2871|2
58
Platform Builder for Microsoft Windows CE 5.0 Compiler Error C2220 [复制链接]
正在编译一款 BSP,碰到 Compiler Error C2220, 查帮助:
Platform Builder User's Guide > Compilers for Microprocessors > Error Messages > Build Errors > Compiler Errors C2200 through C2299
warning treated as error - no object file generated
/WX tells the compiler to treat all warnings as errors.
The following example shows a possible solution for this error.s
Fix the problem that caused the warning.
Compile at a lower warning level.
Compile without /WX.
一般应该是在工程的设置里  详情 回复 发表于 2010-6-1 12:30
79
我想用下面两种方法解决:
但不知道如何具体实现,应该改那里的配置?
知道的帮忙说一下。
75
一般应该是在工程的设置里
