else:
                            place = cwd
                        try:
                            send_list_data(place, dataclient, command == "LIST" or payload == "-l")
                            cl.sendall("150 Here comes the directory listing.\r\n")
                            cl.sendall("226 Listed.\r\n")
                        except:
                        if dataclient is not None:
                            dataclient.close()
                            dataclient = None
                    elif command == "RETR":
                        try:
                            cl.sendall("150 Opening data connection.\r\n")
                            cl.sendall("226 Transfer complete.\r\n")
                        except:
                            dataclient.close()
                            dataclient = None
                    elif command == "STOR":
                        try:
                            cl.sendall("150 Ok to send data.\r\n")
                            save_file_data(path, dataclient, "w")
                        except:
                            dataclient.close()
                            dataclient = None
                    elif command == "APPE":
                        try:
                            save_file_data(path, dataclient, "a")
                        except:
                            dataclient.close()
                            dataclient = None
                    elif command == "DELE":
                        try:
                            uos.remove(path)
                        except:
                    elif command == "RMD":
                        try:
                            uos.rmdir(path)
                        except:
                    elif command == "MKD":
                        try:
                            uos.mkdir(path)
                        except:
                    elif command == "RNFR":
                            fromname = path
                            cl.sendall("350 Rename from\r\n")
                    elif command == "RNTO":
                            if fromname is not None:
                                try:
                                    uos.rename(fromname, path)
                                except:
                            else:
                            fromname = None
                    else:
                        cl.sendall("502 Unsupported command.\r\n")
                        # print("Unsupported command {} with payload {}".format(command, payload))
            except Exception as err:
                print(err)
            finally:
                cl.close()
                cl = None
    finally:
        datasocket.close()
        ftpsocket.close()
            dataclient.close()
nic = w5x00_init()
ftpserver()
运行如图
建立了地址为192.168.1.100的ftp
在PC机上使用Xftp软件,建立连接
建立连接后传输一个文件到FTP上  将DGBCDX64.exe传输到ftp上
演示视频:
https://training.eeworld.com.cn/video/39557
代码下载:
源码
总结
       以前没接触过网络编程这次学到了很多网络底层的协议,提高了不少!
      感谢EEWorld和DigiKey!
