1087|2
6110
【 正点原子瑞芯微RV1126测评】6 socket服务器和客户端编程 [复制链接]
一、连接好网络并检查rv1126板子和电脑是否能ping
二、socket服务器程序和 编译的sh代码
socket_server.sh
/opt/atk-dlrv1126-toolchain/bin/arm-linux-gnueabihf-gcc -o socket_server socket_server.c
chmod +x socket_server
cp socket_server /mnt/hgfs/share/
socket_server.c
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <arpa/inet.h>
#include <netinet/in.h>
#define SERVER_PORT     8888
int main(void)
    struct sockaddr_in server_addr = {0};
    struct sockaddr_in client_addr = {0};
    char ip_str[20] = {0};
    int sockfd, connfd;
    int addrlen = sizeof(client_addr);
    char recvbuf[512];
    int ret;
    sockfd = socket(AF_INET, SOCK_STREAM, 0);
    if (0 > sockfd) {
        perror("socket error");
        exit(EXIT_FAILURE);
    server_addr.sin_family = AF_INET;
    server_addr.sin_addr.s_addr = htonl(INADDR_ANY);
    server_addr.sin_port = htons(SERVER_PORT);
    ret = bind(sockfd, (struct sockaddr *)&server_addr, sizeof(server_addr));
    if (0 > ret) {
        perror("bind error");
        close(sockfd);
        exit(EXIT_FAILURE);
    ret = listen(sockfd, 50);
    if (0 > ret) {
        perror("listen error");
        close(sockfd);
        exit(EXIT_FAILURE);
    connfd = accept(sockfd, (struct sockaddr *)&client_addr, &addrlen);
    if (0 > connfd) {
        perror("accept error");
        close(sockfd);
        exit(EXIT_FAILURE);
    printf("receive client...\n");
    inet_ntop(AF_INET, &client_addr.sin_addr.s_addr, ip_str, sizeof(ip_str));
    printf("client IP addr: %s\n", ip_str);
    printf("client PORT: %d\n", client_addr.sin_port);
    for ( ; ; ) {
    	memset(recvbuf, 0x0, sizeof(recvbuf));
        ret = recv(connfd, recvbuf, sizeof(recvbuf), 0);
        if(0 >= ret) {
            perror("recv error");
            close(connfd);
            break;
        printf("from client: %s\n", recvbuf);
        if (0 == strncmp("exit", recvbuf, 4)) {
            printf("server exit...\n");
            close(connfd);
            break;
	close(sockfd);
    exit(EXIT_SUCCESS);
三、在当前目录运行./ socket_server.sh编译出socket_server
四、socket客户端程序和编译的sh代码
socket_client.sh
/opt/atk-dlrv1126-toolchain/bin/arm-linux-gnueabihf-gcc -o socket_client socket_client.c
chmod +x socket_client
cp socket_client /mnt/hgfs/share/
socket_client.c
 socket_client.c
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
int main(void)
    char buf[512];
    int sockfd;
    int ret;
    char ip[32]="";
    printf("please input ip addr !\n");
    if(scanf("%s",&ip) != 1){
    	printf("input ip error!\n ");
    else{
			printf("ip addr is %s \n",&ip);
    if (0 > sockfd) {
        exit(EXIT_FAILURE);
    memset(&server_addr,0,sizeof(server_addr));
    server_addr.sin_addr.s_addr =inet_addr(&ip);
    ret = connect(sockfd, (struct sockaddr *)&server_addr, sizeof(server_addr));
    if (0 > ret) {
        perror("connect error");
        close(sockfd);
        exit(EXIT_FAILURE);
    printf("server connect succeed...\n\n");
    for ( ; ; ) {
        memset(buf, 0x0, sizeof(buf));
        printf("Please enter a string: ");
        fgets(buf, sizeof(buf), stdin);
        ret = send(sockfd, buf, strlen(buf), 0);
        if(0 > ret){
            perror("send error");
            break;
        if(0 == strncmp(buf, "exit", 4))
            break;
    close(sockfd);
    exit(EXIT_SUCCESS);
五、在当前目录运行./ socket_client.sh编译出socket_client
六、编译好后用adb socket_serversocket_client传到rv1126板子上修改可执行属性
七、运行服务器程序./socket_server
用电脑的tcp工具的客户端连接。
运行结果如下:
八、运行电脑的服务器调试工具,打开服务器监听
运行客户端程序./socket_client
输入ip地址
运行结果如下:
好实验先到这里,谢谢大家。
编译好后用adb 把socket_server、socket_client传到rv1126板子上修改可执行属性,这个步骤是个重点   详情 回复 发表于 2024-2-24 08:03
6850
谢谢支持。客户端程序加了个输入服务器ip的提示和输入。方便调试。  详情 回复 发表于 2024-3-14 12:17
6110
Jacktang 发表于 2024-2-24 08:03 编译好后用adb 把socket_server、socket_client传到rv1126板子上修改可执行属性,这个步骤是个重点
