3546|3
我是菜鸟,那位大哥能为小弟提供vxworks下udp通信源代码?或者给我推荐一本可以解决问题的书,我想实现在一个主程序里自发自收,不知道怎么实现啊,先谢啦 [复制链接]
 我想用udp方式实现任务间的通信,那位大侠可以帮个忙阿
        struct sockaddr_in   local;         struct sockaddr_in   from;           int localfd;         int ret=0;         int len;         unsigned char buffer[80];         struct fd_set readFds;         struct timeval timeval;         bzero((char *)&local,sizeof(local));         local.sin_family = AF_INET;           local.sin_addr.s_addr = htonl (INADDR_ANY);           local.sin_port = htons(gNetInfo.whoamiPort) ;         if((localfd=socket(AF_INET, SOCK_DGRAM, 0)) == ERROR)         {                 logMsg("frame send Task socket() error:%s\n",(int)strerror(errno),0,0,0,0,0);         }         if(bind(localfd, (struct sockaddr *)&local, sizeof(struct sockaddr_in))==ERROR)         {                 logMsg("frame send Task bind() error:%s\n",(int)strerror(errno),0,0,0,0,0);         }                        timeval.tv_sec = 1;         timeval.tv_usec=0;         while(1)         {                 FD_ZERO (&readFds);                 FD_SET (localfd, &readFds);                 ret = select(localfd+1,&readFds,0,0,&timeval);                 if (ret == 0)                 {                         /* time out */                 }                 else if (FD_ISSET (localfd, &readFds))                 {                         len = recvfrom(localfd, buffer, 20, 0, (struct aockaddr *)&from, sizeof(struct sockaddr_in));                         if(len>0)                         {                                 /* data */                         }                 }         }   详情 回复 发表于 2008-3-11 15:13
82
127.0.0.1可以不可以么?
VxWork里,把socket作为一种任务间通信的机制,
Tornado online manual,和常见的书里都应该有讲的,
79
如果你连127.0.0.1都不懂,我劝你还是先补习下网络知识吧,
63
          int localfd;
        int ret=0;
        int len;
        timeval.tv_sec = 1;
        timeval.tv_usec=0;
        while(1)
                FD_ZERO (&readFds);
                if (ret == 0)
                        /* time out */
                        if(len>0)
                                /* data */
