2365|1
枚举设备的色深 [复制链接]
WinCE 4.2以上版本可以使用EnumDisplaySettings来枚举设备的色深等模式信息,但是WinCE4.2以下版本用什么方法获取呢?还有其他的方法来枚举设备的色深等模式信息吗?
This function retrieves information about the capabilities of a specified device. int GetDeviceCaps(   HDC hdc,   int nIndex ); Parameters hdc [in] Handle to the device context. nIndex [in] Specifies the item to return. This parameter can be one of the following values. Value Description ASPECTX Relative width of a device pixel used for line drawing. ASPECTXY Diagonal width of the device pixel used for line drawing. ASPECTY Relative height of a device pixel used for line drawing. BITSPIXEL Number of adjacent color bits for each pixel.   详情 回复 发表于 2010-4-2 09:41
61
int GetDeviceCaps(
  HDC hdc,
  int nIndex
Parameters
hdc
nIndex
Value Description
