使用jetpack安装的jetson,自带了opencv,但是没有cuda加速的,输入opencv_version
使用jtop查看,可以确认自带的opencv是没用cuda的
卸载opencv,先查看有哪些包
pip3 list | grep opencv
opencv-python
然后卸载掉python包以及lib库
- pip3 uninstall opencv-python
- sudo apt purge libopencv*
- sudo apt autoremove
- sudo apt update
安装后面编译需要用到的依赖库
- sudo apt install -y build-essential checkinstall cmake pkg-config yasm git gfortran
- sudo apt update
- sudo apt install -y libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev
- sudo apt install -y libjpeg8-dev libjasper-dev libpng12-dev libtiff5-dev libavcodec-dev libavformat-dev libswscale-dev libdc1394-22-dev libxine2-dev libv4l-dev
- sudo apt install -y libgstreamer1.0-dev libgstreamer-plugins-base1.0-dev libgtk2.0-dev libtbb-dev libatlas-base-dev libfaac-dev libmp3lame-dev libtheora-dev libvorbis-dev libxvidcore-dev libopencore-amrnb-dev libopencore-amrwb-dev x264 v4l-utils
- sudo apt install python-dev python-numpy libtbb2 libtbb-dev libjpeg-dev libpng-dev libtiff-dev libjasper-dev libdc1394-22-dev
下载如下两个仓库
https://github.com/opencv/opencv/releases
https://github.com/opencv/opencv_contrib/releases
解压在同一个文件夹下面
- cd opencv-4.5.5
- mkdir build
- //绝对路径
- cmake \
- -DCMAKE_BUILD_TYPE=Release \
- -DCMAKE_INSTALL_PREFIX=/usr/local \
- -DOPENCV_ENABLE_NONFREE=1 \
- -DBUILD_opencv_python2=1 \
- -DBUILD_opencv_python3=1 \
- -DWITH_FFMPEG=1 \
- -DCUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda \
- -DCUDA_ARCH_BIN=7.2 \
- -DCUDA_ARCH_PTX=7.2 \
- -DWITH_CUDA=1 \
- -DENABLE_FAST_MATH=1 \
- -DCUDA_FAST_MATH=1 \
- -DWITH_CUBLAS=1 \
- -DOPENCV_GENERATE_PKGCONFIG=1 \
- -DOPENCV_EXTRA_MODULES_PATH=/home/jetson/Downloads/opencv-4.5.5/opencv_contrib-4.5.5/modules \
- make -j6
- sudo make install
可以看到cmake的时候,显示的一些配置信息
其中cv2的包将安装到/lib/python3.8/site-packages/cv2/python-3.8,如下为make的过程
使用jtop可以看到opencv已经支持cuda加速了
- cd opencv-4.5.5/build/python_loader
- sudo pip3 install .
再测试一下,发现和jtop看到的是一致的
- jetson@ubuntu:~/Downloads/opencv-4.5.5/build/python_loader$ python3
- Python 3.8.10 (default, Nov 22 2023, 10:22:35)
- [GCC 9.4.0] on linux
- Type "help", "copyright", "credits" or "license" for more information.
- >>> import cv2
- >>> cv2.__version__
- '4.5.5'
- >>> quit()
视频讲解
