TRACE("Prepare data for StartReadUrb()\n");
// Acquire the remove lock so we can't remove the device while the IRP
// is still active.
NTSTATUS status = IoAcquireRemoveLock(&Extension->RemoveLock, Irp);
if (!NT_SUCCESS(status))
Extension->pollpending = 0;
return status;
// Initialize the URB we use for reading the interrupt pipe
// This IRP might have been cancelled the last time it was used, in which case
// the cancel flag will still be on. Clear it to prevent USBD from thinking that it's
// been cancelled again! A better way to do this would be to call IoReuseIrp,
// but that function is not declared in WDM.H.
¸½ÉÏlog
Entering DriverEntry(), RegistryPath=
exiting DriverEntry
enter UsbCom_PnPAddDevice()
enter UsbCom_CreateDeviceObject()
Enter SerialGetRegistryKeyValue
***** DRV=862d4040 PDO=8626dde8 FDO=86268030 (\Device\SOPE1USB1) *****
SUCCEEDED IoSetDeviceInterfaceState()
DO=86268030 SYMBOLIC LINK =
UsbCom_QueryCapabilities() ntStatus from IoCallDriver to PCI = 0x0
Enter UsbCom_SelfSuspendOrActivate(),fSuspend = 1
ABORTING UsbCom_SelfSuspendOrActivate()
exit UsbCom_PnPAddDevice() (0)
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor PowerSystemWorking, -- 18
UsbCom_ProcessPnPIrp() Minor PnP IOCTL not handled
UsbCom_ProcessPnPIrp() Passing PnP Irp down, status = 0
UsbCom_ProcessPnPIrp() Exit UsbCom_ProcessPnPIrp c00000bb
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor IRP_MN_QUERY_RESOURCE_REQUIREMENTS, -- b
UsbCom_ProcessPnPIrp() Exit UsbCom_ProcessPnPIrp 2
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor IRP_MN_FILTER_RESOURCE_REQUIREMENTS, -- d
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor IRP_MN_START_DEVICE, -- 0
enter UsbCom_ProcessSysControlIrp()
enter UsbCom_StartDevice
UsbCom_ProcessSysControlIrp() Exit UsbCom_ProcessSysControlIrp 0
UsbCom_StartDevice() SUCCESS ExAllocatePool() for URB_CONTROL_DESCRIPTOR_REQUESTUsbCom_StartDevice() SUCESS ExAllocatePool() for deviceDescriptor
UsbCom_CallUSBD() (0) DO=86268030 Urb=87ad4fb0 Irp=87cdef20
Device Descriptor = 87918fe8, len 0x12
I82930 Device Descriptor:
bLength 18
bDescriptorType 0x1
bcdUSB 0x200
bDeviceClass 0x0
bDeviceSubClass 0x0
bDeviceProtocol 0x0
bMaxPacketSize0 0x40
idVendor 0xa5c
idProduct 0x2132
bcdDevice 0x202
iManufacturer 0x0
iProduct 0x0
iSerialNumber 0x0
bNumConfigurations 0x1
enter UsbCom_ConfigureDevice
UsbCom_CallUSBD() (1) DO=86268030 Urb=87e98fb0 Irp=87d22f20
UsbCom_CallUSBD() (2) DO=86268030 Urb=87e98fb0 Irp=8801cf20
UsbCom_SelectInterface() DO=86268030 Interfaces=1
UsbCom_CallUSBD() (3) DO=86268030 Urb=862794c8 Irp=877e0f20
NumberOfPipes 0x3
Length 0x4c
Alt Setting 0x0
Interface Number 0x0
Class, subclass, protocol 0xff 0x0 0x0
PipeType 0x3
EndpointAddress 0x81
MaxPacketSize 0x10
Interval 0x4
Handle 0x8630726c
MaximumTransferSize 0x400
InterruptPipe 0x0
PipeType 0x2
EndpointAddress 0x2
MaxPacketSize 0x200
Interval 0x0
Handle 0x8630728c
DataOutPipe 0x1
PipeType 0x2
EndpointAddress 0x82
MaxPacketSize 0x200
Interval 0x0
Handle 0x863072ac
DataInPipe 0x2
SERIAL: The default interrupt read buffer size is: 0
------ The XoffLimit is : 0
------ The XonLimit is : 0
------ The pt 8 size is : 0
exit UsbCom_StartDevice (0)
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor IRP_MN_QUERY_CAPABILITIES, -- 9
[ss] Allow surprise removals --
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor IRP_MN_QUERY_BUS_INFORMATION, -- 14
UsbCom_ProcessPowerIrp() IRP_MJ_POWER
UsbCom_ProcessPowerIrp() UNKNOWN POWER MESSAGE (ff)
Exit UsbCom_ProcessPowerIrp() ntStatus = 0xc00000bb
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor IRP_MJ_INTERNAL_DEVICE_CONTROL, -- ff
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor IRP_MN_QUERY_DEVICE_RELATIONS, -- 7
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor IRP_MN_QUERY_DEVICE_TEXT, -- c
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor IRP_MN_QUERY_PNP_DEVICE_STATE, -- 13
enter UsbCom_ProcessPnPIrp() IRP_MJ_PNP, minor IRP_MN_QUERY_INTERFACE, -- 8
UsbCom_ProcessPnPIrp() Exit UsbCom_ProcessPnPIrp 0
entering UsbCom_Create DO=86268030 Irp=87338eb8
exit UsbCom_Create 0
SERIAL: Dispatch InternalIoControl entry for: 87750ed8
USBSerial IOCTL: beginning set baud rate.
enter UsbCom_SetBaud() DO=86268030 Irp=87ef6ed8 BaudRate=1200
exit UsbCom_SetBaud() Status=00000000
SERIAL: Complete Irp: 882c2ed8
Enter SerialRead
Interrupt Buffer less than half full - Submitting next Read URB
Enter StartReadUrbnew() DO=86268030
IoCallDriver
