670|1
【得捷Follow me第4期】终极任务二:使用外部存储器,组建简易FTP文件服务器 [复制链接]
 【得捷Follow me第4期】终极任务二:使用外部存储器,组建简易FTP文件服务器,并能正常上传下载文件。
前面任务一直使用的arduino IDE,进行最后一个任务的时候一直没把外部存储给搞定,最后只好把软件换成了VScode,顺利启动了FTP服务器。PC端使用filezilla进行访问。
#include <stdio.h>
#include "pico/stdlib.h"
#include "pico/binary_info.h"
#include "hardware/spi.h"
#include "hardware/uart.h"
#include "hardware/irq.h"
#include "wizchip_conf.h"
#include "bsp_spi.h"
#include "dhcp.h"   // Use dhcp
#include "socket.h" // Use socket
#include "ftpd.h"   // Use ftp server
#define SOCKET_ID 0                      // Socket number
#define ETHERNET_BUF_MAX_SIZE (1024 * 2) // Send and receive cache size
#define DHCP_RETRY_COUNT 5               // DHCP retry times
 * [url=home.php?mod=space&uid=159083]@brief[/url] Timer callback processing function, used for dhcp timing processing
 * @param   repeating :Timer structure
 * [url=home.php?mod=space&uid=784970]@return[/url] bool
bool repeating_timer_callback(struct repeating_timer *t);
 * @brief   Initialization of chip network information
 * @param   conf_info :Static configuration information
 * @return  none
void network_init(wiz_NetInfo *conf_info);
/* Network information to be configured. */
wiz_NetInfo net_info = {
    .mac = {0x00, 0x08, 0xdc, 0x11, 0x22, 0x33}, // Configured MAC address
    .ip = {192, 168, 0, 10},                     // Configured IP address
    .sn = {255, 255, 255, 0},                    // Configured subnet mask
    .gw = {192, 168, 0, 1},                      // Configured gateway
    .dns = {8, 8, 8, 8},                         // Configured domain address
    .dhcp = NETINFO_DHCP};                       // Configured dhcp model,NETINFO_DHCP:use dhcp; NETINFO_STATIC: use static ip.
static uint8_t ethernet_buf[ETHERNET_BUF_MAX_SIZE] = {
    0,
}; // Send and receive cachestatic
static uint8_t uart_buf[ETHERNET_BUF_MAX_SIZE] = {
    0,
static uint8_t local_ip[4];
static uint8_t breakout_flag = 0; // Define the DHCP acquisition flag
int main()
    struct repeating_timer timer; // Define the timer structure
    wiz_NetInfo get_info;
    /* MCU init */
    stdio_init_all();     // Initialize the main control peripheral
    wizchip_initialize(); // Initialize the chip interface
    wizchip_setnetinfo(&net_info); // Configure once first
    /*dhcp init*/
    DHCP_init(SOCKET_ID, ethernet_buf);                                   // DHCP initialization
    add_repeating_timer_ms(1000, repeating_timer_callback, NULL, &timer); // Add DHCP 1s Tick Timer handler
    printf("wiznet chip ftp server example.\r\n");
    network_init(&net_info);              // Configuring Network Information
    print_network_information(&get_info); // Read back the configuration information and print it
    getIPfromDHCP(local_ip); // Get the local IP address
    ftpd_init(local_ip);
    while (true)
        ftpd_run(ethernet_buf); // Run FTP Server
    int count = 0;
    uint8_t dhcp_retry = 0;
    if (conf_info->dhcp == NETINFO_DHCP)
        while (true)
            switch (DHCP_run()) // Do the DHCP client
            case DHCP_IP_LEASED: // DHCP resolves the domain name successfully
                if (breakout_flag == 0)
                    printf("DHCP success\r\n");
                    getIPfromDHCP((*conf_info).ip);
                    getGWfromDHCP((*conf_info).gw);
                    getSNfromDHCP((*conf_info).sn);
                    getDNSfromDHCP((*conf_info).dns);
                    wizchip_setnetinfo(conf_info); // Configuring Network Information
                    close(SOCKET_ID);              // After dhcp close the socket, avoid errors in later use
                    breakout_flag = 1;
                break;
            case DHCP_FAILED:
                printf(" DHCP failed \r\n");
                count++;
                if (count <= DHCP_RETRY_COUNT) // If the number of times is less than or equal to the maximum number of times, try again
                    printf("DHCP timeout occurred and retry %d \r\n", count);
                else if (count > DHCP_RETRY_COUNT) // If the number of times is greater than DHCP fails
                    breakout_flag = 1; // if DHCP fail, use the static
                    DHCP_stop();       // Stop processing DHCP protocol
                    conf_info->dhcp = NETINFO_STATIC;
                    break;
                break;
            if (breakout_flag)
                printf("config succ\r\n");
                break;
    else
    DHCP_time_handler(); // DHCP 1s Tick Timer handler
    return true;
启动后,主控板通过DHCP进行配置,配置成功后将服务器地址、账户和密码发送到串口监视器。
PC端启动filezilla软件使用穿孔打印的信息登录FTP服务器,测试上传和下载功能
还是VScode好,能找到底层代码。   详情 回复 发表于 2024-2-20 17:35
7244
还是VScode好,能找到底层代码。
